Line / Curve tool problem...
When using the Line / Curve tool, I tend to cause a line to "finish" becsue when I try to click on a handle to bend the line, I miss, (due to poor vision)... and the line can no longer be adjusted.  Is there a way to cause the handles to re-appear so I can complete the line the way I need to?  "Undo" only makes the line disappear, and I have to start all over.  :(
Any help will be very much appreciated.  :)
I would switch to paint.net v4.0 if possible (as of now, here's the latest version).
It's still in development stages, but it has several really useful new features, one of them being exactly what you're asking for here.
  • 3 weeks later...
Once confirmed the shape is unable to be re-edited using the shape tool. This is because the shape is converted from the cool math into pixels. That's just the way it works. Sorry.
For this reason we recommend placing any new object on it's own layer. It is a relatively painless process to erase the contents of the layer (or hide it & make a new layer) and redraw the shape.
