Shoaib Posted October 1, 2012 Share Posted October 1, 2012 I have a png file that is already in rgb565 format. On Paint.Net, i changed this image by completely deleting the background. What format would this image now be considered to be in? Quote Link to comment Share on other sites More sharing options...
Ego Eram Reputo Posted October 1, 2012 Share Posted October 1, 2012 While in Paint.NET it's 32-bit RGBA. When you save it, the file is formatted to whatever you specify. 1 Quote ebook: Mastering Paint.NET | resources: Plugin Index | Stereogram Tut | proud supporter of Codelab plugins: EER's Plugin Pack | Planetoid | StickMan | WhichSymbol+ | Dr Scott's Markup Renderer | CSV Filetype | dwarf horde plugins: Plugin Browser | ShapeMaker Link to comment Share on other sites More sharing options...
Shoaib Posted October 1, 2012 Author Share Posted October 1, 2012 (edited) While in Paint.NET it's 32-bit RGBA. When you save it, the file is formatted to whatever you specify. Thank you! Would you know how i can save a picture as a ARGB4444 format? Edited October 1, 2012 by Shoaib Quote Link to comment Share on other sites More sharing options...
Rick Brewster Posted October 1, 2012 Share Posted October 1, 2012 Not possible. Quote The Paint.NET Blog: https://blog.getpaint.net/ Donations are always appreciated! https://www.getpaint.net/donate.html Link to comment Share on other sites More sharing options...
Ego Eram Reputo Posted October 1, 2012 Share Posted October 1, 2012 Sounds like one of the DDS variants. If it doesn't appear in the list (when saving as a DDS) then, as Rick said, it's not possible. Quote ebook: Mastering Paint.NET | resources: Plugin Index | Stereogram Tut | proud supporter of Codelab plugins: EER's Plugin Pack | Planetoid | StickMan | WhichSymbol+ | Dr Scott's Markup Renderer | CSV Filetype | dwarf horde plugins: Plugin Browser | ShapeMaker Link to comment Share on other sites More sharing options...
Ego Eram Reputo Posted October 1, 2012 Share Posted October 1, 2012 Just checked. Third variant from the bottom of the DDS list is A4R4G4B4 - I'm guessing this is the same. You need to use File | Save As... to open the save dialog then select the DDS extension from the drop down list in that dialog. Specify a filename (and all that) then click OK. When the DDS dialog opens, scroll to the bottom of the list of variants to find the one I indicated. Select it and save. Quote ebook: Mastering Paint.NET | resources: Plugin Index | Stereogram Tut | proud supporter of Codelab plugins: EER's Plugin Pack | Planetoid | StickMan | WhichSymbol+ | Dr Scott's Markup Renderer | CSV Filetype | dwarf horde plugins: Plugin Browser | ShapeMaker Link to comment Share on other sites More sharing options...
