BoltBait Posted January 28, 2007 Share Posted January 28, 2007 Here are the results from my laptop: PdnBench v3.0.2583.27153 Running in 32-bit mode on Windows 5.1.2600.131072 Service Pack 2 Workstation x86 Processor: 2x "Genuine Intel(R) CPU 1400 @ 1.83GHz" @ ~1828 MHz Memory: 1013 MB Using 2 threads. Loading image ... (1024 x 768) done Rotate/Zoom at 0.00 degrees (3x) ... 614 milliseconds Rotate/Zoom at 70.00 degrees (3x) ... 601 milliseconds Rotate/Zoom at 140.00 degrees (3x) ... 607 milliseconds Rotate/Zoom at 210.00 degrees (3x) ... 574 milliseconds Rotate/Zoom at 280.00 degrees (3x) ... 628 milliseconds Rotate/Zoom at 350.00 degrees (3x) ... 587 milliseconds Oil Painting, brush size = 1, coarseness = 10 (1x) ... 250 milliseconds Oil Painting, brush size = 1, coarseness = 85 (1x) ... 600 milliseconds Oil Painting, brush size = 4, coarseness = 10 (1x) ... 1386 milliseconds Oil Painting, brush size = 4, coarseness = 85 (1x) ... 1776 milliseconds Blur with radius of 2 (1x) ... 314 milliseconds Blur with radius of 4 (1x) ... 552 milliseconds Blur with radius of 8 (1x) ... 1032 milliseconds Blur with radius of 16 (1x) ... 1931 milliseconds Blur with radius of 32 (1x) ... 3714 milliseconds Sharpen with value of 1 (1x) ... 504 milliseconds Sharpen with value of 4 (1x) ... 655 milliseconds Auto-Levels (50x) ... 335 milliseconds Clouds, roughness = 81 (2x) ... 886 milliseconds Clouds, roughness = 27 (2x) ... 446 milliseconds Clouds, roughness = 9 (2x) ... 315 milliseconds Median, radius 4 (1x) ... 623 milliseconds Median, radius 16 (1x) ... 1311 milliseconds Median, radius 64 (1x) ... 3808 milliseconds Unfocus, radius 4 (1x) ... 737 milliseconds Unfocus, radius 16 (1x) ... 1410 milliseconds Unfocus, radius 64 (1x) ... 3942 milliseconds Motion Blur, Horizontal (1x) ... 1889 milliseconds Motion Blur, Vertical (1x) ... 2159 milliseconds Resize from 1024x768 to 512x384 ... 86 milliseconds Resize from 512x384 to 1024x768 ... 314 milliseconds Resize from 1024x768 to 1536x1152 ... 703 milliseconds Resize from 1536x1152 to 1024x768 ... 311 milliseconds Resize from 1024x768 to 2560x1920 ... 1941 milliseconds Resize from 2560x1920 to 1024x768 ... 312 milliseconds Resize from 1024x768 to 3584x2688 ... 3804 milliseconds Resize from 3584x2688 to 1024x768 ... 312 milliseconds Linear reflected gradient @ 4096x3072 (5x) ... 1655 milliseconds Conical gradient @ 4096x3072 (5x) ... 5624 milliseconds Radial gradient @ 4096x3072 (5x) ... 2170 milliseconds Compositing one layer, Normal blend mode, 255 opacity (20x) ... 58 milliseconds Compositing one layer, Normal blend mode, 128 opacity (20x) ... 568 milliseconds Compositing four layers, Normal blend mode, 255 opacity (20x) ... 1518 milliseconds Compositing four layers, Normal blend mode, 255 (layer 0) and 128 (layer 1-3) opacity (20x) ... 2179 milliseconds Compositing four layers, Normal blend mode, 128 opacity (20x) ... 2178 milliseconds Compositing three layers, Normal+Multiply+Overlay blending, 150+255+170 opacity (20x) ... 1729 milliseconds Transform simple surface, no transform, nearest neighbor resampling (25x) ... 100 milliseconds Transform complex surface, no transform, nearest neighbor resampling (25x) ... 95 milliseconds Transform simple surface, no transform, bilinear resampling (25x) ... 4039 milliseconds Transform complex surface, no transform, bilinear resampling (25x) ... 4038 milliseconds Transform simple surface, 45 deg. rotation about center, bilinear resampling (25x) ... 3486 milliseconds Transform complex surface, 45 deg. rotation about center, bilinear resampling (25x) ... 3483 milliseconds Transform simple surface, 50% x-scaling 75% y-scaling, bilinear resampling (25x) ... 1521 milliseconds Transform complex surface, 50% x-scaling 75% y-scaling, bilinear resampling (25x) ... 1521 milliseconds Zoom out, rotated grid multisampling, 66% (1000x) ... 5463 milliseconds Zoom out, rotated grid multisampling, 28% (1000x) ... 1169 milliseconds Zoom 1:1, straight blit (1000x) ... 5927 milliseconds Total time: 90693 milliseconds I have a Core Duo (not a Core2 Duo). If only I could find an upgrade for my BIOS then I could upgrade my CPU. Quote Click to play: Download: BoltBait's Plugin Pack | CodeLab | and how about a Computer Dominos Game Link to comment Share on other sites More sharing options...
