Generic1 Posted September 7, 2012 Share Posted September 7, 2012 Hi, I have for example this image: An now I will give the text an edge (each letter). Is there a possibility to do this with Paint.net easily. Thanks a lot, Generic <snipped by EER> Quote Link to comment Share on other sites More sharing options...
nitenurse79 Posted September 7, 2012 Share Posted September 7, 2012 Do you mean something like this http://forums.getpaint.net/index.php?showtopic=4923 Part of pyrochild's oscar winning plug-in pack Quote Link to comment Share on other sites More sharing options...
barbieq25 Posted September 7, 2012 Share Posted September 7, 2012 There are a number of ways that you can do this but first: You must have the text on a layer of its own or it will not work. So if you have blue text on a white background you can use Grim Colour Reaper plugin or Clear Background plugin to get rid of it or you can select the background with the magic wand & delete it. Easier to start with the text on a new layer. Also creating the image 4x larger than what you want the end result to be will make it look smoother. 1. Use pyrochild's Outline Object plugin 2. Use Drop Shadow There are other ways too but these are the easiest to do. Let me know how it works out, please? Quote Knowledge is no burden to carry. April Jones, 2012 Gallery My DA Gallery Link to comment Share on other sites More sharing options...
