toureasy Posted January 30, 2007 Share Posted January 30, 2007 WARNING: Long post, contains text of a BuildLog.htm When I compile Paint.NET on my PC, I get the following error: error PRJ0019: A tool returned an error code from "Making setup packages ..." in Setup Config. However, the build got far enough to create the following 4 files in src\\Setup\\Release: PaintDotNet.msi PaintDotNet_3_0.exe PaintDotNetSetup.exe PaintDotNet_3_0.zip ( contains PaintDotNet_3_0.exe) I don't know if these are the only files that go into the Setup\\Release directory, because it seems to die while trying to add PaintDotNet_3_0_WithDotNet.exe to the ZIP file, which it says doesn't exist. Below is the contents of the src\\Setup-Config\\Release\\BuildLog.htm log, which seems to contain the text of the error. Thanks in advance for your help. - Brad src\\Setup-Config\\Release\\BuildLog.htm: *********************************** Build Log Build started: Project: Setup Config, Configuration: Release|Win32 Command Lines Creating temporary file "h:\Paint.net\src\Setup-Config\Release\BAT00001036403756.bat" with contents [ @echo off if "%SIGNPDN%" == "1" set COMPRESS=/DCompress echo Settings some last minute MSI properties... call "h:\Paint.net\src\Setup-Config\\SetMsiProperties.bat" "H:\Paint.net\src\\Setup\Release\PaintDotNet.msi" if "%SIGNPDN%" == "1" echo Signing MSI ... call "H:\Paint.net\src\signfile.bat" "H:\Paint.net\src\\Setup\Release\PaintDotNet.msi" rem Ensure that the NSIS stubs have a UAC requireAdministrator manifest md ..\BuildTools\Stubs copy ..\BuildTools\Stubs_needManifest\* ..\BuildTools\Stubs\ call ..\Manifests\embedManifest.bat ..\BuildTools\Stubs\bzip2 ..\Manifests\requireAdministrator.xml call ..\Manifests\embedManifest.bat ..\BuildTools\Stubs\bzip2_solid ..\Manifests\requireAdministrator.xml call ..\Manifests\embedManifest.bat ..\BuildTools\Stubs\lzma ..\Manifests\requireAdministrator.xml call ..\Manifests\embedManifest.bat ..\BuildTools\Stubs\lzma_solid ..\Manifests\requireAdministrator.xml call ..\Manifests\embedManifest.bat ..\BuildTools\Stubs\zlib ..\Manifests\requireAdministrator.xml call ..\Manifests\embedManifest.bat ..\BuildTools\Stubs\zlib_solid ..\Manifests\requireAdministrator.xml echo Making installer ... ..\BuildTools\makensis /DRelease %COMPRESS% MakeSetup.nsi if "%SIGNPDN%" == "1" echo Signing installer ... call "H:\Paint.net\src\signfile.bat" "H:\Paint.net\src\\Setup\Release\PaintDotNetSetup.exe" echo Making full installer ... ..\BuildTools\makensis /DFullInstaller %COMPRESS% /DRelease MakeSetup.nsi if "%SIGNPDN%" == "1" echo Signing full installer ... call "H:\Paint.net\src\signfile.bat" "H:\Paint.net\src\\Setup\Release\PaintDotNetWithDotNetSetup.exe" echo Packaging things up... set PDNAME=3_0 pushd "H:\Paint.net\src\\Setup\Release\" copy PaintDotNetSetup.exe PaintDotNet_%PDNAME%.exe "H:\Paint.net\src\\BuildTools\zip" -9 PaintDotNet_%PDNAME%.zip PaintDotNet_%PDNAME%.exe copy PaintDotNetWithDotNetSetup.exe PaintDotNet_%PDNAME%_WithDotNet.exe "H:\Paint.net\src\\BuildTools\zip" -9 PaintDotNet_%PDNAME%_WithDotNet.zip PaintDotNet_%PDNAME%_WithDotNet.exe rem "H:\Paint.net\src\\BuildTools\zip" -0 PaintDotNet_%PDNAME%_All.zip PaintDotNet_%PDNAME%_WithDotNet.zip PaintDotNet_%PDNAME%.zip popd if errorlevel 1 goto VCReportError goto VCEnd :VCReportError echo Project : error PRJ0019: A tool returned an error code from "Making setup packages ..." exit 1 :VCEnd ] Creating command line """h:\Paint.net\src\Setup-Config\Release\BAT00001036403756.bat""" Output Window Making setup packages ... Settings some last minute MSI properties... Executing SQL command on PaintDotNet.msi: UPDATE Property SET Property.Value = 'ALL' WHERE Property.Property = 'FolderForm_AllUsers' A subdirectory or file ..