thoemmi Posted January 31, 2007 Share Posted January 31, 2007 PdnBench v3.0.2583.27153 Running in 32-bit mode on Windows 6.0.6000.0 Workstation x86 Processor: 2x "Intel(R) Core(TM)2 CPU 6600 @ 2.40GHz" @ ~2400 MHz Memory: 3326 MB Using 2 threads. Loading image ... (1024 x 768) done Rotate/Zoom at 0.00 degrees (3x) ... 415 milliseconds Rotate/Zoom at 70.00 degrees (3x) ... 510 milliseconds Rotate/Zoom at 140.00 degrees (3x) ... 546 milliseconds Rotate/Zoom at 210.00 degrees (3x) ... 473 milliseconds Rotate/Zoom at 280.00 degrees (3x) ... 501 milliseconds Rotate/Zoom at 350.00 degrees (3x) ... 494 milliseconds Oil Painting, brush size = 1, coarseness = 10 (1x) ... 237 milliseconds Oil Painting, brush size = 1, coarseness = 85 (1x) ... 502 milliseconds Oil Painting, brush size = 4, coarseness = 10 (1x) ... 825 milliseconds Oil Painting, brush size = 4, coarseness = 85 (1x) ... 983 milliseconds Blur with radius of 2 (1x) ... 256 milliseconds Blur with radius of 4 (1x) ... 369 milliseconds Blur with radius of 8 (1x) ... 750 milliseconds Blur with radius of 16 (1x) ... 1272 milliseconds Blur with radius of 32 (1x) ... 2528 milliseconds Sharpen with value of 1 (1x) ... 331 milliseconds Sharpen with value of 4 (1x) ... 340 milliseconds Auto-Levels (50x) ... 271 milliseconds Clouds, roughness = 81 (2x) ... 801 milliseconds Clouds, roughness = 27 (2x) ... 440 milliseconds Clouds, roughness = 9 (2x) ... 318 milliseconds Median, radius 4 (1x) ... 358 milliseconds Median, radius 16 (1x) ... 596 milliseconds Median, radius 64 (1x) ... 1631 milliseconds Unfocus, radius 4 (1x) ... 513 milliseconds Unfocus, radius 16 (1x) ... 807 milliseconds Unfocus, radius 64 (1x) ... 1712 milliseconds Motion Blur, Horizontal (1x) ... 1578 milliseconds Motion Blur, Vertical (1x) ... 1598 milliseconds Resize from 1024x768 to 512x384 ... 33 milliseconds Resize from 512x384 to 1024x768 ... 126 milliseconds Resize from 1024x768 to 1536x1152 ... 282 milliseconds Resize from 1536x1152 to 1024x768 ... 125 milliseconds Resize from 1024x768 to 2560x1920 ... 923 milliseconds Resize from 2560x1920 to 1024x768 ... 125 milliseconds Resize from 1024x768 to 3584x2688 ... 1647 milliseconds Resize from 3584x2688 to 1024x768 ... 125 milliseconds Linear reflected gradient @ 4096x3072 (5x) ... 1158 milliseconds Conical gradient @ 4096x3072 (5x) ... 2229 milliseconds Radial gradient @ 4096x3072 (5x) ... 1563 milliseconds Compositing one layer, Normal blend mode, 255 opacity (20x) ... 32 milliseconds Compositing one layer, Normal blend mode, 128 opacity (20x) ... 377 milliseconds Compositing four layers, Normal blend mode, 255 opacity (20x) ... 953 milliseconds Compositing four layers, Normal blend mode, 255 (layer 0) and 128 (layer 1-3) opacity (20x) ... 1414 milliseconds Compositing four layers, Normal blend mode, 128 opacity (20x) ... 1414 milliseconds Compositing three layers, Normal+Multiply+Overlay blending, 150+255+170 opacity (20x) ... 1135 milliseconds Transform simple surface, no transform, nearest neighbor resampling (25x) ... 45 milliseconds Transform complex surface, no transform, nearest neighbor resampling (25x) ... 47 milliseconds Transform simple surface, no transform, bilinear resampling (25x) ... 2825 milliseconds Transform complex surface, no transform, bilinear resampling (25x) ... 2850 milliseconds Transform simple surface, 45 deg. rotation about center, bilinear resampling (25x) ... 2410 milliseconds Transform complex surface, 45 deg. rotation about center, bilinear resampling (25x) ... 2414 milliseconds Transform simple surface, 50% x-scaling 75% y-scaling, bilinear resampling (25x) ... 1068 milliseconds Transform complex surface, 50% x-scaling 75% y-scaling, bilinear resampling (25x) ... 1102 milliseconds Zoom out, rotated grid multisampling, 66% (1000x) ... 3404 milliseconds Zoom out, rotated grid multisampling, 28% (1000x) ... 629 milliseconds Zoom 1:1, straight blit (1000x) ... 3632 milliseconds Total time: 56204 milliseconds Interesting is, that if I switch off OneCare 1.5 beta, it takes about 60 seconds :? Regards, Thomas Quote Link to comment Share on other sites More sharing options...
