first problem. need help
This is the first problem I've had. Earlier today(july 15) I had been using it to edit photos, then I exited when I was done. After an hour or so I needed to edit another photo and when I clicked on it it said that it had crashed. [The pdncrash.log file will be included at the end] I was confused and should of asked for help then but instead I uninstalled it, restarted my computer, and then tried to re-install. I got a null error report thing and was not able to even re-install. So yeah, I need help. Both the crash log and the null report below.
null report while trying to re-install: post-91036-0-10841500-1342442167_thumb.p (click for bigger size)
crash log:
Please e-mail this file to crashlog@getpaint.net so we can diagnose and fix the problem.
Application version: Paint.NET v3.5.10 (Final Release build 3.510.4297.28964)
Time of crash: 7/15/2012 10:35:17 PM
Application uptime: 00:00:04.1550000
Install directory: C:\Program Files\Paint.NET
OS Version: 6.0.6002.131072 Service Pack 2 Workstation x86
.NET version: CLR 2.0.50727.4223 x86, FX 2.0 (rtm sp1 sp2) 3.0 (rtm sp1 sp2) 3.5 (rtm sp1 sp1_CP) 4.0 (rtm)
Processor: 2x "AMD Athlon™ 64 X2 Dual Core Processor 4400+" @ ~2310MHz (DEP, SSE, SSE2, SSE3), fps=0x1
Physical memory: 2941 MB
UI Theme: Aero/Aero (Aero.msstyles)
Updates: true, 7/12/2012
Locale: pdnr.c: en-US, hklm: en-US, hkcu: n/a, cc: en-US, cuic: en-US
Managed assemblies:
mscorlib, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089 @ C:\Windows\Microsoft.NET\Framework\v2.0.50727\mscorlib.dll
PaintDotNet, Version=3.510.4297.28970, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\PaintDotNet.exe
PaintDotNet.Base, Version=3.510.4297.28957, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\PaintDotNet.Base.dll
System, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089 @ C:\Windows\assembly\GAC_MSIL\System\2.0.0.0__b77a5c561934e089\System.dll
WindowsBase, Version=3.0.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35 @ C:\Windows\assembly\GAC_MSIL\WindowsBase\3.0.0.0__31bf3856ad364e35\WindowsBase.dll
System.Windows.Forms, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089 @ C:\Windows\assembly\GAC_MSIL\System.Windows.Forms\2.0.0.0__b77a5c561934e089\System.Windows.Forms.dll
System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a @ C:\Windows\assembly\GAC_MSIL\System.Drawing\2.0.0.0__b03f5f7f11d50a3a\System.Drawing.dll
System.Core, Version=3.5.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089 @ C:\Windows\assembly\GAC_MSIL\System.Core\3.5.0.0__b77a5c561934e089\System.Core.dll
PaintDotNet.Core, Version=3.510.4297.28965, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\PaintDotNet.Core.dll
PaintDotNet.SystemLayer, Version=3.510.4297.28964, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\PaintDotNet.SystemLayer.dll
PaintDotNet.Resources, Version=3.510.4297.28964, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\PaintDotNet.Resources.dll
