Cferra Posted February 7, 2014 Posted February 7, 2014 Hello. I recently updated the program and now it seems to crash whenever I use the magic wand tool. It will work for a little while and it still crashes. Not sure what's wrong. The version I am using is a 4.0.5143.33275 Please help! Thanks in advance. Quote
pyrochild Posted February 7, 2014 Posted February 7, 2014 Please post the crash log. The 4.0 alpha has known issues with the magic wand tool that I believe will be fixed in the next release, and this is probably the same issues, but it doesn't hurt to be sure. Anyway, just as a reminder, 4.0 is still in pre-release stages and is not really ready for prime-time usage. It still has lots of known and unknown bugs and is primarily available for testing, rather than real work. If you have to get real work done with Paint.NET, I recommend sticking with 3.5.11 for now. Quote ambigram signature by Kemaru [i write plugins and stuff] If you like a post, upvote it!
Cferra Posted February 7, 2014 Author Posted February 7, 2014 Okay. How do I downgrade to that version? Already updated. Will post the crash log the next time it crashes. Quote
pyrochild Posted February 7, 2014 Posted February 7, 2014 Download the installer from this page: http://www.dotpdn.com/downloads/pdn.html Click on "Paint.NET v3.5.11" on the right side of the page, not the big green download button, which is a lying, deliberately misleading garbage ad. Quote ambigram signature by Kemaru [i write plugins and stuff] If you like a post, upvote it!
Cferra Posted February 7, 2014 Author Posted February 7, 2014 Okay. It just crashed as I was working on the comic I was working on. Here is the report: This text file was created because paint.net crashed. Please e-mail this to [email protected] so we can diagnose and fix the problem. It should be noted that I use Windows 8. Application version: paint.net 4.0 (α 4.0.5143.33275) Time of crash: 2/7/2014 5:11:32 PM Application uptime: 05:26:11.3290808 Application state: Running Install directory: C:\Program Files\Paint.NET Current directory: C:\Program Files\Paint.NET OS Version: 6.2.9200.0 Workstation x64 .NET version: CLR 4.0.30319.18051 x64, FX 4.0 4.5 Processor: 2x "Intel® Pentium® CPU G2020 @ 2.90GHz" @ ~2893MHz (DEP, SSE, SSE2, SSE3, SSSE3, SSE4_1, SSE4_2, XSAVE) Physical memory: 3980 MB Hardware acceleration: True Video card: Intel® HD Graphics, Microsoft Basic Render Driver UI animations: True UI DPI: 96.00 dpi (1.00x scale) UI Theme: Aero/Aero + DWM (Aero.msstyles) Updates: True, 2/7/2014 Locale: pdnr.c: en-US, hklm: en-US, hkcu: en-US, cc: en-US, cuic: en-US Exception details: System.Reflection.TargetInvocationException: Exception has been thrown by the target of an invocation. ---> System.Reflection.TargetInvocationException: Exception has been thrown by the target of an invocation. ---> PaintDotNet.InternalErrorException: this.baseGeometry == null at PaintDotNet.Tools.MagicWand.MagicWandToolChanges.OnDeserializedGraph() in