Kev Posted February 1, 2007 Share Posted February 1, 2007 Let's see another old computer runing this PdnBench v3.0.2583.27153 Running in 32-bit mode on Windows 5.1.2600.131072 Service Pack 2 Workstation x86 Processor: 2x "AMD Athlon(tm) MP 1800+" @ ~1533 MHz Memory: 2047 MB Using 2 threads. Loading image ... (1024 x 768) done Rotate/Zoom at 0.00 degrees (3x) ... 1663 milliseconds Rotate/Zoom at 70.00 degrees (3x) ... 1329 milliseconds Rotate/Zoom at 140.00 degrees (3x) ... 1367 milliseconds Rotate/Zoom at 210.00 degrees (3x) ... 1371 milliseconds Rotate/Zoom at 280.00 degrees (3x) ... 1773 milliseconds Rotate/Zoom at 350.00 degrees (3x) ... 1544 milliseconds Oil Painting, brush size = 1, coarseness = 10 (1x) ... 580 milliseconds Oil Painting, brush size = 1, coarseness = 85 (1x) ... 907 milliseconds Oil Painting, brush size = 4, coarseness = 10 (1x) ... 2438 milliseconds Oil Painting, brush size = 4, coarseness = 85 (1x) ... 2741 milliseconds Blur with radius of 2 (1x) ... 456 milliseconds Blur with radius of 4 (1x) ... 774 milliseconds Blur with radius of 8 (1x) ... 1349 milliseconds Blur with radius of 16 (1x) ... 2583 milliseconds Blur with radius of 32 (1x) ... 5098 milliseconds Sharpen with value of 1 (1x) ... 862 milliseconds Sharpen with value of 4 (1x) ... 1021 milliseconds Auto-Levels (50x) ... 831 milliseconds Clouds, roughness = 81 (2x) ... 1514 milliseconds Clouds, roughness = 27 (2x) ... 788 milliseconds Clouds, roughness = 9 (2x) ... 610 milliseconds Median, radius 4 (1x) ... 945 milliseconds Median, radius 16 (1x) ... 1801 milliseconds Median, radius 64 (1x) ... 6521 milliseconds Unfocus, radius 4 (1x) ... 1606 milliseconds Unfocus, radius 16 (1x) ... 2459 milliseconds Unfocus, radius 64 (1x) ... 7189 milliseconds Motion Blur, Horizontal (1x) ... 2168 milliseconds Motion Blur, Vertical (1x) ... 10204 milliseconds Resize from 1024x768 to 512x384 ... 112 milliseconds Resize from 512x384 to 1024x768 ... 463 milliseconds Resize from 1024x768 to 1536x1152 ... 999 milliseconds Resize from 1536x1152 to 1024x768 ... 446 milliseconds Resize from 1024x768 to 2560x1920 ... 2812 milliseconds Resize from 2560x1920 to 1024x768 ... 446 milliseconds Resize from 1024x768 to 3584x2688 ... 5511 milliseconds Resize from 3584x2688 to 1024x768 ... 443 milliseconds Linear reflected gradient @ 4096x3072 (5x) ... 2820 milliseconds Conical gradient @ 4096x3072 (5x) ... 4961 milliseconds Radial gradient @ 4096x3072 (5x) ... 3223 milliseconds Compositing one layer, Normal blend mode, 255 opacity (20x) ... 157 milliseconds Compositing one layer, Normal blend mode, 128 opacity (20x) ... 1003 milliseconds Compositing four layers, Normal blend mode, 255 opacity (20x) ... 2588 milliseconds Compositing four layers, Normal blend mode, 255 (layer 0) and 128 (layer 1-3) opacity (20x) ... 359 4 milliseconds Compositing four layers, Normal blend mode, 128 opacity (20x) ... 3940 milliseconds Compositing three layers, Normal+Multiply+Overlay blending, 150+255+170 opacity (20x) ... 3043 mill iseconds Transform simple surface, no transform, nearest neighbor resampling (25x) ... 251 milliseconds Transform complex surface, no transform, nearest neighbor resampling (25x) ... 214 milliseconds Transform simple surface, no transform, bilinear resampling (25x) ... 8681 milliseconds Transform complex surface, no transform, bilinear resampling (25x) ... 8565 milliseconds Transform simple surface, 45 deg. rotation about center, bilinear resampling (25x) ... 7516 millise conds Transform complex surface, 45 deg. rotation about center, bilinear resampling (25x) ... 7482 millis econds Transform simple surface, 50% x-scaling 75% y-scaling, bilinear resampling (25x) ... 3212 milliseco nds Transform complex surface, 50% x-scaling 75% y-scaling, bilinear resampling (25x) ... 3224 millisec onds Zoom out, rotated grid multisampling, 66% (1000x) ... 8200 milliseconds Zoom out, rotated grid multisampling, 28% (1000x) ... 3044 milliseconds Zoom 1:1, straight blit (1000x) ... 9556 milliseconds Total time: 161560 milliseconds Quote Link to comment Share on other sites More sharing options...
FyreWulff Posted February 7, 2007 Share Posted February 7, 2007 PdnBench v3.0.2583.27153 Running in 32-bit mode on Windows 5.1.2600.131072 Service Pack 2 Workstation x86 Processor: 1x "AMD Duron(tm) Processor" @ ~1016 MHz Memory: 223 MB Using 1 threads. Loading image ... (1024 x 768) done Rotate/Zoom at 0.00 degrees (3x) ... 3810 milliseconds Rotate/Zoom at 70.00 degrees (3x) ... 4683 milliseconds Rotate/Zoom at 140.00 degrees (3x) ... 4361 milliseconds Rotate/Zoom at 210.00 degrees (3x) ... 3683 milliseconds Rotate/Zoom at 280.00 degrees (3x) ... 5601 milliseconds Rotate/Zoom at 350.00 degrees (3x) ... 3826 milliseconds Oil Painting, brush size = 1, coarseness = 10 (1x) ... 1182 milliseconds Oil Painting, brush size = 1, coarseness = 85 (1x) ... 2375 milliseconds Oil Painting, brush size = 4, coarseness = 10 (1x) ... 6508 milliseconds Oil Painting, brush size = 4, coarseness = 85 (1x) ... 8941 milliseconds Blur with radius of 2 (1x) ... 1393 milliseconds Blur with radius of 4 (1x) ... 2460 milliseconds Blur with radius of 8 (1x) ... 4357 milliseconds Blur with radius of 16 (1x) ... 