ftlog666 Posted August 29, 2013 Share Posted August 29, 2013 good evening.......how do get the effect of water moving???? eg a flower floating on moving water. i apologize for not having a photograph to upload on this. many thanks again regards Quote Link to comment Share on other sites More sharing options...
david.atwell Posted August 29, 2013 Share Posted August 29, 2013 Paint.NET isn't really an animation program. There is an animated GIF plugin, but it's really not made for that and there is no automated way to do any animation patterns. Also, this is really more of a question of art styles...for instance, your water could look like this: Or it could look like this: As you can see, very different ideas both way. You'd probably be better served asking this questions on an art forum. :-) Quote The Doctor: There was a goblin, or a trickster, or a warrior... A nameless, terrible thing, soaked in the blood of a billion galaxies. The most feared being in all the cosmos. And nothing could stop it, or hold it, or reason with it. One day it would just drop out of the sky and tear down your world.Amy: But how did it end up in there?The Doctor: You know fairy tales. A good wizard tricked it.River Song: I hate good wizards in fairy tales; they always turn out to be him. Link to comment Share on other sites More sharing options...
yellowman Posted August 29, 2013 Share Posted August 29, 2013 Or do you mean something like this: If yes then you need a GIF animator. Quote My GalleryMy YouTube Channel "PDN Tutorials" Link to comment Share on other sites More sharing options...
ftlog666 Posted August 30, 2013 Author Share Posted August 30, 2013 Paint.NET isn't really an animation program. There is an animated GIF plugin, but it's really not made for that and there is no automated way to do any animation patterns. Also, this is really more of a question of art styles...for instance, your water could look like this: Or it could look like this: As you can see, very different ideas both way. You'd probably be better served asking this questions on an art forum. :-) i do have the animation plug in - off to the tutorials - thank you so much Quote Link to comment Share on other sites More sharing options...
ftlog666 Posted August 30, 2013 Author Share Posted August 30, 2013 Or do you mean something like this: If yes then you need a GIF animator. yes - this is exactly what i want....i only have 'animation helper plug in'.....will have another look at the tutorials ....thank you so very much for your reply :Tutorials: back to school!!! Quote Link to comment Share on other sites More sharing options...
ftlog666 Posted August 30, 2013 Author Share Posted August 30, 2013 If it's animation like above you want but not confident about making it yourself, then the Reflecting Water animation in LunaPic could be worth trying original ... notice I cropped the base off the original so's the ripples catches it right i had a look at LunaPic as you suggested - this is the effect i am trying to achieve & LunaPic does it all for you - yet another question?? when you have uploaded to that site - can you then save??? many thanks for your learned advice, kindest regards Quote Link to comment Share on other sites More sharing options...
ftlog666 Posted August 31, 2013 Author Share Posted August 31, 2013 i had a look at LunaPic as you suggested - this is the effect i am trying to achieve & LunaPic does it all for you - yet another question?? when you have uploaded to that site - can you then save??? many thanks for your learned advice, kindest regards i went to the site you so very kindly suggested - yep everything was just fine - downloaded it to my computer ...shock, horror dismay - the water wasn't running...any idea what i did wrong???? Quote Link to comment Share on other sites More sharing options...
ftlog666 Posted August 31, 2013 Author Share Posted August 31, 2013 Or do you mean something like this: If yes then you need a GIF animator. there are so many of them on the net - is there one could could possibly recommend???? my approx 8 week experience with this makes me a little suspicious of some sites Quote Link to comment Share on other sites More sharing options...
pdnnoob Posted August 31, 2013 Share Posted August 31, 2013 I recommend Simon Brown's plugin: http://forums.getpaint.net/index.php?/topic/13454-animated-image-24-agif-apng/page-1 If you don't like that, UnFREEz works alright. Quote what I do all summer Emote Cursor Pack 'noob gallery No, Paint.NET is not spyware...but, installing it is an IQ test. ~BoltBait Blend modes are like the filling in your sandwich. It's the filling that can change your experience of the sandwich. ~Ego Eram Reputo Link to comment Share on other sites More sharing options...
yellowman Posted August 31, 2013 Share Posted August 31, 2013 I use Photoscape, it is free. In my image I created the frames in PDN using Water Reflection plugin, then animated them in Photoscape. I use a complicated method to create the frames for the animations, by using PDN simultaneously with another application that saves me more than 90% of the time. Quote My GalleryMy YouTube Channel "PDN Tutorials" Link to comment Share on other sites More sharing options...
