Spicey54 Posted August 26, 2012 Share Posted August 26, 2012 I love this software, but I am still struggling with my "edges"... I post a picture of the coins and needt to cut around edges... usually wand does get it all and it is time consuming to finish it.. Any help??? Spicey Quote Link to comment Share on other sites More sharing options...
toe_head2001 Posted August 26, 2012 Share Posted August 26, 2012 You can use one of several techniques depending on the specific photo. The best way to receive help would be to post the photo here, otherwise you'll get very generalized advice. Quote My Gallery | My Plugin Pack Layman's Guide to CodeLab Link to comment Share on other sites More sharing options...
Ego Eram Reputo Posted August 26, 2012 Share Posted August 26, 2012 See my answer to your same question here: In addition to that technique you can usually clean up the edges nicely by using AA's assistant or Feather plugins. Quote ebook: Mastering Paint.NET | resources: Plugin Index | Stereogram Tut | proud supporter of Codelab plugins: EER's Plugin Pack | Planetoid | StickMan | WhichSymbol+ | Dr Scott's Markup Renderer | CSV Filetype | dwarf horde plugins: Plugin Browser | ShapeMaker Link to comment Share on other sites More sharing options...
