HorseofDestiny Posted July 12, 2012 Share Posted July 12, 2012 Is there a way to scroll using arrow keys (or any other keys) because it drives me crazy when Im zoomed in to a picture to edit some small detail and i go to use the arow keys to scroll to another spot and I end up moving my mouse across the screen. It is also tiresome that i have to keep going over to the scroll bar to get to see a different part of my image. Please tell me if you know of any way. Thanks a bunch Quote Link to comment Share on other sites More sharing options...
Ego Eram Reputo Posted July 12, 2012 Share Posted July 12, 2012 You want to pan the zoomed image without losing the current pointer location? I'm not sure if this is what you want: Any tool can be used to pan the image (except Text tool). Hold down the spacebar + Click and drag. Another option is to hit the H key (for Pan) then the arrow keys might work (I'm not able to try this as I type it). With Pan active, you can scroll with the mouse wheel. Try it with the Shift key to change the direction. Quote ebook: Mastering Paint.NET | resources: Plugin Index | Stereogram Tut | proud supporter of Codelab plugins: EER's Plugin Pack | Planetoid | StickMan | WhichSymbol+ | Dr Scott's Markup Renderer | CSV Filetype | dwarf horde plugins: Plugin Browser | ShapeMaker Link to comment Share on other sites More sharing options...
HorseofDestiny Posted July 13, 2012 Author Share Posted July 13, 2012 That helps thanks Quote Link to comment Share on other sites More sharing options...
