CodeLab in Russian (v 6.12)
ReMake
For those who still uses Paint.NET 3.5.11 CodeLab v1.8f now in Russian.
Thanks BoltBait for its kind permission and the consent which it gave for the publication of this product.
Для тех, кто все еще использует Paint.NET 3.5.11 CodeLab v1.8f (финальная) теперь и на русском языке.
Спасибо BoltBait за его любезное разрешение и согласие, которые он дал на публикацию этого продукта.
CodeLab18f_ru.zip    :arrow-left:
For users of Paint.NET v5.0.11+  CodeLab v6.12 is now available in the Russian.
Для пользователей Paint.NET v5.0.11+  CodeLab v6.12 теперь доступен и на русском.
CodeLab612_ru       :arrow-left:    (Альтернативная ссылка    CodeLab612_ru)
Your suggestions, comments, as well as about all the inaccuracies of translation write on this thread.
Ваши предложения, замечания, а также обо всех неточностях перевода пишите в этот поток.
CodeLab Help is available in Russian.
Доступен Справочник CodeLab на русском языке.
Edited by ReMake
Updated
Thanks for Your explanation. I think CodeLab v.2.0 translation and its adaptation under PDN 3.5.11 (without 3D Roll, of course) will be last.
Further I will be translate the last versions of CodeLab for PDN 4.XX.
Edited by ReMake
Can I suggest you rename the DLL to differentiate it from the original?  CodeLab_RU.dll would do.
Yes, of course. Updated.
Thanks for Your help.
I don't speak or read Russian, so I can't use your work. I do appreciate the effort you have put in to this.
Thank you.
Thank you.
I think users who speak Russian will not install both CodeLab, they need one.
I don't recommend installing both at the same time. There could be problems... :/
The problem is that when you call one of the two CodeLab, will always run the one that is first detected at startup Paint.NET.
Thanks to all who responded.
  • 1 year later...
Additional language support is added by way of *.dlc files. One is required for each new language. I'm sure there is a mini-tutorial here somewhere, but I can't find it right now.
Some clues here
2 hours ago, MadJik said:
How to(is it possible to) "codelab" a plugin for multi-language (English/french/russian)?
CodeLab in Russian is the recompiled translation of the original (English) CodeLab version. I think multi-language may be achieved using .xml, or .ini files, but there can be problems with the size of dialog boxes for different lengths of words in different languages. Interesting idea though.
You would have to do that using Visual Studio, as CodeLab just hard-codes the strings for UI Controls in your plugin.
That's if you're using midora's OptionBasedEffects; not IndirectUI.
  • Upvote 2
My Gallery  |  My Plugin Pack
Layman's Guide to CodeLab
  • ReMake changed the title to CodeLab in Russian (v 4.0)
  • ReMake changed the title to CodeLab in Russian (v 6.3)
  • Ego Eram Reputo pinned, unpinned, pinned and unpinned this topic
On 9/29/2021 at 3:32 AM, ReMake said:
CodeLab v6.3 is available in the Russian.
I can not download CodeLab63_ru, the link does not work.
  • ReMake changed the title to CodeLab in Russian (v 6.4)
  • ReMake changed the title to CodeLab in Russian (v 6.5)
  • ReMake changed the title to CodeLab in Russian (v 6.6)
  • ReMake changed the title to CodeLab in Russian (v 6.8)
  • ReMake changed the title to CodeLab in Russian (v 6.9)
Зачем такие трудности со скачиванием плагина? Регистрация в DropBox, запрос доступа - зачем всё это? Это сверхсекретный файл?
Размер zip-файла 4.57 Мб, у меня нет столько пространства на getpaint.net. Могу залить на MediaFire или Яндекс.Диск. Откуда вам удобнее скачивать?