D:\src\pdn\paintdotnet\src\PaintDotNet\Tools\MagicWand\MagicWandToolChanges.cs:line 158 at System.Runtime.Serialization.ObjectManager.RaiseDeserializationEvent() at System.Runtime.Serialization.Formatters.Binary.ObjectReader.Deserialize(HeaderHandler handler, __BinaryParser serParser, Boolean fCheck, Boolean isCrossAppDomain, IMethodCallMessage methodCallMessage) at System.Runtime.Serialization.Formatters.Binary.BinaryFormatter.Deserialize(Stream serializationStream, HeaderHandler handler, Boolean fCheck, Boolean isCrossAppDomain, IMethodCallMessage methodCallMessage) at System.Runtime.Serialization.Formatters.Binary.BinaryFormatter.Deserialize(Stream serializationStream, HeaderHandler handler, Boolean fCheck, IMethodCallMessage methodCallMessage) at PaintDotNet.ReferenceValue.CloneCore[TResult]() in D:\src\pdn\paintdotnet\src\Base\ReferenceValue.cs:line 327 at PaintDotNet.Tools.TransactedTool`2.BeginDrawing(TransactedToolDrawingAgent`1 agent, TChanges initialChanges, HistoryMemento beforeDrawingMemento) in D:\src\pdn\paintdotnet\src\PaintDotNet\Tools\TransactedTool`2.cs:line 625 at PaintDotNet.Tools.MagicWand.MagicWandTool.OnUIGestureBegin(Object sender, MouseEventArgs e) in D:\src\pdn\paintdotnet\src\PaintDotNet\Tools\MagicWand\MagicWandTool.cs:line 205 --- End of inner exception stack trace --- at System.RuntimeMethodHandle.InvokeMethod(Object target, Object[] arguments, Signature sig, Boolean constructor) at System.Reflection.RuntimeMethodInfo.UnsafeInvokeInternal(Object obj, Object[] parameters, Object[] arguments) at System.Delegate.DynamicInvokeImpl(Object[] args) at PaintDotNet.UI.UIElement.OnEvent(RoutedEventArgs e) in D:\src\pdn\paintdotnet\src\Framework\UI\UIElement.cs:line 927 at PaintDotNet.UI.EventManager.RaiseDirect(IRoutedEventSink target, RoutedEventArgs e) in D:\src\pdn\paintdotnet\src\Framework\UI\EventManager.cs:line 196 at PaintDotNet.UI.EventManager.RaiseBubble(IRoutedEventSink target, RoutedEventArgs e) in D:\src\pdn\paintdotnet\src\Framework\UI\EventManager.cs:line 154 at PaintDotNet.UI.Controls.ClickDragBehavior.OnMouseDown(Object sender, MouseButtonEventArgs e) in D:\src\pdn\paintdotnet\src\PaintDotNet\UI\Controls\ClickDragBehavior.cs:line 279 --- End of inner exception stack trace --- at System.RuntimeMethodHandle.InvokeMethod(Object target, Object[] arguments, Signature sig, Boolean constructor) at System.Reflection.RuntimeMethodInfo.UnsafeInvokeInternal(Object obj, Object[] parameters, Object[] arguments) at System.Delegate.DynamicInvokeImpl(Object[] args) at PaintDotNet.UI.UIElement.OnEvent(RoutedEventArgs e) in D:\src\pdn\paintdotnet\src\Framework\UI\UIElement.cs:line 927 at PaintDotNet.UI.EventManager.RaiseDirect(IRoutedEventSink target, RoutedEventArgs e) in D:\src\pdn\paintdotnet\src\Framework\UI\EventManager.cs:line 196 at PaintDotNet.UI.EventManager.RaiseBubble(IRoutedEventSink target, RoutedEventArgs e) in D:\src\pdn\paintdotnet\src\Framework\UI\EventManager.cs:line 154 at PaintDotNet.Canvas.CanvasMouseDevice.RelayMouseDown(MouseEventArgsF e) in