Drawing a line using start point & angle
When I draw a line, is there a way to say, "Start at point (864,0), go exactly 270° down (actually, I can hold down the shift key for that, but I digress...) and end at the other side of the canvas at point (864, 3456)?
A script would probably work well, but I've never dipped into that.
Should this be a separate topic, or can I tack other questions on here? Seems rather small for a separate question.
~Joe
Avoid Sears Home Improvement (click to read why)
It's separate (has no bearing on the original thread title). This means that it should really have its own thread. Edit: I've separated them ;)
In answer: Yes, position the cursor using the information in the Status Bar. When you draw a line the angle is also shown in the Status Bar.
