stevodevo Posted June 25, 2013 Share Posted June 25, 2013 (edited) Hi - long time lurker, total paint.net noob, first time post... Ok I used this tut : to make the text image in the attached file. I want to apply a bevel to the text now that I have alpha masked it to get the gradient effect. But the bevel tool is treating the entire image (not just the text) as my selected object. When I get done with the alpha mask, how do I get the text only as my selected object so that the bevel tool will apply the bevel to only the text? I'm trying to get the text effect in this link: http://www.photoshopessentials.com/photoshop-text/text-effects/gold/ or something close to it. A previous post asked the same thing but the only answers he got was how to make it look gold, not how to do all the beveling, textures, sparkles, etc. For now though, all I'm wanting to do is achieve the bevel effect before I move on. Thanks in advance! I'm sure it's something *really* simple! edit: the weird thing is, I can use the outline tool and it will apply only to the text. but when i use the bevel tool, it applies to the outer edges of the canvas. ugh. Edited June 25, 2013 by stevodevo Quote Link to comment Share on other sites More sharing options...
pdnnoob Posted June 25, 2013 Share Posted June 25, 2013 Notice that the plugin is called "bevel selection." Basically, it applies a bevel effect to the outer edge of your selection (which, if you don't have anything selected, is the entire canvas). What you need to do is use the magic wand tool to select your text before you run the bevel plugin. Quote what I do all summer Emote Cursor Pack 'noob gallery No, Paint.NET is not spyware...but, installing it is an IQ test. ~BoltBait Blend modes are like the filling in your sandwich. It's the filling that can change your experience of the sandwich. ~Ego Eram Reputo Link to comment Share on other sites More sharing options...
BoltBait Posted June 25, 2013 Share Posted June 25, 2013 If you are talking about my bevel plugin, you must select what you want beveled first. So, Shift-Click on a transparent area and press Ctrl-I to invert the selection. This should have all the text selected. Now run the bevel effect. Quote Click to play: Download: BoltBait's Plugin Pack | CodeLab | and how about a Computer Dominos Game Link to comment Share on other sites More sharing options...