PaintDotNet.Data, Version=3.510.4297.28969, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\PaintDotNet.Data.dll
Native modules:
C:\Program Files\Paint.NET\PaintDotNet.exe, version='3.510.4297.28970'
C:\Windows\system32\ntdll.dll, version='6.0.6001.18000 (longhorn_rtm.080118-1840)'
C:\Windows\system32\mscoree.dll, version='4.0.31106.0 (Main.031106-0000)'
C:\Windows\system32\KERNEL32.dll, version='6.0.6001.18000 (longhorn_rtm.080118-1840)'
C:\Windows\system32\ADVAPI32.dll, version='6.0.6002.18005 (lh_sp2rtm.090410-1830)'
C:\Windows\system32\RPCRT4.dll, version='6.0.6001.18000 (longhorn_rtm.080118-1840)'
C:\Windows\Microsoft.NET\Framework\v4.0.30319\mscoreei.dll, version='4.0.30319.237 (RTMGDR.030319-2300)'
C:\Windows\system32\SHLWAPI.dll, version='6.0.6000.16386 (vista_rtm.061101-2205)'
C:\Windows\system32\GDI32.dll, version='6.0.6002.18005 (lh_sp2rtm.090410-1830)'
C:\Windows\system32\USER32.dll, version='6.0.6001.18000 (longhorn_rtm.080118-1840)'
C:\Windows\system32\msvcrt.dll, version='7.0.6002.18551 (vistasp2_gdr.111214-0301)'
C:\Windows\system32\IMM32.DLL, version='6.0.6002.18005 (lh_sp2rtm.090410-1830)'
C:\Windows\system32\MSCTF.dll, version='6.0.6000.16386 (vista_rtm.061101-2205)'
C:\Windows\system32\LPK.DLL, version='6.0.6002.18051 (vistasp2_gdr.090615-0258)'
C:\Windows\system32\USP10.dll, version='1.0626.6002.18244 (vistasp2_gdr.100416-0345)'
C:\Windows\WinSxS\x86_microsoft.windows.common-controls_6595b64144ccf1df_6.0.6002.18305_none_5cb72f2a088b0ed3\comctl32.dll, version='6.10 (longhorn_rtm.080118-1840)'
C:\Windows\Microsoft.NET\Framework\v2.0.50727\mscorwks.dll, version='2.0.50727.4223 (VistaSP2GDR.050727-4200)'
C:\Windows\WinSxS\x86_microsoft.vc80.crt_1fc8b3b9a1e18e3b_8.0.50727.6195_none_d09154e044272b9a\MSVCR80.dll, version='8.00.50727.6195'
C:\Windows\system32\shell32.dll, version='6.0.6001.18000 (longhorn_rtm.080118-1840)'
C:\Windows\system32\ole32.dll, version='6.0.6000.16386 (vista_rtm.061101-2205)'
C:\Windows\assembly\NativeImages_v2.0.50727_32\mscorlib\af9c9e9d7e0523cd444f8b551baa9cbf\mscorlib.ni.dll, version='2.0.50727.4223 (VistaSP2GDR.050727-4200)'
C:\Windows\system32\uxtheme.dll, version='6.0.6000.16386 (vista_rtm.061101-2205)'
C:\Windows\assembly\NativeImages_v2.0.50727_32\System\28d633338fc8d29f8af31935ef7d001b\System.ni.dll, version='2.0.50727.4223 (VistaSP2GDR.050727-4200)'
C:\Windows\assembly\NativeImages_v2.0.50727_32\System.Core\0f2b877ed16daa577f95be735a63d19c\System.Core.ni.dll, version='3.5.30729.1 built by: SP'
C:\Windows\assembly\NativeImages_v2.0.50727_32\WindowsBase\54426ee1881b42af5b090e223f43823c\WindowsBase.ni.dll, version='3.0.6920.4213 built by: VistaSP2GDR'
C:\Windows\assembly\NativeImages_v2.0.50727_32\System.Drawing\18f9789aa214c657113e676b3a9015aa\System.Drawing.ni.dll, version='2.0.50727.4230 (VistaSP2GDR.050727-4200)'
C:\Windows\assembly\NativeImages_v2.0.50727_32\System.Windows.Forms\f2691cfa7671cdc58179e56ba9227591\System.Windows.Forms.ni.dll, version='2.0.50727.4228 (VistaSP2GDR.050727-4200)'
