zipmmcs 0 Posted July 13, 2014 Share Posted July 13, 2014 Hello, I faced wiht a symptom with the Paint.NET 4 on Windows 7 x86/x64 Home Premium and Enterprise. The VGA card (if matters) is an ATi 7770, but tested on i3's internal GPU and on HD 6750 as well. All the application fonts (including menus and title bar) shows the fonts blurry - please see attached picture. I tried different ClearType settings including turning it off completely without any progress. With the previous version (3.5.10/11) I did not observe this issue. If there is a workaround or solution already, please share with me. Thanks & Regards, zipmmcs Link to post Share on other sites
BoltBait 3,281 Posted July 13, 2014 Share Posted July 13, 2014 I don't see an attached picture. Please host it at photobucket (or some other hosting site) and post the link here. Click to play: Download: BoltBait's Plugin Pack | CodeLab | and how about a Computer Dominos Game Link to post Share on other sites
zipmmcs 0 Posted July 13, 2014 Author Share Posted July 13, 2014 Dear BoltBait, it is uploaded to here: http://i1285.photobucket.com/albums/a597/zipmmcs/PNET_401_zpsca818dd9.png Thanks, zipmmcs Link to post Share on other sites
Pixey 4,941 Posted July 13, 2014 Share Posted July 13, 2014 (edited) Hi @zipmmcs - you need to have a new layer before you can see those options: With no layer: http://i.imgur.com/M7b6lVU.png With a layer: http://i.imgur.com/0YEHa2M.png Edited July 13, 2014 by Pixey How I made Jennifer & Halle in Paint.net My Gallery | My Deviant Art "Rescuing one animal may not change the world, but for that animal their world is changed forever!" anon. Link to post Share on other sites
zipmmcs 0 Posted July 13, 2014 Author Share Posted July 13, 2014 Hi Pixey, first of all thank you for answering my issue. But you misunderstand the situation. This is and interface issue. OK. I reuploaded the picture with some markings - I was hoping that the screenshot itself will be talkative enough. Link: http://i1285.photobucket.com/albums/a597/zipmmcs/PNET_401_zpsedcc678a.png - Adjustments menu: the letter "n" is barely visible. - Effects menu: the subpixel rendering kills the clear visibility. - Layers menu\Import From File...: also issue of subpixel rendering - the "I" is not black, but somewhat brown. - Layers menu\Flip Horizontal: letter "n" is also badly visible. With the same setup the Paint.NET 3.5.11 was just perfect. I cannot recall if different font was used for the interface of the software. For me it is obvoius that the interface font has issues and cannot be rendered perfectly - or an extra clear type rendering applied to the interface of the software. The situation is even worse when a poor DPI monitor is used like a 5:4 aspect ratop 19"@1280x1024 or a 16:9 24"@1920x1080, it is just bad. I'm sure that this is not a uniqe or user dependent issue since on different setups under different user accounts I can see the problem. Is it possible to change the interface font somehow, like from command parameters? Thanks and Regards, zipmmcs Link to post Share on other sites
Pixey 4,941 Posted July 13, 2014 Share Posted July 13, 2014 Ahhhh - yes I thought you meant the 'functions' were not highlited. So, it could be an artifacts problem .... see here perhaps this will help. Hope so anyway How I made Jennifer & Halle in Paint.net My Gallery | My Deviant Art "Rescuing one animal may not change the world, but for that animal their world is changed forever!" anon. Link to post Share on other sites
zipmmcs 0 Posted July 13, 2014 Author Share Posted July 13, 2014 Unfortunately disabling the HW acceleration and running the pdnrepair.exe does not help... But thanks for the tip. Regards, zipmmcs Link to post Share on other sites
Guest Posted July 13, 2014 Share Posted July 13, 2014 I have the same problem. -win7 x64 -AMD Radeon 14.6 drivers -hardware acc on/off -no problems with 3.5 -default system font changed from Segoe to Arial Link to post Share on other sites
BoltBait 3,281 Posted July 13, 2014 Share Posted July 13, 2014 Or, if you want to keep ClearType, have you "tuned" it? 1 Click to play: Download: BoltBait's Plugin Pack | CodeLab | and how about a Computer Dominos Game Link to post Share on other sites
