Looking for help with adding gold flecks to stone
Through many helpful tutorials, I made the cover for my book. I decided to update the title to be a metallic bevel, and most people say that the gold title (vs a silver-green or bright green) stands out the best.
My sis-in-law suggested I add gold flecks to the stone, to help create a harmonious color effect. I'm not sure how to do that.
Does anyone have a tutorial suggestion to add gold flecks?
post-102816-0-77353500-1413817426_thumb.
Edited by hippiechos
Thanks for the suggestion. It does add a yellow tint to all of the stone, but I was hoping for something more subtle that doesn't permeate everything. I tried adding noise, but the image is too large (300 ppi) and the noise doesn't show up.
I guess I'll keep playing and see if I can find something.
Note: I have not tried the following steps myself. It may not work, but if you understand what I'm trying to do, it shouldn't be too difficult to fix it.
Add a new layer and fill it with black. Add noise to this layer with maximum intensity and about 3% coverage.
Use the mosaic plugin to change the noise into larger flakes, then use dents at low settings to distort the shapes a little.
Change the color of the flakes with whatever method pleases you, then change the layer blend mode till it suits you.
Erase/paint over some of the flakes in a way that makes it less uniform
