Code problem - Listing colors in image
43 colors is a Cakewalk , 16 million colors is a quagmire.
If you do feel the need to process more than 43 colors heres a simple solution:
Since random is psuedo random. Simply Seed the Random generator with the color in question and all the ROI's are in sync.
I replace the reseed button (0 - 255) with a 0 - 32767 for more variations.
This will give you the speed of Multithreading and the palette consistency
#region UICode
int Amount1 = 25; // [0,100] Hue Adjust
int Amount2 = 10; // [0,100] Saturation Adjust
int Amount3 = 10; // [0,100] Value Adjust
int Amount4 = 3; // [0,32767] Reseed
#endregion
object sync = new object();
    bool match = false;
    int colorIdx = 0;
    Color[] colors = new Color[rect.Width * rect.Height];
    Color[] off_colors = new Color[rect.Width * rect.Height];
    ColorBgra CurrentPixel;
    //populate colors
            CurrentPixel = src[x,y];
            bool nomatch=true;
            for (int i = 0; i < colorIdx; i++)
                if (CurrentPixel.ToColor().Equals(colors[i])){
                    nomatch=false;
                    dst[x,y]= ColorBgra.FromColor(off_colors[i]);
			        break;
            if (nomatch){
                colors[colorIdx] = CurrentPixel.ToColor();
                Random rndm = new Random(CurrentPixel.GetHashCode()+ Amount4);
                HsvColor hsv;
                int H = 0, S = 0, V = 0;
                hsv = HsvColor.FromColor(colors[colorIdx]);
                H = hsv.Hue;
                S = hsv.Saturation;
                V = hsv.Value;
                H -= rndm.Next(Amount1 * 180 / 100);
                H += rndm.Next(Amount1 * 180 / 100);
                S -= rndm.Next(Amount2) / 2;
                S += rndm.Next(Amount2) / 2;
                V -= rndm.Next(Amount3) / 2;
                V += rndm.Next(Amount3) / 2;
                if (H < 0) H = 0;
                if (H > 360) H = 360;
                if (S < 0) S = 0;
                if (S > 100) S = 100;
                if (V < 0) V = 0;
                if (V > 100) V = 100;
                hsv = new HsvColor(H,S,V);
                off_colors[colorIdx]=hsv.ToColor();
                dst[x,y]= ColorBgra.FromColor(off_colors[colorIdx]);
                colorIdx++;
Edited by TechnoRobbo
TRsSig.png?raw=1
Since random is Psuedo Random Simply Seed the Random generator with the color in question and all the ROI's are in sync.
Very clever!
I see you got it to respect selections too!
I still don't know what you use
for in the code though.
I also like the reseed button but I can probably figure that out. I thought I posted this but I guess I closed the browser before posting.
I forgot to erase it
reseed button cycles from 0 to 255 as you click on it- it will work too but the sliders will give you more combination (0 - 32767)
Post Edit:
I was just playing around with it -Kudos man, this is a cool concept!!!
I'm removing it from my machine and I will wait for your plugin.
TRsSig.png?raw=1
In paint.net 4.0 you can also make use of PaintDotNet.RandomUtil.ThreadInstance. It's already initialized with a good seed which is thread- and time-dependent. You also won't end up with 2 threads using the same seed, which is important.