Rick Brewster 1,767 Posted July 13, 2014 Share Posted July 13, 2014 Also, if you change the settings for font smoothing, antialiasing, or the ClearType settings, you'll need to restart paint.net. For performance reasons it only gets that info at startup. The Paint.NET Blog: https://blog.getpaint.net/ Donations are always appreciated! https://www.getpaint.net/donate.html Link to post Share on other sites
zipmmcs 0 Posted July 13, 2014 Author Share Posted July 13, 2014 (edited) The cleartype tuned for darker - every applications provides better readability. Just reinstalled 3.5.11 to _exactly_ the same setup - including cleartype tuning: http://i1285.photobucket.com/albums/a597/zipmmcs/PNET_3511_zps4fae7d8a.png No blurry font issue. So there is a difference between the two releases from interface point of view which gone bad. Regards, zipmmcs Edited July 13, 2014 by zipmmcs Link to post Share on other sites
Rick Brewster 1,767 Posted July 13, 2014 Share Posted July 13, 2014 quickpost, The font rendering looks really broken, color-wise, in that screen shot ... O_o Paint.NET is using a high-quality DirectWrite rendering mode called "natural symmetric." Old versions used good ol' GDI for rendering. Some people just don't like the way DirectWrite does it. *shrug* Edit: it also looks like it is buggy on some systems, giving text a weird "rainbow" appearance I have something y'all can try if you really don't like the way the fonts look. You can download the ZIP attached to this post, and then double-click the .REG file inside of it. It will force Paint.NET to use another DirectWrite rendering mode that should look the same as "good ol' GDI". Or you can make the modification yourself by opening up Registry Editor and going to HKEY_CURRENT_USER \ SOFTWARE \ paint.net, then add a String key called "UI/DefaultTextRenderingMode" (without quotes) and set its value to "ClearTypeGdiClassic" (without quotes). Here's the contents of the .REG file which is inside the .ZIP: Windows Registry Editor Version 5.00 [HKEY_CURRENT_USER\Software\Paint.NET] "UI/DefaultTextRenderingMode"="ClearTypeGdiClassic" PDN4_GDIClassicText.zip The Paint.NET Blog: https://blog.getpaint.net/ Donations are always appreciated! https://www.getpaint.net/donate.html Link to post Share on other sites
Guest Posted July 13, 2014 Share Posted July 13, 2014 thank you that really helped, everything fine now Link to post Share on other sites
Ego Eram Reputo 2,800 Posted July 13, 2014 Share Posted July 13, 2014 @Rick: Is this going to become an option for users, or should we bookmark and recommend your post above? ebook: Mastering Paint.NET | resources: Plugin Index | Stereogram Tut | proud supporter of Codelab plugins: EER's Plugin Pack | Planetoid | StickMan | WhichSymbol+ | Dr Scott's Markup Renderer | CSV Filetype | dwarf horde plugins: Plugin Browser | ShapeMaker Link to post Share on other sites
Rick Brewster 1,767 Posted July 13, 2014 Share Posted July 13, 2014 Just bookmark it for now. The Paint.NET Blog: https://blog.getpaint.net/ Donations are always appreciated! https://www.getpaint.net/donate.html Link to post Share on other sites
zeromus 3 Posted July 14, 2014 Share Posted July 14, 2014 I would like to take this opportunity to say thanks for making paint.net is one of the few new relatively new programs in the universe which doesnt forcibly enable text antialiasing.... anywhere. I don't know whether this was on purpose or not, but I imagine the existence of this registry hack is a sign of taking it seriously. Link to post Share on other sites
zipmmcs 0 Posted July 14, 2014 Author Share Posted July 14, 2014 ... Dear Rick, thank you very much for the quick and comprehensive answer on the topic. It behaves as expected on all PCs now. My problem is solved now. Thank you and best regards, zipmmcs Link to post Share on other sites
Rick Brewster 1,767 Posted July 14, 2014 Share Posted July 14, 2014 I would like to take this opportunity to say thanks for making paint.net is one of the few new relatively new programs in the universe which doesnt forcibly enable text antialiasing.... anywhere. I don't know whether this was on purpose or not, but I imagine the existence of this registry hack is a sign of taking it seriously. It seems that most people don't notice / don't care. But for those who do notice/care, it's either something they're super passionate about ("I hate this!") or it just doesn't work for their eyes. So it's good to have an "escape hatch." I don't know if you used some older WPF applications but they had this nasty problem whereby if text was moving (e.g., a scrollable area of text, or any type of animation thingy), the text would be super blurry for a moment once it "settled." That really messed with my eyes trying to focus, and there were some cases where I just couldn't use a certain piece of software because of it. Or I had to train myself to look away and then look back. It was a very unpleasant feeling. The Paint.NET Blog: https://blog.getpaint.net/ Donations are always appreciated! https://www.getpaint.net/donate.html Link to post Share on other sites
