How to set default color for colors
The top menu Window>Colors bring out a Colors window. It always default with black color
I want to set default to red color. Is it possible?
I usually use red color for lines/text that I want to add to the pictures.
Thanks
Edited by pman
I don't recall that the default Primary and Secondary colors can be reset.
You know you can click on the palette in the Color Window to quickly select a color?
I understand that I can click on the palette to select a color. I just thought maybe there are some ways to set some defaults, for example I am using it for text annotation so I always use red text/lines.
Could the default font size and thickness of lines be changed?
Where that I can look at defaults that could be changed?
Look to the left side of the Tool Bar, there is a drop-down list of the Tools. The top item in that list is the option the "Choose Defaults". That will open the default settings dialog.
http://www.getpaint.net/doc/latest/Toolbar.html
Thanks EER.
BTW what does "vote this post up" (little up arrow at bottom right corner of post) do?
EER gives a good explanation here.
