midora Posted September 10, 2014 Share Posted September 10, 2014 (edited) Did a small fix for the high dpi issue regarding the arrow and checkmark symbols in ToolStrip. Maybe it is usefull for someone else. class OptionToolStripMenuRenderer : ToolStripProfessionalRenderer { protected override void OnRenderArrow(ToolStripArrowRenderEventArgs e) { Graphics g = e.Graphics; Rectangle dropDownRect = e.ArrowRectangle; using (Brush brush = new SolidBrush(e.ArrowColor)) { Point middle = new Point(dropDownRect.Left + dropDownRect.Width / 2, dropDownRect.Top + dropDownRect.Height / 2); Point[] arrow; int hor = Ui.ScaleWidth(2); int ver = Ui.ScaleHeight(2); switch (e.Direction) { case ArrowDirection.Up: arrow = new Point[] { new Point(middle.X - hor, middle.Y + 1), new Point(middle.X + hor + 1, middle.Y + 1), new Point(middle.X, middle.Y - ver)}; break; case ArrowDirection.Left: arrow = new Point[] { new Point(middle.X + hor, middle.Y - 2 * ver), new Point(middle.X + hor, middle.Y + 2 * ver), new Point(middle.X - hor, middle.Y)}; break; case ArrowDirection.Right: arrow = new Point[] { new Point(middle.X - hor, middle.Y - 2 * ver), new Point(middle.X - hor, middle.Y + 2 * ver), new Point(middle.X + hor, middle.Y)}; break; case ArrowDirection.Down: default: arrow = new Point[] { new Point(middle.X - hor, middle.Y - 1), new Point(middle.X + hor + 1, middle.Y - 1), new Point(middle.X, middle.Y + ver) }; break; } g.FillPolygon(brush, arrow); } } protected override void OnRenderItemCheck(ToolStripItemImageRenderEventArgs e) { Rectangle imageRect = e.ImageRectangle; Image image = e.Image; if (imageRect != Rectangle.Empty && image != null) { bool disposeImage = false; if (!e.Item.Enabled) { image = CreateDisabledImage(image); disposeImage = true; } // Draw the checkmark background (providing no image) base.OnRenderItemCheck(new ToolStripItemImageRenderEventArgs(e.Graphics, e.Item, null, e.ImageRectangle)); // Draw the checkmark image scaled to the image rectangle e.Graphics.DrawImage(image, imageRect, new Rectangle(Point.Empty, image.Size), GraphicsUnit.Pixel); if (disposeImage) { image.Dispose(); } } } } Edited September 11, 2014 by midora Quote Link to comment Share on other sites More sharing options...
midora Posted September 11, 2014 Author Share Posted September 11, 2014 Added rendering the background of the checkmark.in checked state by calling the base method without the checkmark image. Quote Link to comment Share on other sites More sharing options...
null54 Posted September 11, 2014 Share Posted September 11, 2014 Unfortunately this fix will only work if the menu does not contain enough items to require vertical scrolling. When implementing High DPI support for the example application in my 8bf host library I learned that the MenuStrip overflow scroll buttons are an internal class (ToolStripScrollButton) with static 16x16 images, so while the submenu arrows scale the overflow arrows do not. Quote Plugin Pack | PSFilterPdn | Content Aware Fill | G'MIC | Paint Shop Pro Filetype | RAW Filetype | WebP Filetype The small increase in performance you get coding in C++ over C# is hardly enough to offset the headache of coding in the C++ language. ~BoltBait Link to comment Share on other sites More sharing options...
midora Posted September 11, 2014 Author Share Posted September 11, 2014 Are you talking about the up down buttons in ToolStripDropDownMenu items? You are right they are extremly small on my screen (less than a millimeter) and not usable. Thanks for the "StickyLabel" hint. I solved the issue by adding an Opening handler to these DropDown menus. void DropDown_Opening(object sender, CancelEventArgs e) { ToolStripDropDownMenu tsddm = (ToolStripDropDownMenu)sender; foreach (Control control in tsddm.Controls) { // If control is of type StickyLabel (which is hosted by ToolStripScrollButton) if (control.GetType().Name != "StickyLabel") continue; Label label = control as Label; if (label == null) continue; // Scale the label image if this is not done already if ((label.Image != null) && (label.Tag != label.Image)) { label.Image = Ui.ScaleImage(label.Image); label.Tag = label.Image; } } } item.DropDown.Opening += new CancelEventHandler(DropDown_Opening); Quote Link to comment Share on other sites More sharing options...
