Lann533 Posted February 12, 2014 Share Posted February 12, 2014 Hi i love paint.net and find it essential to the work i do. I only have two problems with the new version, when i am using hardware acceleration the screen flashes black and white and the mouse cursor leaves weird trails all over the screen turning off hardware acceleration fixes the problem so its not a big deal and its probably due to my laptop having two GPUs and using Nvidia optimus to switch between them. my big problem though is the eraser tool, i do a lot of pixel artwork zoomed in very close with a size 1 eraser and the centering for the tool seems to be off slightly like i will have the circle almost completely over the pixel i want to erase but the pixel above or to the right will disappear instead. Quote Link to comment Share on other sites More sharing options...
Rick Brewster Posted February 12, 2014 Share Posted February 12, 2014 For the artifacts, turn off Hardware Accelerated Rendering in the settings. For erasing individual pixels, you should use the Pencil instead. Set the color to have 0 alpha, and then use the Overwrite blending mode in the toolbar. Quote The Paint.NET Blog: https://blog.getpaint.net/ Donations are always appreciated! https://www.getpaint.net/donate.html Link to comment Share on other sites More sharing options...
Lann533 Posted February 12, 2014 Author Share Posted February 12, 2014 Thanks for the fast response that's solved it Keep up the good work Quote Link to comment Share on other sites More sharing options...
Rick Brewster Posted February 13, 2014 Share Posted February 13, 2014 I've also filed a bug for the centering. It does feel a bit too clamped in the wrong direction. Quote The Paint.NET Blog: https://blog.getpaint.net/ Donations are always appreciated! https://www.getpaint.net/donate.html Link to comment Share on other sites More sharing options...