C:\Windows\assembly\NativeImages_v2.0.50727_32\PaintDotNet.Base\72b91068ac38e5a698a17ec85c003924\PaintDotNet.Base.ni.dll, version='3.510.4297.28957'
C:\Windows\assembly\NativeImages_v2.0.50727_32\PaintDotNet.SystemL#\e4b759769273f7d5c0c005a8b1c6573f\PaintDotNet.SystemLayer.ni.dll, version='3.510.4297.28964'
C:\Windows\assembly\NativeImages_v2.0.50727_32\PaintDotNet.Resourc#\10c1cc0f39c6124d9f04454fabd15fb3\PaintDotNet.Resources.ni.dll, version='3.510.4297.28964'
C:\Windows\system32\rsaenh.dll, version='6.0.6002.18005 (lh_sp2rtm.090410-1830)'
C:\Windows\assembly\NativeImages_v2.0.50727_32\PaintDotNet.Core\d0478808dc4e6cfa5668ef45ca76111e\PaintDotNet.Core.ni.dll, version='3.510.4297.28965'
C:\Windows\assembly\NativeImages_v2.0.50727_32\PaintDotNet.Data\9c8914b20caa7fabcef0d91a4fba8468\PaintDotNet.Data.ni.dll, version='3.510.4297.28969'
C:\Windows\assembly\NativeImages_v2.0.50727_32\PaintDotNet\050b8351b32406288a452fde98d0a38d\PaintDotNet.ni.exe, version='3.510.4297.28970'
C:\Windows\assembly\NativeImages_v2.0.50727_32\PaintDotNet.SystemL#\85e6a3d8972e4477a140cfaed74b5727\PaintDotNet.SystemLayer.Native.x86.ni.dll, version='3.510.0.0'
C:\Windows\assembly\NativeImages_v2.0.50727_32\Interop.WIA\3de41f22b0c4cdc1e8f07ac5af4be42c\Interop.WIA.ni.dll, version='1.0.0.0'
C:\Windows\assembly\NativeImages_v2.0.50727_32\PaintDotNet.Effects\5129c69b6b3b62bdd83917c7f89f0864\PaintDotNet.Effects.ni.dll, version='3.510.4297.28970'
C:\Program Files\Paint.NET\Native.x86\PaintDotNet.Native.x86.dll, version='3.510.0.0'
C:\Windows\WinSxS\x86_microsoft.vc90.crt_1fc8b3b9a1e18e3b_9.0.30729.6161_none_50934f2ebcb7eb57\MSVCR90.dll, version='9.00.30729.6161'
C:\Windows\WinSxS\x86_microsoft.vc90.openmp_1fc8b3b9a1e18e3b_9.0.30729.6161_none_80ba6c811e9b4aff\VCOMP90.DLL, version='9.00.30729.6161 built by: QFE'
C:\Windows\WinSxS\x86_microsoft.windows.gdiplus_6595b64144ccf1df_1.0.6002.18581_none_9e591052ca1013d0\gdiplus.dll, version='5.2.6002.18581 (vistasp2_gdr.120203-0237)'
C:\Windows\system32\version.dll, version='6.0.6002.18005 (lh_sp2rtm.090410-1830)'
C:\Windows\system32\SetupApi.dll, version='6.0.6001.18000 (longhorn_rtm.080118-1840)'
C:\Windows\system32\OLEAUT32.dll, version='6.0.6002.18508'
C:\Windows\system32\WINTRUST.dll, version='6.0.6002.18592 (vistasp2_gdr.120229-0238)'
C:\Windows\system32\CRYPT32.dll, version='6.0.6002.18618 (vistasp2_gdr.120423-0338)'
C:\Windows\system32\MSASN1.dll, version='6.0.6002.18106 (vistasp2_gdr.090903-2340)'
C:\Windows\system32\USERENV.dll, version='6.0.6000.16386 (vista_rtm.061101-2205)'
C:\Windows\system32\Secur32.dll, version='6.0.6002.18541 (vistasp2_gdr.111116-0305)'
C:\Windows\system32\imagehlp.dll, version='6.0.6002.18592 (vistasp2_gdr.120229-0238)'
C:\Windows\system32\dwmapi.dll, version='6.0.6001.18000 (longhorn_rtm.080118-1840)'
C:\Windows\system32\psapi.dll, version='6.0.6000.16386 (vista_rtm.061101-2205)'
Exception details:
System.AccessViolationException: Attempted to read or write protected memory. This is often an indication that other memory is corrupt.
