renee27 Posted September 28, 2012 Share Posted September 28, 2012 TWO questions: I asked this before but it didn't load. I downloaded the starglow plug-in into Paint.net program, effects folder. I unzipped it first. It showed up as in there on the Programs folder, but when I went to use it in Paint.net, it isn't listed in the Effects. What did I do wrong? Secondly, I just spent almost an hour making part of a background transparent, including careful detailed erasing. It looked great--unti I saved it and now it's got a white--not transparent background. What can I do to get my transparent background file back--and even joking please don't say do it again!! I've done it twice already. Thanks, I hope. Renee Quote Link to comment Share on other sites More sharing options...
BoltBait Posted September 28, 2012 Share Posted September 28, 2012 Here is a tutorial on how to install Paint.NET plugins: http://www.boltbait.com/pdn/InstallingEffects.php Quote Click to play: Download: BoltBait's Plugin Pack | CodeLab | and how about a Computer Dominos Game Link to comment Share on other sites More sharing options...
jim100361 Posted September 28, 2012 Share Posted September 28, 2012 To maintain transparency you must save it as either gif or png Quote Link to comment Share on other sites More sharing options...
renee27 Posted September 28, 2012 Author Share Posted September 28, 2012 Thank you both. I'll give both your solutions a try. Hopefully I can do it correctly now. Jim, I thought I'd try re-saving the one with the white background as a pdn or gif--or do I have to start all over? Quote Link to comment Share on other sites More sharing options...
renee27 Posted September 28, 2012 Author Share Posted September 28, 2012 PS BoltBait that's the tutorial you sent me before that didn't work because my computer doesn't ask me where I want to download it, it just says do you want to open or save in downloads. Period. No choice offered. And then every place you said to "open" and I told ya'll it wouldn't because it kept asking what program I wanted to use, and then someone said you can't open a dll file. So I quit trying. However, I managed to get the CameraTrousersFlare to the Effects folder and it does show when I go to Paint.net and open a file on the canvas. So I must be doing something right. It's just the StarGlow that won't behave. Quote Link to comment Share on other sites More sharing options...
renee27 Posted September 28, 2012 Author Share Posted September 28, 2012 It worked, Jim. I changed the extension and then it was easy to use the magic wand and erasure to do a fast clean up. thank you for the info. Quote Link to comment Share on other sites More sharing options...
renee27 Posted September 28, 2012 Author Share Posted September 28, 2012 Although I saved it to Effects, I found it in Stylize! And don't know how to get it to show--I know absolutely nothing about settings! Quote Link to comment Share on other sites More sharing options...
Pixey Posted September 29, 2012 Share Posted September 29, 2012 Hi Renee - Yes, this plug-in sits in the Stylize section of the Effects area. It enhances light spots in an image. Below is a' before' and 'after' shot of using starglow. First upload an image with light spots in it. Then go to" starglow", whilst you are "on" the image layer and play with the settings. I used the slider to play with the size of the glows for the example: Mini to 193 Maxi to 255 Radius to 21 The rest at default settings It will be a case of playing with the slider to see the effect. I used a slightly over-the-top setting to see the result. Before After Happy PDNing 1 Quote How I made Jennifer & Halle in Paint.net My Gallery | My Deviant Art "Rescuing one animal may not change the world, but for that animal their world is changed forever!" anon. Link to comment Share on other sites More sharing options...
renee27 Posted September 30, 2012 Author Share Posted September 30, 2012 Thank you, nanette. I copied the settings and will certainly use them! Renee Quote Link to comment Share on other sites More sharing options...
