Suggestions for lighting direction
I have always wondered if there was a way or a plugin that can control where the light source on a image or layer comes from. The Curves and Levels tools are not always reliable.
I like to render a light source that comes from one direction such as from the left side, right side, from above or even below. The light source can be vertical, horizontal or in a tilted diagonal angle. And there should also be an option if it expands and fades as it comes closer to the center of the image. Imagine the rays of the sun of the light beam of a flashlight? I want to render that kind of lighting.
It would be very useful in creating an artificial light source. If there isn't a plugin written for this yet, let me be the first to make a call towards making one. Thank you.
I am aware of making another layer and using a transparent gradient to mimic a light source. I have tried that multiple times but it has limitations. I think I might have used something like that on the shadow side of the planet of my profile picture.
However, it would have been better if it can be applied without needing another layer. Such a plugin would greatly affect and enhance an image that needs directional lighting to be added. I recently used the Sharpen Landscape plugin for enhancing a dull landscape image I found and it has good effects, thanks to its multiple adjustment controls. Maybe a new plugin for rendering a light source with comparable mechanics can be made.
And thanks Goonfella for linking that Light Rays Plugin. I was looking for that plugin but that's another story.
Isn't lighting the primary function of a Normal Map?  http://en.wikipedia.org/wiki/Normal_mapping
There are a few plugins.  This one Normal Tools has excellent supporting documentation.
do you mean something like this?
Plugin Retracted
It's under the Color menu
CodeLab Source Code
Hidden Content:
// Submenu: Color
// Name: TR's SimpleLight
// Title: TR's SimpleLight- v1.0
// Author: TechnoRobbo
// URL: http://www.technorobbo.com
#region UICode
Pair<double, double> Amount1 = Pair.Create( 0.0 , 0.0 ); // Hot Spot
double Amount2 = 0.5; // [0,4] Coverage
byte Amount3 = 0; // [1] Type|Normal|Flood|Spot
double Amount4 = 1; // [0.5,2] Gain
#endregion
    // Delete any of these lines you don't need
    int CenterX = ((selection.Right - selection.Left) / 2)+selection.Left;
    int CenterY = ((selection.Bottom - selection.Top) / 2)+selection.Top;
    ColorBgra PrimaryColor = (ColorBgra)EnvironmentParameters.PrimaryColor;
    ColorBgra SecondaryColor = (ColorBgra)EnvironmentParameters.SecondaryColor;
    int BrushWidth = (int)EnvironmentParameters.BrushWidth;
    System.Drawing.PointF org =new System.Drawing.PointF( (float)Amount1.First, (float)Amount1.Second);
    float range =  (float)Amount2;
    ColorBgra CP;
            float relx = (float)(x -  CenterX) / (float)CenterX;
            float rely = (float)(y -  CenterY) / (float)CenterY;
            float dist =(float) Math.Sqrt((org.X - relx )*(org.X - relx )
                    + (org.Y - rely)*(org.Y - rely));
            float coeff = (dist > range)? 0: (1f - dist/range);
            coeff *= (float)Amount4;
            if (Amount3==1)
                coeff = (float)Math.Sqrt(coeff);
            }else if (Amount3==2)
                coeff *= coeff;
            CP = src[x,y];
            float tmp = (float)CP.R * coeff;
            tmp = (tmp > 255) ? 255: tmp;
            CP .R = (byte)tmp;
            tmp = (float)CP.G * coeff;
            tmp = (tmp>255) ? 255: tmp;
            CP .G = (byte)tmp;
            tmp = (float)CP.B * coeff;
            CP .B = (byte)tmp;
            CP.A = (byte)CP.A;
            dst[x,y] = CP;
not published yet - need to make it 3.5 and Plugin browser compatible.
TRsSig.png?raw=1
