Redman 0 Posted June 29, 2007 Share Posted June 29, 2007 I have an error : IO.FileNotFoundException Quote Link to post Share on other sites
Bob 4 Posted June 29, 2007 Share Posted June 29, 2007 Did you carefully pasted pdnbench.exe in the Paint.NET folder? Quote No. Way. I've just seen Bob. And... *poof!*—just like that—he disappears into the mist again. ~Helio Link to post Share on other sites
Redman 0 Posted June 29, 2007 Share Posted June 29, 2007 Nope, in the folder effects and I forget the dll link, can you give me it ? It's not written on this topic. Quote Link to post Share on other sites
Bob 4 Posted June 29, 2007 Share Posted June 29, 2007 http://paintdotnet.12.forumer.com/viewt ... 2733#22733 Paste it where paintdotnet.exe is located. Quote No. Way. I've just seen Bob. And... *poof!*—just like that—he disappears into the mist again. ~Helio Link to post Share on other sites
Redman 0 Posted June 29, 2007 Share Posted June 29, 2007 Thanks, it functionned for many things and suddenly an error appear : TypeLoadException Quote Link to post Share on other sites
Bob 4 Posted June 29, 2007 Share Posted June 29, 2007 Please create a new thread so we will resolve the issue more comfortably. Quote No. Way. I've just seen Bob. And... *poof!*—just like that—he disappears into the mist again. ~Helio Link to post Share on other sites
marques999 0 Posted July 2, 2007 Share Posted July 2, 2007 Mine crashes at Linear reflected gradient but when was with my old graphic card this didn't happen. Processor: Memory: 2047 MB Using 2 threads. Loading image ... (1024 x 768) done Rotate/Zoom at 0.00 degrees (3x) ... 1244 milliseconds Rotate/Zoom at 70.00 degrees (3x) ... 1197 milliseconds Rotate/Zoom at 140.00 degrees (3x) ... 1217 milliseconds Rotate/Zoom at 210.00 degrees (3x) ... 1205 milliseconds Rotate/Zoom at 280.00 degrees (3x) ... 1331 milliseconds Rotate/Zoom at 350.00 degrees (3x) ... 1265 milliseconds Oil Painting, brush size = 1, coarseness = 10 (1x) ... 489 milliseconds Oil Painting, brush size = 1, coarseness = 85 (1x) ... 1408 milliseconds Oil Painting, brush size = 4, coarseness = 10 (1x) ... 2308 milliseconds Oil Painting, brush size = 4, coarseness = 85 (1x) ... 3351 milliseconds Blur with radius of 2 (1x) ... 668 milliseconds Blur with radius of 4 (1x) ... 1222 milliseconds Blur with radius of 8 (1x) ... 2294 milliseconds Blur with radius of 16 (1x) ... 4344 milliseconds Blur with radius of 32 (1x) ... 7763 milliseconds Sharpen with value of 1 (1x) ... 696 milliseconds Sharpen with value of 4 (1x) ... 957 milliseconds Clouds, roughness = 81 (2x) ... 1452 milliseconds Clouds, roughness = 27 (2x) ... 749 milliseconds Clouds, roughness = 9 (2x) ... 541 milliseconds Median, radius 4 (1x) ... 875 milliseconds Median, radius 16 (1x) ... 2084 milliseconds Median, radius 64 (1x) ... 7465 milliseconds Unfocus, radius 4 (1x) ... 1236 milliseconds Unfocus, radius 16 (1x) ... 2610 milliseconds Unfocus, radius 64 (1x) ... 8733 milliseconds Motion Blur, Horizontal (1x) ... 3768 milliseconds Motion Blur, Vertical (1x) ... 4964 milliseconds Resize from 1024x768 to 512x384 ... 109 milliseconds Resize from 512x384 to 1024x768 ... 421 milliseconds Resize from 1024x768 to 1536x1152 ... 883 milliseconds Resize from 1536x1152 to 1024x768 ... 388 milliseconds Resize from 1024x768 to 2560x1920 ... 2499 milliseconds Resize from 2560x1920 to 1024x768 ... 372 milliseconds Resize from 1024x768 to 3584x2688 ... 4862 milliseconds Resize from 3584x2688 to 1024x768 ... 408 milliseconds Linear reflected gradient @ 4096x3072 (5x) ... Excepção não processada: System.TypeLoadException: Não foi possÃvel carregar o t ipo 'PaintDotNet.BoxedConstants' da assemblagem 'PaintDotNet.Core, Version=3.8.2 708.22785, Culture=neutral, PublicKeyToken=null'. em PdnBench.GradientBenchmark.OnExecute() em PdnBench.Benchmark.Execute() em PdnBench.Startup.Main(String[] args) Prima qualquer tecla para continuar . . . Try to guess my crappy CPU :o Quote Link to post Share on other sites
Redman 0 Posted July 2, 2007 Share Posted July 2, 2007 Did you carefully pasted pdnbench.exe in the Paint.NET folder? Yes I dit it. Quote Link to post Share on other sites
surgency 0 Posted July 2, 2007 Share Posted July 2, 2007 alright. im probably the dumbes programmer here but how do i use this? if i have to put it in my pdn directory and run it from command prompt then im doing it right but i dont understand two things: 1. what is the patch thing for? 2. my pdn directory is located at C:\Paint.NET when i open command prompt it says: C\documents and settings\lev> how can i drop it to being just C:\ (i used to know this) Quote Link to post Share on other sites
Bob 4 Posted July 3, 2007 Share Posted July 3, 2007 cd c:/program files/Paint.NET/ Quote No. Way. I've just seen Bob. And... *poof!*—just like that—he disappears into the mist again. ~Helio Link to post Share on other sites
surgency 0 Posted July 3, 2007 Share Posted July 3, 2007 thank you very much EDIT: your slashes are backwards and it wont work anyway Quote Link to post Share on other sites
Bob 4 Posted July 3, 2007 Share Posted July 3, 2007 Yeah just use the inverted ones, the forum doesn't allow me to display them correctly. And sorry I read it too quicky, you said your PdN folder is at c:/Paint.NET so type cd C:/Paint.NET Replace the / by a backslash (the other way). Quote No. Way. I've just seen Bob. And... *poof!*—just like that—he disappears into the mist again. ~Helio Link to post Share on other sites
saivert 0 Posted October 30, 2007 Share Posted October 30, 2007 I posted in the wrong thread ( an old one I think) ) anyways go read this: viewtopic.php?f=16&t=1149&p=108253#p108253 A bug with the benchmark. causing exceptions Make this thread a sticky please. It's very hard to find.. try searching for pdnbench on this forum yourself and you will be surprised. Quote Link to post Share on other sites
Rick Brewster 1,766 Posted October 30, 2007 Author Share Posted October 30, 2007 PdnBench just hasn't been updated for the latest releases of Paint.NET. That's why this topic isn't currently a sticky. I will make sure to update it for the v3.20 release. Quote The Paint.NET Blog: https://blog.getpaint.net/ Donations are always appreciated! https://www.getpaint.net/donate.html Link to post Share on other sites