13408 milliseconds Blur with radius of 32 (1x) ... 44716 milliseconds Sharpen with value of 1 (1x) ... 4430 milliseconds Sharpen with value of 4 (1x) ... 4575 milliseconds Auto-Levels (50x) ... 4454 milliseconds Clouds, roughness = 81 (2x) ... 4559 milliseconds Clouds, roughness = 27 (2x) ... 4112 milliseconds Clouds, roughness = 9 (2x) ... 3969 milliseconds Median, radius 4 (1x) ... 4488 milliseconds Median, radius 16 (1x) ... 12200 milliseconds Median, radius 64 (1x) ... 64074 milliseconds Unfocus, radius 4 (1x) ... 4774 milliseconds Unfocus, radius 16 (1x) ... 13182 milliseconds Unfocus, radius 64 (1x) ... 59693 milliseconds Motion Blur, Horizontal (1x) ... 6143 milliseconds Motion Blur, Vertical (1x) ... 35918 milliseconds Resize from 1024x768 to 512x384 ... 376 milliseconds Resize from 512x384 to 1024x768 ... 1364 milliseconds Resize from 1024x768 to 1536x1152 ... 3795 milliseconds Resize from 1536x1152 to 1024x768 ... 2600 milliseconds Resize from 1024x768 to 2560x1920 ... 11091 milliseconds Resize from 2560x1920 to 1024x768 ... 1969 milliseconds Resize from 1024x768 to 3584x2688 ... 19586 milliseconds Resize from 3584x2688 to 1024x768 ... 1861 milliseconds Linear reflected gradient @ 4096x3072 (5x) ... 9146 milliseconds Conical gradient @ 4096x3072 (5x) ... 17419 milliseconds Radial gradient @ 4096x3072 (5x) ... 11903 milliseconds Compositing one layer, Normal blend mode, 255 opacity (20x) ... 611 milliseconds Compositing one layer, Normal blend mode, 128 opacity (20x) ... 5138 milliseconds Compositing four layers, Normal blend mode, 255 opacity (20x) ... 12869 milliseconds Compositing four layers, Normal blend mode, 255 (layer 0) and 128 (layer 1-3) opacity (20x) ... 18209 milliseconds Compositing four layers, Normal blend mode, 128 opacity (20x) ... 14666 milliseconds Compositing three layers, Normal+Multiply+Overlay blending, 150+255+170 opacity (20x) ... 11062 milliseconds Transform simple surface, no transform, nearest neighbor resampling (25x) ... 1203 milliseconds Transform complex surface, no transform, nearest neighbor resampling (25x) ... 1317 milliseconds Transform simple surface, no transform, bilinear resampling (25x) ... 30698 milliseconds Transform complex surface, no transform, bilinear resampling (25x) ... 33125 milliseconds Transform simple surface, 45 deg. rotation about center, bilinear resampling (25x) ... 26677 milliseconds Transform complex surface, 45 deg. rotation about center, bilinear resampling (25x) ... 23534 milliseconds Transform simple surface, 50% x-scaling 75% y-scaling, bilinear resampling (25x) ... 12709 milliseconds Transform complex surface, 50% x-scaling 75% y-scaling, bilinear resampling (25x) ... 11037 milliseconds Zoom out, rotated grid multisampling, 66% (1000x) ... 55487 milliseconds Zoom out, rotated grid multisampling, 28% (1000x) ... 19945 milliseconds Zoom 1:1, straight blit (1000x) ... 68272 milliseconds Total time: 767439 milliseconds Quote Link to comment Share on other sites More sharing options...
bahamasc Posted February 22, 2007 Share Posted February 22, 2007 PdnBench v3.0.2583.27153 Running in 32-bit mode on Windows 5.1.2600.131072 Service Pack 2 Workstation x86 Processor: 2x "AMD Athlon(tm) 64 X2 Dual Core Processor 3800+" @ ~2009 MHz Memory: 1023 MB Using 2 threads. Loading image ... (1024 x 768) done Rotate/Zoom at 0.00 degrees (3x) ... 665 milliseconds Rotate/Zoom at 70.00 degrees (3x) ... 679 milliseconds Rotate/Zoom at 140.00 degrees (3x) ... 687 milliseconds Rotate/Zoom at 210.00 degrees (3x) ... 646 milliseconds Rotate/Zoom at 280.00 degrees (3x) ... 698 milliseconds Rotate/Zoom at 350.00 degrees (3x) ... 666 milliseconds Oil Painting, brush size = 1, coarseness = 10 (1x) ... 275 milliseconds Oil Painting, brush size = 1, coarseness = 85 (1x) ... 580 milliseconds Oil Painting, brush size = 4, coarseness = 10 (1x) ... 1493 milliseconds Oil Painting, brush size = 4, coarseness = 85 (1x) ... 1807 milliseconds Blur with radius of 2 (1x) ... 300 milliseconds Blur with radius of 4 (1x) ... 495 milliseconds Blur with radius of 8 (1x) ... 893 milliseconds Blur with radius of 16 (1x) ... 1734 milliseconds Blur with radius of 32 (1x) ... 3256 milliseconds Sharpen with value of 1 (1x) ... 658 milliseconds Sharpen with value of 4 (1x) ... 718 milliseconds Auto-Levels (50x) ... 471 milliseconds Clouds, roughness = 81 (2x) ... 1065 milliseconds Clouds, roughness = 27 (2x) ... 544 milliseconds Clouds, roughness = 9 (2x) ... 392 milliseconds Median, radius 4 (1x) ... 670 milliseconds Median, radius 16 (1x) ... 1296 milliseconds Median, radius 64 (1x) ... 3641 milliseconds Unfocus, radius 4 (1x) ... 901 milliseconds Unfocus, radius 16 (1x) ... 1531 milliseconds Unfocus, radius 64 (1x) ... 3892 milliseconds Motion Blur, Horizontal (1x) ... 1440 milliseconds Motion Blur, Vertical (1x) ... 1770 milliseconds Resize from 1024x768 to 512x384 ... 75 milliseconds Resize from 512x384 to 1024x768 ... 291 milliseconds Resize from 1024x768 to 1536x1152 ... 657 milliseconds Resize from 1536x1152 to 1024x768 ... 292 milliseconds Resize from 1024x768 to 2560x1920 ... 1826 milliseconds Resize from 2560x1920 to 1024x768 ... 292 milliseconds Resize from 1024x768 to 3584x2688 ... 