Transparent Background not clean
I have been working on making this have a transparent background, (everything outside the blue ring, except where the feather goes outside the blue box). When I use the magic wand and delete the background, it has very jagged edges and a lot of pixels that don't clean up. I tried using the eraser to clean them up, but it looks awful. I read in some of the posts to try feathering it, but I don't know how to do that. I tried selecting the blue ring and feathering but didn't see where that helped. I would appreciate any other suggestions. Thanks.
Your image has not shown up - so we're guessing a little.
I'd recommend trying the AA's Assistant plugin. This will work well to clean up those edges if the surrounding is transparent.
You can find the plugin here: dpy's Pack