D:\src\pdn\paintdotnet\src\PaintDotNet\Canvas\CanvasMouseDevice.cs:line 34 at PaintDotNet.Tools.PresentationBasedTool`2.OnMouseDown(MouseEventArgsF e) in D:\src\pdn\paintdotnet\src\PaintDotNet\Tools\PresentationBasedTool`2.cs:line 211 at PaintDotNet.Tools.Tool.MouseDown(MouseEventArgsF e) in D:\src\pdn\paintdotnet\src\PaintDotNet\Tools\Tool.cs:line 724 at PaintDotNet.Tools.Tool.PerformMouseDown(MouseEventArgsF e) in D:\src\pdn\paintdotnet\src\PaintDotNet\Tools\Tool.cs:line 486 at PaintDotNet.Controls.DocumentView.MouseDownHandler(Object sender, MouseEventArgs e) in D:\src\pdn\paintdotnet\src\PaintDotNet\Controls\DocumentView.cs:line 1158 at System.Windows.Forms.Control.WmMouseDown(Message& m, MouseButtons button, Int32 clicks) at System.Windows.Forms.Control.WndProc(Message& m) at PaintDotNet.SystemLayer.GdiPaintControl.WndProc(Message& m) in D:\src\pdn\paintdotnet\src\SystemLayer\GdiPaintControl.cs:line 123 at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam) Managed assemblies: mscorlib, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089 @ C:\Windows\Microsoft.NET\Framework64\v4.0.30319\mscorlib.dll PaintDotNet, Version=4.0.5143.33275, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\PaintDotNet.exe PaintDotNet.Base, Version=4.0.5143.33275, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\PaintDotNet.Base.dll System, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089 @ C:\windows\Microsoft.Net\assembly\GAC_MSIL\System\v4.0_4.0.0.0__b77a5c561934e089\System.dll WindowsBase, Version=4.0.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35 @ C:\windows\Microsoft.Net\assembly\GAC_MSIL\WindowsBase\v4.0_4.0.0.0__31bf3856ad364e35\WindowsBase.dll System.Drawing, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a @ C:\windows\Microsoft.Net\assembly\GAC_MSIL\System.Drawing\v4.0_4.0.0.0__b03f5f7f11d50a3a\System.Drawing.dll PresentationFramework, Version=4.0.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35 @ C:\windows\Microsoft.Net\assembly\GAC_MSIL\PresentationFramework\v4.0_4.0.0.0__31bf3856ad364e35\PresentationFramework.dll PresentationCore, Version=4.0.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35 @ C:\windows\Microsoft.Net\assembly\GAC_64\PresentationCore\v4.0_4.0.0.0__31bf3856ad364e35\PresentationCore.dll System.Core, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089 @ C:\windows\Microsoft.Net\assembly\GAC_MSIL\System.Core\v4.0_4.0.0.0__b77a5c561934e089\System.Core.dll PaintDotNet.Core, Version=4.0.5143.33275, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\PaintDotNet.Core.dll System.Windows.Forms, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089 @ C:\windows\Microsoft.Net\assembly\GAC_MSIL\System.Windows.Forms\v4.0_4.0.0.0__b77a5c561934e089\System.Windows.Forms.dll PaintDotNet.SystemLayer, Version=4.0.5143.33275, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\PaintDotNet.SystemLayer.dll PaintDotNet.Framework, Version=4.0.5143.33275, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\PaintDotNet.Framework.dll