Unfocus effect "transparent pixels" problem
Collision
So this is what happens whenever you load a PNG file and try applying "Unfocus" effect on it, it all goes transparent like in the picture below :
Sometimes you get to see only some parts of the picture (mainly when it's a text or an object with the same color), I also think that it may be a memory-related issue.
Can you provide me with two things?
1) The output from Settings -> Diagnostics (there's a "Copy to Clipboard" button")
2) Attach one of the PNGs which causes this to happen to your reply
For 1) :
Application	paint.net 4.0.3 (Final 4.3.5316.40022)
Build Date	mardi 22 juillet 2014
Hardware accelerated rendering (GPU)	True
Animations	True
DPI	96.00 (1.00x scale)
Language	en-US
OS	Windows 7 Service Pack 1 (6.1.7601.65536)
.NET Runtime	4.0.30319.17929
Physical Memory	8 076 MB
CPU	Intel(R) Core(TM) i7-3770K CPU @ 3.50GHz
    Architecture	x64 (64-bit)
    Process Mode	64-bit
    Speed	~3500 MHz
    Cores / Threads	8
    Features	DEP, SSE, SSE2, SSE3, SSSE3, SSE4_1, SSE4_2, XSAVE
Video Card	NVIDIA GeForce GTX 770
    Dedicated Video RAM	1 990 MB
    Dedicated System RAM	0 MB
    Shared System RAM	2 048 MB
    Vendor ID	0x10DE
    Device ID	0x1184
    Subsystem ID	0x28251462
    Revision	161
    LUID	0x0000A3C0
    Flags	None
    Outputs	1
Video Card	Intel(R) HD Graphics 4000
    Dedicated Video RAM	64 MB
    Shared System RAM	1 632 MB
    Vendor ID	0x8086
    Device ID	0x0162
    Subsystem ID	0x01621849
    Revision	9
    LUID	0x0000A6EF
    Flags	None
    Outputs	0
For 2) : A screenshot taken from a Vegas Pro 12.0 project.
(Couldn't attach it because its size is higher than 256 KB)
