nery89 0 Posted June 9, 2014 Report Share Posted June 9, 2014 (edited) Strange "flickering images" appear around the reference points of the selection. see attached capture using: windows 7 build: 4.0 beta Edited June 9, 2014 by nery89 Quote Link to post Share on other sites
Rick Brewster 1,751 Posted June 9, 2014 Report Share Posted June 9, 2014 Install the 5268 build. If it still happens, please tell us what graphics card you have. Or you can go to Settings -> Diagnostics and click Copy to Clipboard and paste that here. My non-psychic guess is that you have an Intel GPU. Quote The Paint.NET Blog: https://blog.getpaint.net/ Donations are always appreciated! https://www.getpaint.net/donate.html Link to post Share on other sites
nery89 0 Posted June 10, 2014 Author Report Share Posted June 10, 2014 (edited) with the 5268 build all work perfectly! thanks a lot boss! anyway, here my log (mercoledì == wednesday) Application paint.net 4.0 (β 4.0.5268.42065) Build Date mercoledì 4 giugno 2014 Expiration Date mercoledì 27 agosto 2014 Accelerazione hardware di rendering (GPU) False Animazioni False Lingua it OS Windows 7 Service Pack 1 (6.1.7601.65536) .NET Runtime 4.0.30319.18444 Physical Memory 3,947 MB CPU Intel® Core i5-2410M CPU @ 2.30GHz Architecture x64 (64-bit) Process Mode 64-bit Speed ~2294 MHz Cores / Threads 4 Features DEP, SSE, SSE2, SSE3, SSSE3, SSE4_1, SSE4_2, XSAVE Video Card Intel® HD Graphics Family Dedicated Video RAM 128 MB Dedicated System RAM 0 MB Shared System RAM 1,632 MB Vendor ID 0x8086 Device ID 0x0116 Subsystem ID 0x05041025 Revision 9 LUID 0x00008AE7 Flags None Video Card NVIDIA GeForce GT 540M Dedicated Video RAM 977 MB Dedicated System RAM 0 MB Shared System RAM 1,717 MB Vendor ID 0x10DE Device ID 0x0DF4 Subsystem ID 0x05051025 Revision 161 LUID 0x000093DE Flags None Edited June 10, 2014 by nery89 Quote Link to post Share on other sites
Rick Brewster 1,751 Posted June 10, 2014 Report Share Posted June 10, 2014 As I suspected ... you have an Intel graphics chip. In 5268 I set it so that Intel chips have hardware acceleration disabled by default. I was getting a lot of reports like the one you gave here. Performance might be lower but .. it'll work! Quote The Paint.NET Blog: https://blog.getpaint.net/ Donations are always appreciated! https://www.getpaint.net/donate.html Link to post Share on other sites