PaintDotNet.Resources, Version=4.0.5143.33275, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\PaintDotNet.Resources.dll PaintDotNet.Data, Version=4.0.5143.33275, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\PaintDotNet.Data.dll PaintDotNet.Effects, Version=4.0.5143.33275, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\PaintDotNet.Effects.dll PaintDotNet.SystemLayer.Native.x64, Version=4.0.5143.33275, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\PaintDotNet.SystemLayer.Native.x64.dll System.Xaml, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089 @ C:\windows\Microsoft.Net\assembly\GAC_MSIL\System.Xaml\v4.0_4.0.0.0__b77a5c561934e089\System.Xaml.dll System.Xml, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089 @ C:\windows\Microsoft.Net\assembly\GAC_MSIL\System.Xml\v4.0_4.0.0.0__b77a5c561934e089\System.Xml.dll Lightning, Version=1.1.3896.32593, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Lightning.dll LightRays, Version=1.3.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\LightRays.dll System.Configuration, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a @ C:\windows\Microsoft.Net\assembly\GAC_MSIL\System.Configuration\v4.0_4.0.0.0__b03f5f7f11d50a3a\System.Configuration.dll WindowsFormsIntegration, Version=4.0.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35 @ C:\windows\Microsoft.Net\assembly\GAC_MSIL\WindowsFormsIntegration\v4.0_4.0.0.0__31bf3856ad364e35\WindowsFormsIntegration.dll Native modules: C:\Program Files\Paint.NET\PaintDotNet.exe, version=4.0.5143.33275 C:\windows\SYSTEM32\ntdll.dll, version=6.2.9200.16384 (win8_rtm.120725-1247) C:\windows\SYSTEM32\MSCOREE.DLL, version=4.0.41209.0 (Main.041209-0000) C:\windows\system32\KERNEL32.dll, version=6.2.9200.16384 (win8_rtm.120725-1247) C:\windows\system32\KERNELBASE.dll, version=6.2.9200.16384 (win8_rtm.120725-1247) C:\windows\system32\ADVAPI32.dll, version=6.2.9200.16384 (win8_rtm.120725-1247) C:\windows\system32\msvcrt.dll, version=7.0.9200.16384 (win8_rtm.120725-1247) C:\windows\SYSTEM32\sechost.dll, version=6.2.9200.16384 (win8_rtm.120725-1247) C:\windows\system32\RPCRT4.dll, version=6.2.9200.16384 (win8_rtm.120725-1247) C:\Windows\Microsoft.NET\Framework64\v4.0.30319\mscoreei.dll, version=4.0.30319.18010 built by: FX45RTMGDR C:\windows\system32\SHLWAPI.dll, version=6.2.9200.16384 (win8_rtm.120725-1247) C:\windows\system32\USER32.dll, version=6.2.9200.16384 (win8_rtm.120725-1247) C:\windows\system32\GDI32.dll, version=6.2.9200.16728 (win8_gdr.131001-1503) C:\windows\system32\IMM32.DLL, version=6.2.9200.16384 (win8_rtm.120725-1247) C:\windows\system32\MSCTF.dll, version=6.2.9200.16384 (win8_rtm.120725-1247) C:\Windows\Microsoft.NET\Framework64\v4.0.30319\clr.dll, version=4.0.30319.18051 built by: FX45RTMGDR C:\windows\SYSTEM32\MSVCR110_CLR0400.dll, version=11.00.50709.17929 built by: FX45RTMREL C:\windows\assembly\NativeImages_v4.0.30319_64\mscorlib\ab0a8fc3d086a3aaf942f366a12a9185\mscorlib.ni.dll, version=4.0.30319.18051 