Cherrybooboo Posted August 3, 2014 Share Posted August 3, 2014 Hello I decided to sign up to the forums today as i have used Paint.net for many years, however, i am now having a problem with the recently updated version. I create a lot of walls for The Sims 2 and I attach 3 images of a wall template i use. Image 1 - This is a blank canvas before i use any colour to colour it in. Image 2 - First time using this template after the update and the thin black lines which i coloured white are now THICK ????? Image 3 - After being coloured in using whatever colour i choose, this is the end result of what it should look like, not as image 2. Can someone advise how i can get this changed as its frustrating. Thank you. Quote Link to comment Share on other sites More sharing options...
Cherrybooboo Posted August 3, 2014 Author Share Posted August 3, 2014 How do i stop the colours bleeding into other sections? Quote Link to comment Share on other sites More sharing options...
midora Posted August 3, 2014 Share Posted August 3, 2014 Hi Cherybooboo, you should decribe in more detail how you are coloring the templates (which tools in which order). Maybe you just have to disable anti-aliasing in one of the steps. Quote Link to comment Share on other sites More sharing options...
Cherrybooboo Posted August 10, 2014 Author Share Posted August 10, 2014 Hi Midora Sorry for the delay in responding. I do the following steps:- Choose my colour Choose Paint Bucket Make sure the fill option is on Flood mode Click on the wall to colour it in full Right click on the black lines to turn them white and thats when it blends in to look thicker How do you disable the anti-aliasing you mentioned. I apologise now asking silly questions. Thanks Quote Link to comment Share on other sites More sharing options...
Cherrybooboo Posted August 10, 2014 Author Share Posted August 10, 2014 Going to take me a while to get use to the settings and where everything is now however, after going through the above, i messed about abit and doing the following has sorted me out:- Rasterization = Antiliasing Disabled Bleeding Mode = Normal (it was on Glow) !!! Antaliased Selection Quality highlighted My items look like they did before Yay. Thanks for your help. Quote Link to comment Share on other sites More sharing options...
