Lucida Calligrapy italic does not work
Hi,
when I start with a new image for example and want to insert text of the type Lucida Calligrapy, and then change it to italic it does not change.
In Word or Wordpad it works.
I tested it with the newest version of paint.net on my Windows 7 and my Windows 8 laptop, both the same result.
Regards,
Henrik
Hi - I just tried this and found you need to first pick the italic option in PDN and then type your text.  Don't type the text and then try to change it.
I am working with Windows 7.  I downloaded the font (and then unzipped it and added it to the Font in Windows 7 first) from here using the second post with the zipped file.
This is the result after using it in PDN:
