Trax rInfo Posted June 2, 2014 Share Posted June 2, 2014 HELLO i'm here to ask a question, idk if it's possible but, how can you keep semi-transparent parts in .png files :0 for example the Drop shadow plugin looks cool. but it doesn't work effectively if the background is completely transparent i saved it as a .png file then bam the shadow is gone (except for the non-transparent parts of the shadow) Quote Link to comment Share on other sites More sharing options...
pdnnoob Posted June 2, 2014 Share Posted June 2, 2014 Would you mind posting an example image of what's happening? As far as I know, .png images support a full range of transparency. Make sure, when you're saving, you have bit-depth set to "Auto-detect" 1 Quote No, Paint.NET is not spyware...but, installing it is an IQ test. ~BoltBait Blend modes are like the filling in your sandwich. It's the filling that can change your experience of the sandwich. ~Ego Eram Reputo Link to comment Share on other sites More sharing options...
Trax rInfo Posted June 5, 2014 Author Share Posted June 5, 2014 Would you mind posting an example image of what's happening? As far as I know, .png images support a full range of transparency. Make sure, when you're saving, you have bit-depth set to "Auto-detect" Ah, the bit depth was the problem thanks. Quote Link to comment Share on other sites More sharing options...
