Alex95 0 Report post Posted May 22, 2014 Hi, Tool Linear Gradient: no repeat, color mode, antialiasing enabled, normal blending. primary color - white - alpha is zero secondary - white alpha - 100% Original image: Gradient from left to white. In the middle of image. ( I used Ctrl key in order to create horizontal gradient). Looks fine, however, right part is not solid white.There are a lot of non white dots, especially in the right bottom. Pixels can be RGB(255,255,254) or even RGB(252,252,253). I can imagine that 254 may be caused by rounding errors, but 252 is very strange. Not sure how this tool works in 3.5, but I think it was fine. I quite often use Magic Wand with zero tolerance in order to select white areas and never had problems. Now this tool does not work after gradient in my case. In gimp this tool works as expected. Thanks, Alex Share this post Link to post Share on other sites
BoltBait 2,170 Report post Posted May 22, 2014 This may be a case where the R,G,and B values of a pixel are "undefined" when alpha is 0. Share this post Link to post Share on other sites
Alex95 0 Report post Posted May 22, 2014 primary color - RGBA(255,255,255,0) secondary color - RGBA(255,255,255,255) no layers in image, just background. Share this post Link to post Share on other sites
vvye 0 Report post Posted May 22, 2014 If that's what I think it is, then it's actually a feature, not a bug. Disabling anti-aliasing should get rid of the noise. Share this post Link to post Share on other sites
Rick Brewster 1,159 Report post Posted May 22, 2014 What vvye said. Share this post Link to post Share on other sites
Alex95 0 Report post Posted May 22, 2014 OK, but this is really unexpected. Share this post Link to post Share on other sites
Rick Brewster 1,159 Report post Posted May 22, 2014 It's unexpected for it to default to the higher quality option? Share this post Link to post Share on other sites
Alex95 0 Report post Posted May 22, 2014 No, I still think gradient does not work properly. But suggestion may help to do what I need. See another image. This was screenshot of Paint.Net itself. I've tried horizontal linear gradient. From RGBA(255,255,255,0) to RGBA(255,255,255,255). Start , End are shown on screenshot. 1. Left part is not affected by gradient - this is fine, alpha is zero. 2. Middle part - I see some noise on screenshot, not sure is this right or not - probably you are trying to achieve better quality and avoid vertical lines. If yes, I'm fine with that. Looks good. 3. Right part - should be fully white, without noise. This is what I expect. Open this image in Paint.Net, zoom and check area where the status bar was. Colors there are in range from 253 to 255. In rest parts colors jumping from 254 to 255. Share this post Link to post Share on other sites
