Make 3D-Stone Text
yellowman
Great tut! A bit complicated, but quite well put together. My example is a slight variation on it as it is now Winter here...
@racerx! A very big thank you for the work. Well done. Thank you.
Gandhi
  • 9 months later...
  • 4 months later...
  • 2 months later...
Try it again. One step at a time. We'll help you if you get stuck.
It helps if you download and print out the PDF so you can refer to it.