\BuildTools\Stubs already exists. ..\BuildTools\Stubs_needManifest\bzip2 ..\BuildTools\Stubs_needManifest\bzip2_solid ..\BuildTools\Stubs_needManifest\lzma ..\BuildTools\Stubs_needManifest\lzma_solid ..\BuildTools\Stubs_needManifest\zlib ..\BuildTools\Stubs_needManifest\zlib_solid 6 file(s) copied. Making installer ... MakeNSIS v2.11 - Copyright 1999-2005 Nullsoft, Inc. Portions Copyright © 1995-1998 Jean-loup Gailly and Mark Adler (zlib). Portions Copyright © 1996-2002 Julian R Seward (bzip2). Portions Copyright © 1999-2003 Igor Pavlov (lzma). Contributors: nnop@newmail.ru, Ryan Geiss, Andras Varga, Drew Davidson, Peter Windridge, Dave Laundon, Robert Rainwater, Yaroslav Faybishenko, Jeff Doozan, Amir Szekely, Ximon Eighteen, et al. Command line defined: "Release" Changing directory to: "h:\Paint.net\src\Setup-Config" Processing script file: "MakeSetup.nsi" Processing plugin dlls: "h:\Paint.net\src\BuildTools\Plugins\*.dll" SetCompress: off Name: "Paint.NET SFX" InstallDir: "$TEMP\PdnSetup" SilentInstall: silent Icon: "..\Resources\Icons\PaintDotNet.ico" VIAddVersionKey: "ProductName" "Paint.NET Setup" VIAddVersionKey: "ProductVersion" "3.0.0.0" VIAddVersionKey: "FileVersion" "3.0.0.0" VIAddVersionKey: "LegalCopyright" "Copyright ⌠Link to comment Share on other sites More sharing options...
Rick Brewster Posted January 31, 2007 Share Posted January 31, 2007 Did you read the readme.txt in the programs/dot_net_2_0 directory? The Paint.NET Blog: https://blog.getpaint.net/ Donations are always appreciated! https://www.getpaint.net/donate.html Link to comment Share on other sites More sharing options...
toureasy Posted January 31, 2007 Author Share Posted January 31, 2007 Thanks Rick. That did it. I downloaded the two packages, and did the following 2 commands to install them: dotnetfx.exe /T:H://Paint.net//programs//dotnet_2_0//x86 /C netfx64.exe /T:H://Paint.net//programs//dotnet_2_0//x64 /C where // is a backslash Then I rebuilt Paint.NET, and the build succeeded. Thanks. Link to comment Share on other sites More sharing options...
Matt1 Posted October 26, 2009 Share Posted October 26, 2009 Link to comment Share on other sites More sharing options...
david.atwell Posted October 26, 2009 Share Posted October 26, 2009 Holy Necrospamming, Batman! The Doctor: There was a goblin, or a trickster, or a warrior... A nameless, terrible thing, soaked in the blood of a billion galaxies. The most feared being in all the cosmos. And nothing could stop it, or hold it, or reason with it. One day it would just drop out of the sky and tear down your world.Amy: But how did it end up in there?The Doctor: You know fairy tales. A good wizard tricked it.River Song: I hate good wizards in fairy tales; they always turn out to be him. Link to comment Share on other sites More sharing options...