built by: FX45RTMGDR C:\windows\system32\ole32.dll, version=6.2.9200.16384 (win8_rtm.120725-1247) C:\windows\SYSTEM32\combase.dll, version=6.2.9200.16384 (win8_rtm.120725-1247) C:\windows\SYSTEM32\CRYPTBASE.dll, version=6.2.9200.16384 (win8_rtm.120725-1247) C:\windows\SYSTEM32\bcryptPrimitives.dll, version=6.2.9200.16384 (win8_rtm.120725-1247) C:\windows\system32\uxtheme.dll, version=6.2.9200.16384 (win8_rtm.120725-1247) C:\Program Files (x86)\Common Files\Spigot\Search Settings\wthx176.dll, version=8, 6, 0, 1 C:\windows\system32\PSAPI.DLL, version=6.2.9200.16384 (win8_rtm.120725-1247) C:\windows\assembly\NativeImages_v4.0.30319_64\System\84008211017a9909ffd971633716ffc5\System.ni.dll, version=4.0.30319.18045 built by: FX45RTMGDR C:\windows\assembly\NativeImages_v4.0.30319_64\WindowsBase\e515366a6daafba8ecb221ba61fd9f2e\WindowsBase.ni.dll, version=4.0.30319.18058 built by: FX45RTMGDR C:\windows\SYSTEM32\CRYPTSP.dll, version=6.2.9200.16384 (win8_rtm.120725-1247) C:\windows\system32\rsaenh.dll, version=6.2.9200.16553 (win8_gdr.130308-1505) C:\windows\assembly\NativeImages_v4.0.30319_64\System.Drawing\810a79f22ac4d44804984e417c380706\System.Drawing.ni.dll, version=4.0.30319.18022 built by: FX45RTMGDR C:\windows\assembly\NativeImages_v4.0.30319_64\PresentationCore\ccb0cf23d8607c241d292c922aaa9061\PresentationCore.ni.dll, version=4.0.30319.18058 built by: FX45RTMGDR C:\windows\assembly\NativeImages_v4.0.30319_64\Presentatio5ae0f00f#\5ae84452122e5ba9f9157164ec4e1452\PresentationFramework.ni.dll, version=4.0.30319.18058 C:\windows\assembly\NativeImages_v4.0.30319_64\System.Core\ed7a3f09e7c952af6bb5bef3e7198192\System.Core.ni.dll, version=4.0.30319.17929 built by: FX45RTMREL C:\windows\assembly\NativeImages_v4.0.30319_64\PaintDotNet.Base\7dad8ec5071ff0b1d5053d51c0b18ea1\PaintDotNet.Base.ni.dll, version=4.0.5143.33275 C:\windows\assembly\NativeImages_v4.0.30319_64\System.Windows.Forms\ea463e5c9f7c03e073197ccf9e96b853\System.Windows.Forms.ni.dll, version=4.0.30319.18046 built by: FX45RTMGDR C:\windows\assembly\NativeImages_v4.0.30319_64\PaintDotNet500b2e4f#\bf6a6b36d3732411703fb054a950ba08\PaintDotNet.SystemLayer.ni.dll, version=4.0.5143.33275 C:\windows\assembly\NativeImages_v4.0.30319_64\PaintDotNet.Core\09711dfa8f13366a24df2b0300938148\PaintDotNet.Core.ni.dll, version=4.0.5143.33275 C:\windows\assembly\NativeImages_v4.0.30319_64\PaintDotNet26779e70#\fba11c9448a1a944aa28c0a511968da9\PaintDotNet.Resources.ni.dll, version=4.0.5143.33275 C:\windows\assembly\NativeImages_v4.0.30319_64\PaintDotNet7afaaa15#\1b2bbb86057d1c656aa876738d151d58\PaintDotNet.Framework.ni.dll, version=4.0.5143.33275 C:\windows\assembly\NativeImages_v4.0.30319_64\PaintDotNet.Data\b6cadd9a021daadd876dc4bf0e751617\PaintDotNet.Data.ni.dll, version=4.0.5143.33275 C:\windows\assembly\NativeImages_v4.0.30319_64\PaintDotNet.Effects\eacfe09a6c7c671f4cad2db892af6ad2\PaintDotNet.Effects.ni.dll, version=4.0.5143.33275 C:\windows\assembly\NativeImages_v4.0.30319_64\PaintDotNet\c7e8e816b5eecfba6057a6c8b943677e\PaintDotNet.ni.exe, version=4.0.5143.33275 