How to make images auto-click together?
Tuckertcs
I want to have puzzle piece shaped images and want to make it so when I drag two close together they auto click to fit together instead of zooming in and aligning them up just right.  Is it possible?
Not posible exactly the way you describe but it may be worth trying Madjik's 'Gravity' plugin.
Here:http://forums.getpaint.net/index.php?showtopic=7968
It can move opaque pixels across to fill in the space where transparent pixels are. It won't work if your puzzle pieces have an 'undercut' though.
Hello. :)
You might get some puzzle ideas from this tutorial : http://forums.getpaint.net/index.php?/topic/25201-its-puzzle-time-image-heavy/
Note, the tutorial uses some plugins, the plugins used can be found here : Alpha Mask and AA's Assistant.
You may also like these puzzle brushes : http://www.brusheezy.com/brushes/24418-50-puzzle-pieces-brushes. Which you could use with the Alpha Mask plugin or in another creative way.
If the brushes are ABR format either get Paint.NET's abr file type plugn, or try using ABRMate to convert the brushes to PNG.
Edited by Cc4FuzzyHuggles