pgaske 0 Posted July 15, 2014 Share Posted July 15, 2014 I'd just like to post that I had the same issue on my laptop; Windows 8.1. The .reg file in this thread fixed my issue. I'm using two external monitors via display port, Paint.NET on primary monitor. Native screen resolution is 2560 x 1440. All other applications render fonts correctly, but Paint.NET was really messed up. It's almost like it was subpixel rendering the fonts with incorrect knowledge of the pixel colour components (ie: RGB vs BGR). Here's a copy of my Diagnostics information: Application paint.net 4.0.1 (Final 4.1.5306.43142) Build Date Saturday, 12 July 2014 Hardware accelerated rendering (GPU) True Animations True DPI 96.00 (1.00x scale) Language en-US OS Windows 8.1 (6.3.9600.0) .NET Runtime 4.0.30319.34014 Physical Memory 16,323 MB CPU Intel® Core i7-4900MQ CPU @ 2.80GHz Architecture x64 (64-bit) Process Mode 64-bit Speed ~2794 MHz Cores / Threads 8 Features DEP, SSE, SSE2, SSE3, SSSE3, SSE4_1, SSE4_2, XSAVE Video Card NVIDIA Quadro K2100M Dedicated Video RAM 1,958 MB Dedicated System RAM 0 MB Shared System RAM 8,161 MB Vendor ID 0x10DE Device ID 0x11FC Subsystem ID 0x05CC1028 Revision 161 LUID 0x00008839 Flags None Outputs 2 Video Card Microsoft Basic Render Driver Dedicated Video RAM 0 MB Dedicated System RAM 0 MB Shared System RAM 256 MB Vendor ID 0x1414 Device ID 0x008C Subsystem ID 0x00000000 Revision 0 LUID 0x00009309 Flags Software Outputs 0 Link to post Share on other sites
Elbart 0 Posted July 15, 2014 Share Posted July 15, 2014 (edited) Have there been changes in 4.0.1 compared to 4.0 regarding the rendering of fonts? Left 4.0, right 4.0.1 Disabling hardware-acceleration doesn't help. Win7 SP1, .NET Runtime 4.0.30319.18444, nVidia GT 640, 337.88 Edited July 15, 2014 by Elbart Link to post Share on other sites
Rick Brewster 1,767 Posted July 15, 2014 Share Posted July 15, 2014 There wasn't supposed to be but I'm seeing several people reporting this. I'm trying to figure out what change could've possibly caused this. Are you using a rotated monitor by any chance? The Paint.NET Blog: https://blog.getpaint.net/ Donations are always appreciated! https://www.getpaint.net/donate.html Link to post Share on other sites
Rick Brewster 1,767 Posted July 15, 2014 Share Posted July 15, 2014 Okay I think I figured this out. I accidentally swapped the ClearTypeLevel and EnhancedContrast values in 1 location, due to inconsistent ordering between 2 different representations of the text rendering parameters. I'm planning a 4.0.2 update for today or tomorrow, so please just bear with the font rendering for a little while longer. The Paint.NET Blog: https://blog.getpaint.net/ Donations are always appreciated! https://www.getpaint.net/donate.html Link to post Share on other sites
BoltBait 3,281 Posted July 15, 2014 Share Posted July 15, 2014 Have there been changes in 4.0.1 compared to 4.0 regarding the rendering of fonts? Left 4.0, right 4.0.1 Disabling hardware-acceleration doesn't help. Win7 SP1, .NET Runtime 4.0.30319.18444, nVidia GT 640, 337.88 I've been running 4.0 for plugin development and hadn't updated to 4.0.1. So, I didn't see the same issue that you all have seen in this thread. Had I upgraded, I would have been "up in arms" as well. I just upgraded and must say that Version 4.0.1 hurts my eyes. Click to play: Download: BoltBait's Plugin Pack | CodeLab | and how about a Computer Dominos Game Link to post Share on other sites
Rick Brewster 1,767 Posted July 15, 2014 Share Posted July 15, 2014 Install 4.0.2 and it'll fix this. The Paint.NET Blog: https://blog.getpaint.net/ Donations are always appreciated! https://www.getpaint.net/donate.html Link to post Share on other sites
Elbart 0 Posted July 16, 2014 Share Posted July 16, 2014 Fixed, thank you. Link to post Share on other sites