C:\windows\SYSTEM32\dwrite.dll, version=6.2.9200.16384 (win8_rtm.120725-1247) C:\Windows\Microsoft.NET\Framework64\v4.0.30319\WPF\wpfgfx_v0400.dll, version=4.0.30319.18046 built by: FX45RTMGDR C:\windows\system32\OLEAUT32.dll, version=6.2.9200.16726 C:\Windows\Microsoft.NET\Framework64\v4.0.30319\WPF\PresentationNative_v0400.dll, version=4.0.30319.17929 built by: FX45RTMREL C:\windows\system32\shell32.dll, version=6.2.9200.16496 (win8_gdr.130108-1504) C:\windows\SYSTEM32\SHCORE.dll, version=6.2.9200.16384 (win8_rtm.120725-1247) C:\Windows\Microsoft.NET\Framework64\v4.0.30319\clrjit.dll, version=4.0.30319.18046 built by: FX45RTMGDR C:\Program Files\Paint.NET\PaintDotNet.SystemLayer.Native.x64.dll, version=4.0 C:\windows\SYSTEM32\MSVCR100.dll, version=10.00.40219.325 C:\windows\SYSTEM32\VCOMP100.DLL, version=10.00.40219.325 built by: SP1LDR C:\windows\SYSTEM32\MSVCP100.dll, version=10.00.40219.325 C:\windows\SYSTEM32\PROPSYS.dll, version=7.00.9200.16384 (win8_rtm.120725-1247) C:\windows\WinSxS\amd64_microsoft.windows.gdiplus_6595b64144ccf1df_1.1.9200.16518_none_726fbfe0cc22f012\gdiplus.dll, version=6.2.9200.16518 (win8_gdr.130201-1704) C:\windows\SYSTEM32\profapi.dll, version=6.2.9200.16384 (win8_rtm.120725-1247) C:\windows\assembly\NativeImages_v4.0.30319_64\PaintDotNetc8826574#\8d6eea75881249e3ae7ed3941e4157d0\PaintDotNet.SystemLayer.Native.x64.ni.dll, version=4.0 C:\windows\SYSTEM32\clbcatq.dll, version=2001.12.10130.16384 (win8_rtm.120725-1247) C:\windows\System32\UIAnimation.dll, version=6.2.9200.16384 (win8_rtm.120725-1247) C:\windows\SYSTEM32\dwmapi.dll, version=6.2.9200.16384 (win8_rtm.120725-1247) C:\windows\SYSTEM32\version.dll, version=6.2.9200.16384 (win8_rtm.120725-1247) C:\windows\SYSTEM32\bcrypt.dll, version=6.2.9200.16384 (win8_rtm.120725-1247) C:\windows\WinSxS\amd64_microsoft.windows.common-controls_6595b64144ccf1df_6.0.9200.16579_none_418ab7ef718b27ef\comctl32.dll, version=6.10 (win8_rtm.120725-1247) C:\windows\WinSxS\amd64_microsoft.windows.common-controls_6595b64144ccf1df_5.82.9200.16658_none_776622cb3175a40c\comctl32.dll, version=6.10 (win8_rtm.120725-1247) C:\windows\SYSTEM32\WindowsCodecs.dll, version=6.2.9200.16548 (win8_gdr.130301-1803) C:\windows\system32\d2d1.dll, version=6.2.9200.16384 (win8_rtm.120725-1247) C:\windows\SYSTEM32\wtsapi32.dll, version=6.2.9200.16384 (win8_rtm.120725-1247) C:\windows\SYSTEM32\WINSTA.dll, version=6.2.9200.16384 (win8_rtm.120725-1247) C:\windows\SYSTEM32\d3d11.dll, version=6.2.9200.16699 (win8_gdr.130822-1702) C:\windows\SYSTEM32\dxgi.dll, version=6.2.9200.16420 (win8_gdr.120919-1813) C:\windows\SYSTEM32\D3D10Warp.dll, version=6.2.9200.16420 (win8_gdr.120919-1813) C:\windows\assembly\NativeImages_v4.0.30319_64\System.Xaml\a26ad1493f4f8621e90811cb38ad22e2\System.Xaml.ni.dll, version=4.0.30319.18016 built by: FX45RTMGDR C:\windows\assembly\NativeImages_v4.0.30319_64\System.Xml\17fa9b078e78b857f6c5f5a8081220ae\System.Xml.ni.dll, version=4.0.30319.18058 built by: FX45RTMGDR