iDrBlue Posted April 17, 2014 Posted April 17, 2014 When I downloaded the ZIP file, I accidentally said to open it with Adobe PDF (ADOBE ACROBAT) and now I cannot undo this. So whenever I open a plugin ZIP file, all the plugins are PDF files. How do I undo this!? here is a screenshot: Quote
xod Posted April 17, 2014 Posted April 17, 2014 Not a good idea to affect the registry but look at this video: Quote
Sozo Posted April 17, 2014 Posted April 17, 2014 They aren't pdf files, in fact those plugins will work as-is if you put them in the right folder. To change the default program back, right click on any .zip file, go to 'open with' and click on windows explorer. 2 Quote