3575 milliseconds Resize from 3584x2688 to 1024x768 ... 295 milliseconds Linear reflected gradient @ 4096x3072 (5x) ... 1844 milliseconds Conical gradient @ 4096x3072 (5x) ... 3136 milliseconds Radial gradient @ 4096x3072 (5x) ... 2054 milliseconds Compositing one layer, Normal blend mode, 255 opacity (20x) ... 57 milliseconds Compositing one layer, Normal blend mode, 128 opacity (20x) ... 562 milliseconds Compositing four layers, Normal blend mode, 255 opacity (20x) ... 1397 milliseconds Compositing four layers, Normal blend mode, 255 (layer 0) and 128 (layer 1-3) opacity (20x) ... 2034 milliseconds Compositing four layers, Normal blend mode, 128 opacity (20x) ... 2033 milliseconds Compositing three layers, Normal+Multiply+Overlay blending, 150+255+170 opacity (20x) ... 1648 milliseconds Transform simple surface, no transform, nearest neighbor resampling (25x) ... 103 milliseconds Transform complex surface, no transform, nearest neighbor resampling (25x) ... 102 milliseconds Transform simple surface, no transform, bilinear resampling (25x) ... 4219 milliseconds Transform complex surface, no transform, bilinear resampling (25x) ... 4217 milliseconds Transform simple surface, 45 deg. rotation about center, bilinear resampling (25x) ... 3672 milliseconds Transform complex surface, 45 deg. rotation about center, bilinear resampling (25x) ... 3659 milliseconds Transform simple surface, 50% x-scaling 75% y-scaling, bilinear resampling (25x) ... 1570 milliseconds Transform complex surface, 50% x-scaling 75% y-scaling, bilinear resampling (25x) ... 1573 milliseconds Zoom out, rotated grid multisampling, 66% (1000x) ... 4719 milliseconds Zoom out, rotated grid multisampling, 28% (1000x) ... 1310 milliseconds Zoom 1:1, straight blit (1000x) ... 4994 milliseconds Total time: 86305 milliseconds Quote Link to comment Share on other sites More sharing options...
Bob Posted February 22, 2007 Share Posted February 22, 2007 Running in 32-bit mode on Windows 5.1.2600.131072 Service Pack 2 Workstation x86Processor: 2x "AMD Athlon 64 X2 Dual Core Processor 3800+" @ ~2009 MHz Quote No. Way. I've just seen Bob. And... *poof!*—just like that—he disappears into the mist again. ~Helio Link to comment Share on other sites More sharing options...
barkbark00 Posted February 22, 2007 Share Posted February 22, 2007 thats what I said... Quote  Take responsibility for your own intelligence. -Rick Brewster Link to comment Share on other sites More sharing options...
Rick Brewster Posted February 22, 2007 Author Share Posted February 22, 2007 I don't understand ... why the eye-rolling? Quote The Paint.NET Blog: https://blog.getpaint.net/ Donations are always appreciated! https://www.getpaint.net/donate.html Link to comment Share on other sites More sharing options...
usedHONDA Posted February 22, 2007 Share Posted February 22, 2007 You don't know why their rolling their eyes? Seriously? I don't either Quote "The greatest thing about the Internet is that you can write anything you want and give it a false source." ~Ezra Pound twtr | dA | tmblr | yt | fb Link to comment Share on other sites More sharing options...
Rick Brewster Posted February 22, 2007 Author Share Posted February 22, 2007 Ok I'm bringing out the big guns here. Yes, that's 8-cores and 8GB of RAM. PdnBench v3.0.2573.22452 Running in 64-bit mode on x64 OS Processor: 8x Intel(R) Xeon(R) CPU X5355 @ 2.66GHz Memory: 8190 MB Using 8 threads. Loading image ... (1024 x 768) done Rotate/Zoom at 0.00 degrees (3x) ... 81 milliseconds Rotate/Zoom at 70.00 degrees (3x) ... 81 milliseconds Rotate/Zoom at 140.00 degrees (3x) ... 100 milliseconds Rotate/Zoom at 210.00 degrees (3x) ... 74 milliseconds Rotate/Zoom at 280.00 degrees (3x) ... 99 milliseconds Rotate/Zoom at 350.00 degrees (3x) ... 81 milliseconds Oil Painting, brush size = 1, coarseness = 10 (1x) ... 51 milliseconds Oil Painting, brush size = 1, coarseness = 85 (1x) ... 51 milliseconds Oil Painting, brush size = 4, coarseness = 10 (1x) ... 107 milliseconds Oil Painting, brush size = 4, coarseness = 85 (1x) ... 130 milliseconds Blur with radius of 2 (1x) ... 46 milliseconds Blur with radius of 4 (1x) ... 39 milliseconds Blur with radius of 8 (1x) ... 122 milliseconds Blur with radius of 16 (1x) ... 110 milliseconds Blur with radius of 32 (1x) ... 394 milliseconds Sharpen with value of 1 (1x) ... 61 milliseconds Sharpen with value of 4 (1x) ... 138 milliseconds Auto-Levels (50x) ... 241 milliseconds Clouds, roughness = 81 (2x) ... 263 milliseconds Clouds, roughness = 27 (2x) ... 123 milliseconds Clouds, roughness = 9 (2x) ... 85 milliseconds Median, radius 4 (1x) ... 130 milliseconds Median, radius 16 (1x) ... 116 milliseconds Median, radius 64 (1x) ... 450 milliseconds Unfocus, radius 4 (1x) ... 96 milliseconds Unfocus, radius 16 (1x) ... 280 milliseconds Unfocus, radius 64 (1x) ... 303 milliseconds Motion Blur, Horizontal (1x) ... 172 milliseconds Motion Blur, Vertical (1x) ... 204 milliseconds Resize from 1024x768 to 512x384 ... 8 milliseconds Resize from 512x384 to 1024x768 ... 25 milliseconds Resize from 1024x768 to 1536x1152 ... 57 milliseconds Resize from 1536x1152 to 1024x768 ... 25 milliseconds Resize from 1024x768 to 2560x1920 ... 