C:\windows\SYSTEM32\igd10umd64.dll, version=9.17.10.2932 C:\windows\SYSTEM32\winmm.dll, version=6.2.9200.16384 (win8_rtm.120725-1247) C:\windows\SYSTEM32\WINMMBASE.dll, version=6.2.9200.16384 (win8_rtm.120725-1247) C:\windows\SYSTEM32\cfgmgr32.dll, version=6.2.9200.16384 (win8_rtm.120725-1247) C:\windows\system32\DEVOBJ.dll, version=6.2.9200.16384 (win8_rtm.120725-1247) C:\windows\system32\explorerframe.dll, version=6.2.9200.16384 (win8_rtm.120725-1247) C:\windows\system32\DUser.dll, version=6.2.9200.16384 (win8_rtm.120725-1247) C:\windows\system32\DUI70.dll, version=6.2.9200.16384 (win8_rtm.120725-1247) C:\Program Files\Paint.NET\Effects\Lightning.dll, version=1.1.3896.32593 C:\Program Files\Paint.NET\Effects\LightRays.dll, version=1.3.0.0 C:\windows\assembly\NativeImages_v4.0.30319_64\System.Configuration\80c78462e16a886f9d46df2cf4a1eb7e\System.Configuration.ni.dll, version=4.0.30319.18058 built by: FX45RTMGDR C:\windows\assembly\NativeImages_v4.0.30319_64\WindowsForm0b574481#\b3e4cf29c27d45a83636b58f2fdd9253\WindowsFormsIntegration.ni.dll, version=4.0.30319.18058 built by: FX45RTMGDR C:\Windows\Microsoft.NET\Framework64\v4.0.30319\diasymreader.dll, version=11.0.50709.17929 built by: FX45RTMREL C:\windows\system32\SETUPAPI.dll, version=6.2.9200.16384 (win8_rtm.120725-1247) C:\windows\SYSTEM32\apphelp.dll, version=6.2.9200.16384 (win8_rtm.120725-1247) C:\windows\System32\shdocvw.dll, version=6.2.9200.16550 (win8_gdr.130305-1505) C:\Windows\Microsoft.NET\Framework64\v4.0.30319\clrcompression.dll, version=4.0.30319.18010 built by: FX45RTMGDR C:\windows\System32\comdlg32.dll, version=6.2.9200.16384 (win8_rtm.120725-1247) C:\Program Files\Common Files\microsoft shared\ink\tiptsf.dll, version=6.2.9200.16384 (win8_rtm.120725-1247) C:\windows\system32\xmllite.dll, version=6.2.9200.16384 (win8_rtm.120725-1247) C:\windows\System32\StructuredQuery.dll, version=7.00.9200.16433 (win8_gdr.121010-1704) C:\windows\System32\Secur32.dll, version=6.2.9200.16384 (win8_rtm.120725-1247) C:\windows\System32\SSPICLI.DLL, version=6.2.9200.16420 (win8_gdr.120919-1813) C:\Windows\System32\actxprxy.dll, version=6.2.9200.16547 (win8_gdr.130228-1507) C:\Windows\System32\thumbcache.dll, version=6.2.9200.16384 (win8_rtm.120725-1247) C:\Windows\System32\oleacc.dll, version=7.2.9200.16384 (win8_rtm.120725-1247) C:\windows\system32\NetworkExplorer.dll, version=6.2.9200.16384 (win8_rtm.120725-1247) C:\windows\SYSTEM32\LINKINFO.dll, version=6.2.9200.16384 (win8_rtm.120725-1247) C:\windows\SYSTEM32\MPR.dll, version=6.2.9200.16384 (win8_rtm.120725-1247) C:\windows\SYSTEM32\cscapi.dll, version=6.2.9200.16384 (win8_rtm.120725-1247) C:\Windows\System32\dlnashext.dll, version=12.0.9200.16384 (win8_rtm.120725-1247) C:\Windows\System32\DevDispItemProvider.dll, version=6.2.9200.16547 (win8_gdr.130228-1507) C:\Windows\System32\twinapi.dll, version=6.2.9200.16384 (win8_rtm.120725-1247) C:\windows\system32\WINTRUST.dll, version=6.2.9200.16666 (win8_gdr.130712-1604) C:\windows\system32\CRYPT32.dll, version=6.2.9200.16727 (win8_gdr.130930-1510) C:\windows\system32\MSASN1.dll, version=6.2.9200.16384 (win8_rtm.120725-1247) C:\Windows\System32\EhStorShell.dll, version=6.2.9200.16384 (win8_rtm.120725-1247) C:\windows\SYSTEM32\ntshrui.dll, version=6.2.9200.16384 (win8_rtm.120725-1247) C:\windows\SYSTEM32\srvcli.dll, version=6.2.9200.16384 (win8_rtm.120725-1247) C:\windows\system32\IconCodecService.dll, version=6.2.9200.16384 (win8_rtm.120725-1247) C:\windows\SYSTEM32\ktmw32.dll, version=6.2.9200.16384 (win8_rtm.120725-1247) C:\Windows\System32\Windows.Globalization.dll, version=6.2.9200.16384 (win8_rtm.120725-1247) C:\Windows\System32\Bcp47Langs.dll, version=6.2.9200.16604 (win8_gdr.130503-1646) C:\windows\system32\SearchFolder.dll, version=6.2.9200.16384 (win8_rtm.120725-1247) C:\windows\System32\drprov.dll, version=6.2.9200.16384 (win8_rtm.120725-1247) C:\windows\System32\ntlanman.dll, version=6.2.9200.16384 (win8_rtm.120725-1247) C:\windows\System32\davclnt.dll, version=6.2.9200.16700 (win8_gdr.130826-1506) C:\windows\System32\DAVHLPR.dll, version=6.2.9200.16384 (win8_rtm.120725-1247) C:\windows\system32\WS2_32.dll, version=6.2.9200.16384 (win8_rtm.120725-1247) C:\windows\system32\NSI.dll, version=6.2.9200.16384 (win8_rtm.120725-1247) C:\windows\System32\provsvc.dll, version=6.2.9200.16384 (win8_rtm.120725-1247) C:\windows\system32\urlmon.dll, version=10.00.9200.16384 (win8_rtm.120725-1247) C:\windows\system32\iertutil.dll, version=10.00.9200.16384 (win8_rtm.120725-1247) C:\windows\system32\WININET.dll, version=10.00.9200.16384 (win8_rtm.120725-1247) C:\windows\SYSTEM32\MsftEdit.dll, version=6.2.9200.16384 (win8_rtm.120725-1247) C:\windows\System32\NaturalLanguage6.dll, version=6.2.9200.16384 (win8_rtm.120725-1247) C:\windows\System32\NLSData0009.dll, version=6.2.9200.16384 (win8_rtm.120725-1247) C:\windows\System32\NLSLexicons0009.dll, version=6.2.9200.16384 (win8_rtm.120725-1247) C:\windows\System32\msxml6.dll, version=6.30.9200.16447 C:\windows\SYSTEM32\sxs.dll, version=6.2.9200.16384 (win8_rtm.120725-1247) C:\Windows\System32\ieframe.dll, version=10.00.9200.16384 (win8_rtm.120725-1247) C:\windows\SYSTEM32\elscore.dll, version=6.2.9200.16384 (win8_rtm.120725-1247) C:\windows\system32\ElsLad.dll, version=6.2.9200.16384 (win8_rtm.120725-1247) C:\windows\SYSTEM32\wkscli.dll, version=6.2.9200.16384 (win8_rtm.120725-1247) C:\windows\SYSTEM32\netutils.dll, version=6.2.9200.16384 (win8_rtm.120725-1247) C:\windows\SYSTEM32\ntmarta.dll, version=6.2.9200.16384 (win8_rtm.120725-1247) --------------------------------------------------- Quote
Cferra Posted February 7, 2014 Author Posted February 7, 2014 Installing the other version now. I hope you guys can fix the program! Quote
Rick Brewster Posted February 8, 2014 Posted February 8, 2014 This is fixed for the upcoming beta Quote The Paint.NET Blog: https://blog.getpaint.net/ Donations are always appreciated! https://www.getpaint.net/donate.html
Note: Your post will require moderator approval before it will be visible.
