yankeedoodler88 Posted January 29, 2013 Share Posted January 29, 2013 (edited) every time i try to erase i get this grid is there anyway to turn if off ?? any help is greatly appreciated thank you for your time Edited January 29, 2013 by yankeedoodler88 Quote Link to comment Share on other sites More sharing options...
Darkrder Posted January 29, 2013 Share Posted January 29, 2013 That grid represents a transparent background. All photo editing software uses it. There's no way to turn it off, but if you flatten your image so there's no transparency behind it, it shouldn't appear when you erase. Quote Link to comment Share on other sites More sharing options...
Pixey Posted January 29, 2013 Share Posted January 29, 2013 In this case you coud use the paint brush, with the colour white, to erase and then there would be no transparent background. Quote How I made Jennifer & Halle in Paint.net My Gallery | My Deviant Art "Rescuing one animal may not change the world, but for that animal their world is changed forever!" anon. Link to comment Share on other sites More sharing options...
Ego Eram Reputo Posted January 29, 2013 Share Posted January 29, 2013 Edited the thread title to make it more descriptive than the original plea for help. <moved to Paint.NET Discussion and Questions> Quote ebook: Mastering Paint.NET | resources: Plugin Index | Stereogram Tut | proud supporter of Codelab plugins: EER's Plugin Pack | Planetoid | StickMan | WhichSymbol+ | Dr Scott's Markup Renderer | CSV Filetype | dwarf horde plugins: Plugin Browser | ShapeMaker Link to comment Share on other sites More sharing options...
pdnnoob Posted January 29, 2013 Share Posted January 29, 2013 Another option is to add a new layer, fill it with white, and move it underneath the original. That way, if you erase, you see the white from the bottom layer instead of the transparency checkerboard. Quote what I do all summer Emote Cursor Pack 'noob gallery No, Paint.NET is not spyware...but, installing it is an IQ test. ~BoltBait Blend modes are like the filling in your sandwich. It's the filling that can change your experience of the sandwich. ~Ego Eram Reputo Link to comment Share on other sites More sharing options...
barbieq25 Posted January 29, 2013 Share Posted January 29, 2013 When you first open the program it comes with a white background. If you then add a layer it will still show as white. If the checkerboard wasn't there, how would you know if it was a transparent layer that you ware working on? If the canvas was transparent you would be able to see your desktop. Think of layers like transparent sheets. Quote Knowledge is no burden to carry. April Jones, 2012 Gallery My DA Gallery Link to comment Share on other sites More sharing options...