157 milliseconds Resize from 2560x1920 to 1024x768 ... 26 milliseconds Resize from 1024x768 to 3584x2688 ... 308 milliseconds Resize from 3584x2688 to 1024x768 ... 26 milliseconds Linear reflected gradient @ 4096x3072 (5x) ... 164 milliseconds Conical gradient @ 4096x3072 (5x) ... 560 milliseconds Radial gradient @ 4096x3072 (5x) ... 244 milliseconds Compositing one layer, Normal blend mode, 255 opacity (20x) ... 27 milliseconds Compositing one layer, Normal blend mode, 128 opacity (20x) ... 60 milliseconds Compositing four layers, Normal blend mode, 255 opacity (20x) ... 128 milliseconds Compositing four layers, Normal blend mode, 255 (layer 0) and 128 (layer 1-3) opacity (20x) ... 180 milliseconds Compositing four layers, Normal blend mode, 128 opacity (20x) ... 180 milliseconds Compositing three layers, Normal+Multiply+Overlay blending, 150+255+170 opacity (20x) ... 159 milliseconds Transform simple surface, no transform, nearest neighbor resampling (25x) ... 30 milliseconds Transform complex surface, no transform, nearest neighbor resampling (25x) ... 29 milliseconds Transform simple surface, no transform, bilinear resampling (25x) ... 370 milliseconds Transform complex surface, no transform, bilinear resampling (25x) ... 366 milliseconds Transform simple surface, 45 deg. rotation about center, bilinear resampling (25x) ... 632 milliseconds Transform complex surface, 45 deg. rotation about center, bilinear resampling (25x) ... 635 milliseconds Transform simple surface, 50% x-scaling 75% y-scaling, bilinear resampling (25x) ... 144 milliseconds Transform complex surface, 50% x-scaling 75% y-scaling, bilinear resampling (25x) ... 143 milliseconds Zoom out, rotated grid multisampling, 66% (1000x) ... 900 milliseconds Zoom out, rotated grid multisampling, 28% (1000x) ... 271 milliseconds Zoom 1:1, straight blit (1000x) ... 1061 milliseconds Total time: 11288 milliseconds Quote The Paint.NET Blog: https://blog.getpaint.net/ Donations are always appreciated! https://www.getpaint.net/donate.html Link to comment Share on other sites More sharing options...
BoltBait Posted February 22, 2007 Share Posted February 22, 2007 I don't understand ... why the eye-rolling? I'm guessing because 3800 != 2009. Quote Click to play: Download: BoltBait's Plugin Pack | CodeLab | and how about a Computer Dominos Game Link to comment Share on other sites More sharing options...
Bob Posted February 23, 2007 Share Posted February 23, 2007 He is using a 32bit Windows XP with a Athlon 64 (64bit). But the Intel Core-s are 64bit too? My bad. Quote No. Way. I've just seen Bob. And... *poof!*—just like that—he disappears into the mist again. ~Helio Link to comment Share on other sites More sharing options...
The_Lionhearted Posted February 23, 2007 Share Posted February 23, 2007 Ok I'm bringing out the big guns here. Yes, that's 8-cores and 8GB of RAM. That's hot. :shock: Quote My Gallery Link to comment Share on other sites More sharing options...
Illnab1024 Posted February 23, 2007 Share Posted February 23, 2007 Holy Octa core goodness!!! *faints* Quote ~~ Link to comment Share on other sites More sharing options...
casio7131 Posted February 24, 2007 Share Posted February 24, 2007 i was looking to compare my computer with something of a similar speed. i find it curious that my 2xp3-933 is 3x faster than a duron1000 --- i'd expect it to be ~2x quicker (maybe because the duron has so little ram?). making a spreadsheet, i notice that the duron performs worst (relative to me) with large radius values (blur, median, unfocus are ~4--7 times slower). PdnBench v3.0.2583.27153 Running in 32-bit mode on Windows 5.1.2600.131072 Service Pack 2 Workstation x86 Processor: 1x "AMD Duron(tm) Processor" @ ~1016 MHz Memory: 223 MB Using 1 threads. ... Total time: 767439 milliseconds PdnBench v3.0.2583.27153 Running in 32-bit mode on Windows 5.1.2600.131072 Service Pack 2 Workstation x86 Processor: 2x "Intel(r) Pentium(r)III processor" @ ~930 MHz Memory: 767 MB Using 2 threads. ... Total time: 276810 milliseconds Quote Link to comment Share on other sites More sharing options...
Illnab1024 Posted February 24, 2007 Share Posted February 24, 2007 1x vs. 2x likely means a good difference in cache and bus sizes, would be my guess. RAM also helps a bit, too, when you're not paging all the time. Quote ~~ Link to comment Share on other sites More sharing options...
Rick Brewster Posted February 24, 2007 Author Share Posted February 24, 2007 I've published more benchmark results along w/ commentary, http://blogs.msdn.com/rickbrew/archive/ ... cores.aspx Quote The Paint.NET Blog: https://blog.getpaint.net/ Donations are always appreciated! https://www.getpaint.net/donate.html Link to comment Share on other sites More sharing options...
BoltBait Posted February 24, 2007 Share Posted February 24, 2007 I've published more benchmark results along w/ commentary, http://blogs.msdn.com/rickbrew/archive/ ... cores.aspx I found scores 1 and 3 of your chart to be the most interesting. Does moving from 32 to 64 bits really make that much of a difference? Quote Click to play: Download: BoltBait's Plugin Pack | CodeLab | and how about a Computer Dominos Game Link to comment Share on other sites More sharing options...
