Mark J Posted September 12, 2014 Share Posted September 12, 2014 (edited) Where is the download for this Plugin( Effects/Photo/Lens Distortion......) See attached pic. I have this on my laptop running windows 7 and Paint.net V3.5.11. It is perfect for barrel distortion correction on the projects that I do. I would like to add this to my work computer running windows 8 and Paint.net V4.0.3 and can not find it anywhere. I even copied all of my .dll program files to that computer thinking it would transfer with everything else but it didn't. Any suggestions? Thanks in advance for the help Mark Edited September 12, 2014 by Mark J Quote Link to comment Share on other sites More sharing options...
Red ochre Posted September 12, 2014 Share Posted September 12, 2014 That is a useful plugin!Do you have the file named 'kb_lens.dll' in your Pdn4 paint.net/Effects folder? - if you do and it's not showing up, then sadly it may not be Pdn 4 compatible. (I can't test as don't have Pdn 4)Perhaps ask on the thread (unlikely, but the author may still be around?)http://forums.getpaint.net/index.php?showtopic=7216 Btw the effect is listed in the plugin index as 'Camera lens distorion' - 'lens distortion' is a different (more complex U.I.) plugin you could try. Quote Red ochre Plugin pack.............. Diabolical Drawings ................Real Paintings Link to comment Share on other sites More sharing options...
Ego Eram Reputo Posted September 13, 2014 Share Posted September 13, 2014 This is compatible with PDN 4.0.3. Quote ebook: Mastering Paint.NET | resources: Plugin Index | Stereogram Tut | proud supporter of Codelab plugins: EER's Plugin Pack | Planetoid | StickMan | WhichSymbol+ | Dr Scott's Markup Renderer | CSV Filetype | dwarf horde plugins: Plugin Browser | ShapeMaker Link to comment Share on other sites More sharing options...
