Pingonaut Posted September 10, 2014 Posted September 10, 2014 (edited) I've used this program for years, and I've grown accustomed to the controls. Today I opened up the program and I've had a problem. What I'm used to: - Hold SHIFT and scroll to scroll left/right - Hold CTRL and scroll to zoom in/out - Scroll to scroll up/down What's happening (and this isn't even consistent): - Push SHIFT to set it to this - Push CTRL to set it to this - Push the last set button to scroll up/down For some reason, it has changed from holding down these buttons. The problem is that I forget which I have it set to, and I have to guess, or it completely doesn't work at all. It isn't consistent. Is there any way I can fix this? It's very frustrating and makes using the program very difficult for me. Edited September 10, 2014 by Pingonaut Quote
midora Posted September 10, 2014 Posted September 10, 2014 I would check the keyboard settings in 'Control Panel' 'Ease of Access'. (maybe 'Sticky Keys' setting). Quote
Pingonaut Posted September 10, 2014 Author Posted September 10, 2014 (edited) I would check the keyboard settings in 'Control Panel' 'Ease of Access'. (maybe 'Sticky Keys' setting). I just realized this and came here to tell the thread that I found a solution. Sticky keys has recently been coming up on my computer when I had it turned off. This is definitely the problem, not Paint.net. Thanks for the response. Edited September 10, 2014 by Pingonaut Quote