Rick Brewster Posted February 25, 2007 Author Share Posted February 25, 2007 Yup. Look at last year's results when the Core 2 was fresh on the market, http://blogs.msdn.com/rickbrew/archive/ ... 64890.aspx Quote The Paint.NET Blog: https://blog.getpaint.net/ Donations are always appreciated! https://www.getpaint.net/donate.html Link to comment Share on other sites More sharing options...
bahamasc Posted March 1, 2007 Share Posted March 1, 2007 I don't understand ... why the eye-rolling? I am trying to figure out too. The x2 3800+ is at 2000mhz so the so the 2009 isnt out of the question. Also the AMD64 is 64bit as well as the c2d to my knowledge and many if not most persons run them with 32bit Windows I would guess. Quote Link to comment Share on other sites More sharing options...
Zagna Posted March 2, 2007 Share Posted March 2, 2007 PdnBench v3.0.2583.27153 Running in 32-bit mode on Windows 5.1.2600.131072 Service Pack 2 Workstation x86 Processor: 1x "AMD Athlon(tm) XP 2500+" @ ~1829 MHz Memory: 511 MB Using 1 threads. Loading image ... (1024 x 768) done Rotate/Zoom at 0,00 degrees (3x) ... 2459 milliseconds Rotate/Zoom at 70,00 degrees (3x) ... 2318 milliseconds Rotate/Zoom at 140,00 degrees (3x) ... 2445 milliseconds Rotate/Zoom at 210,00 degrees (3x) ... 2272 milliseconds Rotate/Zoom at 280,00 degrees (3x) ... 2568 milliseconds Rotate/Zoom at 350,00 degrees (3x) ... 2294 milliseconds Oil Painting, brush size = 1, coarseness = 10 (1x) ... 748 milliseconds Oil Painting, brush size = 1, coarseness = 85 (1x) ... 1454 milliseconds Oil Painting, brush size = 4, coarseness = 10 (1x) ... 4137 milliseconds Oil Painting, brush size = 4, coarseness = 85 (1x) ... 4783 milliseconds Blur with radius of 2 (1x) ... 802 milliseconds Blur with radius of 4 (1x) ... 1303 milliseconds Blur with radius of 8 (1x) ... 2368 milliseconds Blur with radius of 16 (1x) ... 4727 milliseconds Blur with radius of 32 (1x) ... 8998 milliseconds Sharpen with value of 1 (1x) ... 1255 milliseconds Sharpen with value of 4 (1x) ... 1529 milliseconds Auto-Levels (50x) ... 1119 milliseconds Clouds, roughness = 81 (2x) ... 3043 milliseconds Clouds, roughness = 27 (2x) ... 1597 milliseconds Clouds, roughness = 9 (2x) ... 1150 milliseconds Median, radius 4 (1x) ... 1413 milliseconds Median, radius 16 (1x) ... 2988 milliseconds Median, radius 64 (1x) ... 9640 milliseconds Unfocus, radius 4 (1x) ... 2759 milliseconds Unfocus, radius 16 (1x) ... 4329 milliseconds Unfocus, radius 64 (1x) ... 10790 milliseconds Motion Blur, Horizontal (1x) ... 3882 milliseconds Motion Blur, Vertical (1x) ... 5855 milliseconds Resize from 1024x768 to 512x384 ... 277 milliseconds Resize from 512x384 to 1024x768 ... 809 milliseconds Resize from 1024x768 to 1536x1152 ... 1780 milliseconds Resize from 1536x1152 to 1024x768 ... 926 milliseconds Resize from 1024x768 to 2560x1920 ... 5264 milliseconds Resize from 2560x1920 to 1024x768 ... 851 milliseconds Resize from 1024x768 to 3584x2688 ... 10302 milliseconds Resize from 3584x2688 to 1024x768 ... 807 milliseconds Linear reflected gradient @ 4096x3072 (5x) ... 5023 milliseconds Conical gradient @ 4096x3072 (5x) ... 9095 milliseconds Radial gradient @ 4096x3072 (5x) ... 5949 milliseconds Compositing one layer, Normal blend mode, 255 opacity (20x) ... 234 milliseconds Compositing one layer, Normal blend mode, 128 opacity (20x) ... 1778 milliseconds Compositing four layers, Normal blend mode, 255 opacity (20x) ... 5227 milliseconds Compositing four layers, Normal blend mode, 255 (layer 0) and 128 (layer 1-3) opacity (20x) ... 6740 milliseconds Compositing four layers, Normal blend mode, 128 opacity (20x) ... 6678 milliseconds Compositing three layers, Normal+Multiply+Overlay blending, 150+255+170 opacity (20x) ... 5283 milliseconds Transform simple surface, no transform, nearest neighbor resampling (25x) ... 353 milliseconds Transform complex surface, no transform, nearest neighbor resampling (25x) ... 335 milliseconds Transform simple surface, no transform, bilinear resampling (25x) ... 15692 milliseconds Transform complex surface, no transform, bilinear resampling (25x) ... 15721 milliseconds Transform simple surface, 45 deg. rotation about center, bilinear resampling (25x) ... 13910 milliseconds Transform complex surface, 45 deg. rotation about center, bilinear resampling (25x) ... 14092 milliseconds Transform simple surface, 50% x-scaling 75% y-scaling, bilinear resampling (25x) ... 6969 milliseconds Transform complex surface, 50% x-scaling 75% y-scaling, bilinear resampling (25x) ... 6471 milliseconds Zoom out, rotated grid multisampling, 66% (1000x) ... 14433 milliseconds Zoom out, rotated grid multisampling, 28% (1000x) ... 4186 milliseconds Zoom 1:1, straight blit (1000x) ... 16930 milliseconds Total time: 271591 milliseconds The K7 Model 10 isn't the latest proc out there but good enough for me Quote Link to comment Share on other sites More sharing options...
