rockwood Posted June 25, 2012 Share Posted June 25, 2012 Using: Paint.NET v3.5.10 (Final Release build 3.510.4297.28964) Select a rectangular area Effects -> Blurs -> Gaussian Blur -> Radius 6 Select Round Rectangle Tool Cursor changes to cross with rounded rectangle but it will not draw. However if you do this in reverse order i.e. select round rectangle, blur it is ok. Quote Link to comment Share on other sites More sharing options...
Rick Brewster Posted June 25, 2012 Share Posted June 25, 2012 Are you trying to draw inside or outside of the selection you drew in step 1? Drawing is always clipped to the selected area. Quote The Paint.NET Blog: https://blog.getpaint.net/ Donations are always appreciated! https://www.getpaint.net/donate.html Link to comment Share on other sites More sharing options...
rockwood Posted June 26, 2012 Author Share Posted June 26, 2012 I was attempting to draw outside. I've re-tried my scenario and can see it does draw as you mention in the selected area. I guess this was not obvious as when you open a fresh image hence with no selection it will draw the rounded rectangle where-ever the cursor is. Quote Link to comment Share on other sites More sharing options...
jim100361 Posted June 26, 2012 Share Posted June 26, 2012 (edited) If I'm understanding this correctly, you want to blur outside the selection then what you need to do is invert the selection. The blur is going to apply to the area you are selecting, so once you select the rectangled area press Ctrl + I to invert the selection and then apply the blur. This should leave the previously selected area intact and apply it to the selected area. EDIT: The below demonstrates that the garage door was first selected, then the selection was inverted and blur is being applied to the newly selected (inverted) area: Edited June 26, 2012 by jim100361 Quote Link to comment Share on other sites More sharing options...
rockwood Posted June 29, 2012 Author Share Posted June 29, 2012 No Jim100361, I was blurring some sensitive data in an image for a user manual, then I wanted to highlight an important section of the image in the non blured area. So step 1 I blurred the sensitive data, step 2 I attempted to draw a red rectangle around the completely seperate important information. As Rick Brewster mentioned the selection I made for the blur remained active when I tried to draw the rectangle. Reversing my process to drawing the rectangle 1st then moving onto bluring the data solved the problem. Quote Link to comment Share on other sites More sharing options...
Ego Eram Reputo Posted June 30, 2012 Share Posted June 30, 2012 Blurring is a mathematical function. Clever people can reconstruct the image. I heartily recommend you don't just blur sensitive data to stop viewers seeing it. Instead, remove the sensitive bits completely then replace with garbage - then blur it Quote ebook: Mastering Paint.NET | resources: Plugin Index | Stereogram Tut | proud supporter of Codelab plugins: EER's Plugin Pack | Planetoid | StickMan | WhichSymbol+ | Dr Scott's Markup Renderer | CSV Filetype | dwarf horde plugins: Plugin Browser | ShapeMaker Link to comment Share on other sites More sharing options...
