Problem with Character edges
Make sure antialiasing is turned on when using the text tool?
For the coloring, you can select all the characters (hint: select the background with the magic wand on low tolerance +Shift key. Then invert the selection with Ctrl + i). Then apply the multicolor gradient plugin.
Antialiasing is turned on.
I tried but the best result is achieved by Photo> Glow
Radius 1
Brightness 10
Contrast 10
Thanks all
LE:
@EER
I don't have the multicolor gradient plugin.
Where is it on this forum?
Ok, I found it. I used this trick:
site:http://forums.getpaint.net multicolor gradient plugin
Now I will test.
LLE:
I'm impressed. This plugin is amazing. Thanks EER!
Edited by klaxxon
