The ultimate Power Point Stick Show!
aatwo
Cleaning out 200 Gigabytes of data from your hard drive can lead you to some amazing forgotten treasures. I made this power point animation after I discovered the wonders of Microsoft Power point when I was roughly twelve.
Well I used cam studio to record my screen whilst I played the slides (all 1023 of them) in power point and here it is.
Enjoy :D
The Ultimate Power Point Stick Fight
  • 3 weeks later...
Clever. I actually like that one better, UsedHonda. Less violence and more action expression (e.g. line dashes for fast movement.)
v An excellent open–source strategy game—highly recommended.
"I wish I had never been born," she said. "What are we born for?"
"For infinite happiness," said the Spirit. "You can step out into it at any moment..."
Mmm... I don't know. It looks almost drawn, but that would take a long time.
PIVOT 3 BETA: http://rapidshare.com/files/18320848/pivot.exe.html
^this is the stick figure one... similar to what I made...
EASY TOON TRANSLATED: http://rapidshare.com/files/18320908/EasyToon_1.9.5_EN.exe.html
this is what program was used to draw that "bashing the wall" animation, yes, that animation was drawn 1 frame at a time.
here is another example of EZtoon (its very difficult to use :( )
Site: RIP =(
  • 5 months later...
Did you know that Pivot 3.1 beta is full of bugs? It can ruin your animations and your STK files - and the only bigger changes from version 2.2.5 is the possibility of importing sprites (small pictures) into the animation and the possibility of having multible backgrounds.
In the Pivot animating forums (like PA, DarkDemon and Droidz) most animators uses Pivot 2.2.5 - but many of the noobs use Pivot 3.1 beta.
Here is an animation i am working on, what do you think about it?:
Read the rules, mainly this one:
9) Don't respond to very old threads. Also known as "reviving" or "resusitating" old/dead threads. Also called "necroposting" (eww). If there has been no discussion in a thread for, say, 3 months ... then it is dead. Do not reply to it -- pretend like it is locked. If you reply to it, then the thread will be immediately locked and your post may be deleted.
