Steved1 Posted January 14, 2013 Share Posted January 14, 2013 Hi all this is my first post and I am new to Paint.net I am trying to get some text with a transparent background to put on glass as an image in sketchup but am having problems. I have attached an image showing what I ended up with when I made a transparent background However when I export it (as a PNG or Jpeg) it has a white background. Any ideas! Thanks Quote Link to comment Share on other sites More sharing options...
Pixey Posted January 14, 2013 Share Posted January 14, 2013 Hi and Welcome to Paint.NET. From viewing your thumb I can see that you do have a transparent background with your black text, because your background shows checkering. It will look like you have a white background, if you are viewing it on a page that is white. If you view it on a background that is say, red, then you will see that the text will be on a red background. I hope that makes sense? But - this only applies in Paint.NET and if you are transferring the image to another programme you may have encountered compatibility problems. Quote How I made Jennifer & Halle in Paint.net My Gallery | My Deviant Art "Rescuing one animal may not change the world, but for that animal their world is changed forever!" anon. Link to comment Share on other sites More sharing options...
pdnnoob Posted January 14, 2013 Share Posted January 14, 2013 (edited) as a .jpeg image, it will have a white background because .jpeg doesn't support transparency. As a .png image, it will look like it has a white background in the preview, but it's lying to you. It's really transparent. Make sure you save as a .png or another filetype that supports transparency. Edited January 14, 2013 by pdnnoob Quote No, Paint.NET is not spyware...but, installing it is an IQ test. ~BoltBait Blend modes are like the filling in your sandwich. It's the filling that can change your experience of the sandwich. ~Ego Eram Reputo Link to comment Share on other sites More sharing options...
Steved1 Posted January 16, 2013 Author Share Posted January 16, 2013 Thanks guys have taken note will give it another try Quote Link to comment Share on other sites More sharing options...
