Chalkboard (needs work... ok, hopeless)
BoltBait
*idea!*
:D
*tinker* *tinker* *tinker*
*give up*
// Author: BoltBait
// Submenu: Artistic
// Name: Chalkboard
// URL: http://www.BoltBait.com/pdn
// Title: BoltBait's Chalkboard v1.0
#region UICode
int Amount1 = 10; // [0,100] Radius
int Amount2 = -10; // [-100,100] Brightness
int Amount3 = 10; // [-100,100] Contrast
double Amount4 = 0.9; // [0,1] Strength
bool Amount5 = false; // [0,1] Invert Mask
#endregion
// Setup for using pixel op
private UnaryPixelOps.Desaturate desaturateOp = new UnaryPixelOps.Desaturate();
private UnaryPixelOps.Invert invertOp = new UnaryPixelOps.Invert();
// Setup for using Darken blend op
private UserBlendOps.MultiplyBlendOp multiplyOp = new UserBlendOps.MultiplyBlendOp();
// Here is the main render loop function
unsafe void Render(Surface dst, Surface src, Rectangle rect)
    // Setup for calling the Gaussian Blur effect
    GaussianBlurEffect blurEffect = new GaussianBlurEffect();
    PropertyCollection blurProps = blurEffect.CreatePropertyCollection();
    PropertyBasedEffectConfigToken BlurParameters = new PropertyBasedEffectConfigToken(blurProps);
    BlurParameters.SetPropertyValue(GaussianBlurEffect.PropertyNames.Radius, Amount1);
    blurEffect.SetRenderInfo(BlurParameters, new RenderArgs(dst), new RenderArgs(src));
    // Call the Gaussian Blur function
    blurEffect.Render(new Rectangle[1] {rect},0,1);
    // Setup for calling the Brightness and Contrast function
    BrightnessAndContrastAdjustment bacAdjustment = new BrightnessAndContrastAdjustment();
    PropertyCollection cProps = bacAdjustment.CreatePropertyCollection();
    PropertyBasedEffectConfigToken cParameters = new PropertyBasedEffectConfigToken(cProps);
    cParameters.SetPropertyValue(BrightnessAndContrastAdjustment.PropertyNames.Brightness, Amount2);
    cParameters.SetPropertyValue(BrightnessAndContrastAdjustment.PropertyNames.Contrast, Amount3);
    bacAdjustment.SetRenderInfo(cParameters, new RenderArgs(dst), new RenderArgs(dst));
    // Call the Brightness and Contrast function
    bacAdjustment.Render(new Rectangle[1] {rect},0,1);
    // Now in the main render loop, the dst canvas has a blurred version of the src canvas
        ColorBgra* srcPtr = src.GetPointAddressUnchecked(rect.Left, y);
        ColorBgra* dstPtr = dst.GetPointAddressUnchecked(rect.Left, y);
            ColorBgra CurrentPixel = *srcPtr;
            ColorBgra DestPixel = *dstPtr;
            // Desaturate pixels
            CurrentPixel = desaturateOp.Apply(CurrentPixel);
            DestPixel = desaturateOp.Apply(DestPixel);
            // Calculate difference in src and blurred dest pixel
            DestPixel.R = (byte)Math.Abs(CurrentPixel.R - DestPixel.R);
            DestPixel.G = (byte)Math.Abs(CurrentPixel.G - DestPixel.G);
            DestPixel.B = (byte)Math.Abs(CurrentPixel.B - DestPixel.B);
            // Invert mask
            if (Amount5) DestPixel = invertOp.Apply(DestPixel);
            // Apply strength
            DestPixel.A = (byte)((double)DestPixel.A * Amount4);
            // Shade final pixel
            CurrentPixel = multiplyOp.Apply(*srcPtr, DestPixel);
            *dstPtr = CurrentPixel;
            srcPtr++;
            dstPtr++;
Click to play:
Trying to replicate an image drawn in chalk?  Like these?
2843407875_c90f501df0.jpg?w=440