mykeys Posted March 14, 2007 Share Posted March 14, 2007 Better than my older Duron 800Mhz PdnBench v3.0.2583.27153 Running in 32-bit mode on Windows 6.0.6000.0 Workstation x86 Processor: 2x "AMD Turion(tm) 64 X2 Mobile Technology TL-52" @ ~1606 MHz Memory: 894 MB Using 2 threads. Loading image ... (1024 x 768) done Rotate/Zoom at 0,00 degrees (3x) ... 1021 milliseconds Rotate/Zoom at 70,00 degrees (3x) ... 1085 milliseconds Rotate/Zoom at 140,00 degrees (3x) ... 1080 milliseconds Rotate/Zoom at 210,00 degrees (3x) ... 968 milliseconds Rotate/Zoom at 280,00 degrees (3x) ... 1102 milliseconds Rotate/Zoom at 350,00 degrees (3x) ... 1166 milliseconds Oil Painting, brush size = 1, coarseness = 10 (1x) ... 358 milliseconds Oil Painting, brush size = 1, coarseness = 85 (1x) ... 843 milliseconds Oil Painting, brush size = 4, coarseness = 10 (1x) ... 2036 milliseconds Oil Painting, brush size = 4, coarseness = 85 (1x) ... 2726 milliseconds Blur with radius of 2 (1x) ... 424 milliseconds Blur with radius of 4 (1x) ... 804 milliseconds Blur with radius of 8 (1x) ... 1158 milliseconds Blur with radius of 16 (1x) ... 2390 milliseconds Blur with radius of 32 (1x) ... 4514 milliseconds Sharpen with value of 1 (1x) ... 935 milliseconds Sharpen with value of 4 (1x) ... 1026 milliseconds Auto-Levels (50x) ... 886 milliseconds Clouds, roughness = 81 (2x) ... 1727 milliseconds Clouds, roughness = 27 (2x) ... 819 milliseconds Clouds, roughness = 9 (2x) ... 871 milliseconds Median, radius 4 (1x) ... 914 milliseconds Median, radius 16 (1x) ... 1773 milliseconds Median, radius 64 (1x) ... 4803 milliseconds Unfocus, radius 4 (1x) ... 1435 milliseconds Unfocus, radius 16 (1x) ... 2655 milliseconds Unfocus, radius 64 (1x) ... 5716 milliseconds Motion Blur, Horizontal (1x) ... 1905 milliseconds Motion Blur, Vertical (1x) ... 2508 milliseconds Resize from 1024x768 to 512x384 ... 75 milliseconds Resize from 512x384 to 1024x768 ... 306 milliseconds Resize from 1024x768 to 1536x1152 ... 567 milliseconds Resize from 1536x1152 to 1024x768 ... 308 milliseconds Resize from 1024x768 to 2560x1920 ... 1636 milliseconds Resize from 2560x1920 to 1024x768 ... 302 milliseconds Resize from 1024x768 to 3584x2688 ... 3361 milliseconds Resize from 3584x2688 to 1024x768 ... 301 milliseconds Linear reflected gradient @ 4096x3072 (5x) ... 2754 milliseconds Conical gradient @ 4096x3072 (5x) ... 4321 milliseconds Radial gradient @ 4096x3072 (5x) ... 2921 milliseconds Compositing one layer, Normal blend mode, 255 opacity (20x) ... 54 milliseconds Compositing one layer, Normal blend mode, 128 opacity (20x) ... 757 milliseconds Compositing four layers, Normal blend mode, 255 opacity (20x) ... 1953 milliseconds Compositing four layers, Normal blend mode, 255 (layer 0) and 128 (layer 1-3) opacity (20x) ... 2821 milliseconds Compositing four layers, Normal blend mode, 128 opacity (20x) ... 2828 milliseconds Compositing three layers, Normal+Multiply+Overlay blending, 150+255+170 opacity (20x) ... 2386 milliseconds Transform simple surface, no transform, nearest neighbor resampling (25x) ... 122 milliseconds Transform complex surface, no transform, nearest neighbor resampling (25x) ... 129 milliseconds Transform simple surface, no transform, bilinear resampling (25x) ... 6200 milliseconds Transform complex surface, no transform, bilinear resampling (25x) ... 6377 milliseconds Transform simple surface, 45 deg. rotation about center, bilinear resampling (25x) ... 5851 milliseconds Transform complex surface, 45 deg. rotation about center, bilinear resampling (25x) ... 5928 milliseconds Transform simple surface, 50% x-scaling 75% y-scaling, bilinear resampling (25x) ... 2466 milliseconds Transform complex surface, 50% x-scaling 75% y-scaling, bilinear resampling (25x) ... 2693 milliseconds Zoom out, rotated grid multisampling, 66% (1000x) ... 7771 milliseconds Zoom out, rotated grid multisampling, 28% (1000x) ... 1516 milliseconds Zoom 1:1, straight blit (1000x) ... 7310 milliseconds Total time: 123900 milliseconds Quote Link to comment Share on other sites More sharing options...
tunedude Posted March 14, 2007 Share Posted March 14, 2007 I ran it from the command line. "bench > bench.txt", then press a key when the CPU fan stops going crazy (because it still does the "Press a key to continue..." you just can't see it). What about printing that info to stderr instead? Quote Link to comment Share on other sites More sharing options...
Rick Brewster Posted March 26, 2007 Author Share Posted March 26, 2007 I've updated the download link to a new version that works with Paint.NET v3.05. This was necessary because PdnLib.dll was renamed to PaintDotNet.Core.dll. Also, in this new version, the Auto-Levels benchmark has been removed. After some quick analysis by the guys at Intel, it was determined that it was a poor benchmark for multiprocessor scaling. Quote The Paint.NET Blog: https://blog.getpaint.net/ Donations are always appreciated! https://www.getpaint.net/donate.html Link to comment Share on other sites More sharing options...
Crisao23 Posted April 20, 2007 Share Posted April 20, 2007 My results with the new version: Opteron 165 @ 3006 Mhz Quote Link to comment Share on other sites More sharing options...
