Xhin Posted August 4, 2012 Share Posted August 4, 2012 I'm curious how the quality slider of some plugins and built-in effects works. I read somewhere that it had something to do with a gaussian blur, but I'm not sure what you do with it exactly. Can anyone clarify? Quote Link to comment Share on other sites More sharing options...
Rick Brewster Posted August 4, 2012 Share Posted August 4, 2012 Gaussian Blur? No. For the built-in effects, at least, quality affects how many samples are calculated for each output pixel. It's a non-linear relationship though between the quality value and # of samples. The samples are then blended together. It's just like your typical GeForce's MSAA (multi-sample anti-aliasing). Quote The Paint.NET Blog: https://blog.getpaint.net/ Donations are always appreciated! https://www.getpaint.net/donate.html Link to comment Share on other sites More sharing options...
Rick Brewster Posted August 4, 2012 Share Posted August 4, 2012 Oh, and further explanation. Multisampling works for those effects because they are essentially mathematical functions defined on the set of real numbers (not just at integer pixel coordinates). Multisampling works by taking >1 sample of that mathematical function at various locations within each pixel (e.g. [x+0.25,y+0.75], [x+0.75, y+0.25], etc). Then those samples are averaged (blended) to calculate the final output value. 1 Quote The Paint.NET Blog: https://blog.getpaint.net/ Donations are always appreciated! https://www.getpaint.net/donate.html Link to comment Share on other sites More sharing options...
Xhin Posted August 5, 2012 Author Share Posted August 5, 2012 Is there a way of tapping into that native multisampling algorithm, or would I have to calculate it manually if I wanted to build a plugin with a quality control? I might be going about this the wrong way though, what I'm looking to do is to rotate part of an image an arbitrary number of degrees without messing up its quality. I figured something like whatever the quality slider or anti-aliasing tool did would work to fix jagged edges and whatnot. I appreciate your help. Also, just curious, why are the quality sliders limited to 5? What does the quality number actually mean? Quote Link to comment Share on other sites More sharing options...
midora Posted August 5, 2012 Share Posted August 5, 2012 A 'quality' slider is just a control which returns a value. You have to define what the return value is used for. As Rick said, in most cases it just tells that the algorithm will do a more precise calculation of the final pixels. But this means if you like to get more quality then it takes a lot more time to do the calculation (sometimes minutes or hours). Quote Link to comment Share on other sites More sharing options...
AhmedElyamani Posted September 3, 2012 Share Posted September 3, 2012 if you need some simple smoothness effect you can simple pick the color of the surrounding pixels of each pixel and use the average as your pixel color . this actually simulates Paint.NET's built-in Median effect , and it gives a nice smooth for your effects . this might be coded like so: ColorBgra CurrentPixel,pxl1,pxl2,pxl3,pxl4,pxl5,pxl6,pxl7,pxl8; CurrentPixel = src[x,y]; pxl1= src[Math.Min(x+1,rect.Right-1),y]; pxl2= src[Math.Max(x-1,rect.Left),y]; pxl3= src[x,Math.Min(y+1,rect.Bottom-1)]; pxl4= src[x,Math.Max(y-1,rect.Top)]; pxl5= src[Math.Min(x+1,rect.Right-1),Math.Min(y+1,rect.Bottom-1)]; pxl6= src[Math.Min(x+1,rect.Right-1),Math.Max(y-1,rect.Top)]; pxl7= src[Math.Max(x-1,rect.Left),Math.Min(y+1,rect.Bottom-1)]; pxl8= src[Math.Max(x-1,rect.Left),Math.Max(y-1,rect.Top)]; CurrentPixel.R=(byte)((CurrentPixel.R+pxl1.R+pxl2.R+pxl3.R+pxl4.R+pxl5.R+pxl6.R+pxl7.R+pxl8.R)/9); CurrentPixel.G=(byte)((CurrentPixel.G+pxl1.G+pxl2.G+pxl3.G+pxl4.G+pxl5.G+pxl6.G+pxl7.G+pxl8.G)/9); CurrentPixel.B=(byte)((CurrentPixel.B+pxl1.B+pxl2.B+pxl3.B+pxl4.B+pxl5.B+pxl6.B+pxl7.B+pxl8.B)/9); Hope you find this helpful . Ahmed. Quote Link to comment Share on other sites More sharing options...
BoltBait Posted September 4, 2012 Share Posted September 4, 2012 How does "Quality" work? Deep question. Perhaps you should read the book Zen and the Art of Motorcycle Maintenance. 1 Quote Click to play: Download: BoltBait's Plugin Pack | CodeLab | and how about a Computer Dominos Game Link to comment Share on other sites More sharing options...
Rick Brewster Posted September 4, 2012 Share Posted September 4, 2012 if you need some simple smoothness effect you can simple pick the color of the surrounding pixels of each pixel and use the average as your pixel color . this actually simulates Paint.NET's built-in Median effect , and it gives a nice smooth for your effects . Unfortunately that has absolutely nothing in common with the multisampling algorithm which is configured via the "Quality" slider. (Fortunately that doesn't imply your idea is worthless or anything, that's not what I mean) What you describe is essentially a smoothing effect accomplished with post-processing, which reminds me a bit of FXAA or Quincunx. Multisampling works by gathering samples within the same pixel. Without it you get all the shimmering artifacts typically associated with Nearest Neighbor resampling when you shrink an image (and, in fact, they are the exact same thing). 1 Quote The Paint.NET Blog: https://blog.getpaint.net/ Donations are always appreciated! https://www.getpaint.net/donate.html Link to comment Share on other sites More sharing options...
AhmedElyamani Posted September 5, 2012 Share Posted September 5, 2012 Unfortunately that has absolutely nothing in common with the multisampling algorithm which is configured via the "Quality" slider. (Fortunately that doesn't imply your idea is worthless or anything, that's not what I mean) What you describe is essentially a smoothing effect accomplished with post-processing, which reminds me a bit of FXAA or Quincunx. Multisampling works by gathering samples within the same pixel. Without it you get all the shimmering artifacts typically associated with Nearest Neighbor resampling when you shrink an image (and, in fact, they are the exact same thing). wait , you meant smoothing works on each pixel ? can you link me to a wikipedia topic, please ? Quote Link to comment Share on other sites More sharing options...
Rick Brewster Posted September 5, 2012 Share Posted September 5, 2012 Smoothing and multisampling aren't the same. Just look it up... you know, type in "multisampling" into a search engine and then hit enter Which one can be used depends on the fundamental algorithm of your effect. 1 Quote The Paint.NET Blog: https://blog.getpaint.net/ Donations are always appreciated! https://www.getpaint.net/donate.html Link to comment Share on other sites More sharing options...
AhmedElyamani Posted September 5, 2012 Share Posted September 5, 2012 Thankyou ! o'll sure give it a try later . Quote Link to comment Share on other sites More sharing options...
timoti Posted May 24, 2013 Share Posted May 24, 2013 Hi Rick, Thanks for the detailed info. If you are using MSAA, can you please tell me if your implementation is regular grid, sparse regular grid or stochastic sample patterns? Also when you said "within the same pixel", I am not sure what you mean because by adding offsets less than 1 to the original integer pixel coordinate, are you not crossing into the other pixels? Or do you mean it's within 1 pixel range so it's not like smoothing algorithms which use a larger radius and therefore the average gets more blurry? Also another thing that confuse me is, is it not better to use all float coordinates [0..1] instead of integer pixel coordinates which makes adding of floating point offsets more complex? Thanks again. Quote Link to comment Share on other sites More sharing options...
