Eraser problems :(
The eraser acts like a paintbrush because it's literally supposed to be that way.
If you want to erase individual pixels, then use the pencil tool: set the color to transparent, and the blending mode to Overwrite.
This question comes up occasionally. Perhaps it would be useful to change the behavior of the eraser to act like an overwrite pencil when the size of the eraser is set to 1.
Or, you could have a hard/soft setting on the eraser.
Click to play:
Okay thanks! Just for future REF, I think there should be a tool to erase pixel by pixel. But how do I turn antialising off?
Edited by coolalex131
Also, Nevermind, turned Antialising off but every time I try to erase something, it erases the pixel above rather than the one I want to erase.
Do this:
Just to make absolutely certain you're doing it right... (There's always that chance. I'm not trying to insult your intelligence in any way.)
