peterd2012 Posted February 28, 2013 Share Posted February 28, 2013 I need to be able to draw "squiggly" (multi-point)lines. Specifically, roads on a map. Is there any tool or plug in that allows for "squiggly" lines? The line/curve tool seems to be limited to 4 points that act as reference points for curves only so it isn't any use to me. Thanks Quote Link to comment Share on other sites More sharing options...
pdnnoob Posted February 28, 2013 Share Posted February 28, 2013 Draw more than one line. 1 Quote No, Paint.NET is not spyware...but, installing it is an IQ test. ~BoltBait Blend modes are like the filling in your sandwich. It's the filling that can change your experience of the sandwich. ~Ego Eram Reputo Link to comment Share on other sites More sharing options...
Ego Eram Reputo Posted February 28, 2013 Share Posted February 28, 2013 Or draw them freehand with the Pencil or Paintbrush tools. Quote ebook: Mastering Paint.NET | resources: Plugin Index | Stereogram Tut | proud supporter of Codelab plugins: EER's Plugin Pack | Planetoid | StickMan | WhichSymbol+ | Dr Scott's Markup Renderer | CSV Filetype | dwarf horde plugins: Plugin Browser | ShapeMaker Link to comment Share on other sites More sharing options...
BoltBait Posted February 28, 2013 Share Posted February 28, 2013 Use a different tool: Inkscape. Quote Click to play: Download: BoltBait's Plugin Pack | CodeLab | and how about a Computer Dominos Game Link to comment Share on other sites More sharing options...
peterd2012 Posted March 1, 2013 Author Share Posted March 1, 2013 Thank you for the suggestions, but the freehand tool doesn't let you edit the and drawing multiple lines isn't an option. One road can have 300-400 points. And if I have to move it? It's just not practical. I'll give Inkscape a look and see what it can do. Quote Link to comment Share on other sites More sharing options...
pdnnoob Posted March 1, 2013 Share Posted March 1, 2013 If you wish to adjust the line after it is drawn...you can't. Inkscape should be capable of doing what you are looking for. Quote No, Paint.NET is not spyware...but, installing it is an IQ test. ~BoltBait Blend modes are like the filling in your sandwich. It's the filling that can change your experience of the sandwich. ~Ego Eram Reputo Link to comment Share on other sites More sharing options...