at System.Drawing.SafeNativeMethods.Gdip.GdipCreateFontFromLogfontW(HandleRef hdc, Object lf, IntPtr& font)
at System.Drawing.Font.FromLogFont(Object lf, IntPtr hdc)
at System.Drawing.Font.FromHfont(IntPtr hfont)
at System.Drawing.SystemFonts.get_DefaultFont()
at System.Windows.Forms.Control.get_DefaultFont()
at System.Windows.Forms.Control.get_Font()
at System.Windows.Forms.Control.AssignParent(Control value)
at System.Windows.Forms.Control.ControlCollection.Add(Control value)
at System.Windows.Forms.Form.ControlCollection.Add(Control value)
at PaintDotNet.PdnBaseForm..ctor() in D:\src\pdn\pdn_35x\src\Core\PdnBaseForm.cs:line 993
at PaintDotNet.Dialogs.MainForm..ctor(String[] args) in D:\src\pdn\pdn_35x\src\PaintDotNet\Dialogs\MainForm.cs:line 293
at PaintDotNet.Startup.StartPart4(String mutexName) in D:\src\pdn\pdn_35x\src\PaintDotNet\Startup.cs:line 428
at PaintDotNet.Startup.StartPart3() in D:\src\pdn\pdn_35x\src\PaintDotNet\Startup.cs:line 377
at PaintDotNet.Startup.StartPart2() in D:\src\pdn\pdn_35x\src\PaintDotNet\Startup.cs:line 358
at PaintDotNet.Startup.Start() in D:\src\pdn\pdn_35x\src\PaintDotNet\Startup.cs:line 271
at PaintDotNet.Startup.Main(String[] args) in D:\src\pdn\pdn_35x\src\PaintDotNet\Startup.cs:line 465
Time of crash: 7/15/2012 10:35:31 PM
Application uptime: 00:00:00.8530000
Managed assemblies:
Native modules:
Exception details:
Time of crash: 7/15/2012 10:37:38 PM
Application uptime: 00:00:02.4680000
Managed assemblies:
Native modules:
Exception details:
Time of crash: 7/15/2012 10:39:00 PM
Application uptime: 00:00:00.7360000
Managed assemblies:
Native modules:
Exception details:
Time of crash: 7/15/2012 10:52:34 PM
Application uptime: 00:00:00.8900000
Managed assemblies:
Native modules:
Exception details:
Time of crash: 7/15/2012 10:57:09 PM
Application uptime: 00:00:00.8070000
Managed assemblies:
Native modules:
Exception details:
Time of crash: 7/16/2012 2:39:00 AM
Application uptime: 00:00:01.4250000
Managed assemblies:
Native modules:
Exception details:
Time of crash: 7/16/2012 3:21:19 AM
Application uptime: 00:00:00.6820000
Managed assemblies:
Native modules:
Exception details:
What midora said :) You may have success running something called SFC (System File Checker). It's a bit arcane, but here's how to do it ...
1. Press the Windows key or click the Start menu/pearl
2. Type CMD and then press Ctrl+Shift+Enter (this will allow it to run with administrator privilege, which SFC requires)
3. Click yes/continue/whatever on the security prompt if it shows up (UAC)
Now you're at the command-line. Be careful, but no need to be scared.
4. To get your bearings, type "sfc /?" (without quotes) and press enter
5. Next, type "sfc /VERIFYONLY" (without quotes) and press enter
6. Wait awhile ...
7. If it displays any errors you will then want to type "sfc /SCANNOW" (without quotes) and then press enter
8. Wait awhile ...
(Technically, steps 4-6 are optional)
If that doesn't help, you will want to find another computer that's running Windows Vista and copy their C:\Windows\FONTS directory into your C:\WIndows\FONTS directory.
Also, I recommend running "chkdsk". You can either brave the command line for this, or do it through My Computer like so:
1. Press Windows Key + E to bring up Windows Explorer. It should already be parked at "My Computer".
2. Right click on your hard drive (it should have a "(C:)" suffix) and click Properties in the menu that comes up
3. Click on the tab named "Tools"
4. There should be a section called "Error checking" with a button labeled "Check now...". Click on the button.
5. Another small dialog will pop up. Click on the "Start" button. You may have to restart your computer to perform the scan, during which you won't be able to use your computer for other stuff. It will tell you if this is necessary.
I did both the SFC and chkdsk but it didn't help. Whatever is wrong is affecting other parts of my computer too. I can't open any of my other editing programs and whatever Windows Defender User Interface is isn't not working. How would I copy someone else's C:\Windows\FONTS directory to mine?
