TheDapperThylacine Posted June 25, 2014 Share Posted June 25, 2014 (edited) I want to remove everything but the card. I tried using the magic wand but it keeps selecting parts of the card. I am very new to Paint.NET Edited June 25, 2014 by TheDapperThylacine Quote Link to comment Share on other sites More sharing options...
skullbonz Posted June 25, 2014 Share Posted June 25, 2014 You could use this; http://forums.getpaint.net/index.php?/topic/26966-trs-alpha-cutter-v304-april-7th-2014/ Quote http://forums.getpaint.net/index.php?/topic/21233-skullbonz-art-gallery Link to comment Share on other sites More sharing options...
TheDapperThylacine Posted June 25, 2014 Author Share Posted June 25, 2014 You could use this; http://forums.getpaint.net/index.php?/topic/26966-trs-alpha-cutter-v304-april-7th-2014/ Looks good, but I'm not sure how to install it. Also, do you know if it works with version 4 of Paint.NET? Quote Link to comment Share on other sites More sharing options...
BoltBait Posted June 26, 2014 Share Posted June 26, 2014 Easier... Use square select to select from the top left corner to the right edge low enough to just touch the top of the card. Press DEL. Repeat for other 3 sides. Use eraser set to size 9 to clean up the 4 corners. Quote Click to play: Download: BoltBait's Plugin Pack | CodeLab | and how about a Computer Dominos Game Link to comment Share on other sites More sharing options...
johnnysdream Posted June 26, 2014 Share Posted June 26, 2014 (edited) Easier... Use square select to select from the top left corner to the right edge low enough to just touch the top of the card. Press DEL. Repeat for other 3 sides. Use eraser set to size 9 to clean up the 4 corners Wont they have to hit control+I to invert the selection before they delete? Edited June 26, 2014 by johnnysdream Quote Link to comment Share on other sites More sharing options...
Pixey Posted June 26, 2014 Share Posted June 26, 2014 Looks good, but I'm not sure how to install it. Also, do you know if it works with version 4 of Paint.NET? Yes, it works with v4. Here is a link to help you with installing plugins. Wont they have to hit control+I to invert the selection before they delete? No they wouldn't in this instance. Just select with the rectangle select, delete. Then a little erasing at the edges and AA's Assistant and Voila: Quote How I made Jennifer & Halle in Paint.net My Gallery | My Deviant Art "Rescuing one animal may not change the world, but for that animal their world is changed forever!" anon. Link to comment Share on other sites More sharing options...
