avim1968 Posted May 17, 2012 Share Posted May 17, 2012 Hi I'm working now on a project with canvas size A4 (5600x4200) i'm working with large objects and small objects each in its own layer. i wanted to align few object in a certain way and i wanted to use the grid for this. however the grid is so small and can only be seen using 66% and more zoom in. which makes it impossible to align the object since i can't see all of them together. is there any way to adjust the grid to be in proportion to the correct zoom or not window ? as a workaround i found is the grid plugin , but with it i must recreate the grid for each zoom size and its hard to work like this. having the grid adjusted automatically or at least allow max/min setting for it so it can be seen in an A4 size canvas. would be great help. Avi Quote "DDAP=Don't Drink And Post!" :-) Link to comment Share on other sites More sharing options...
Rick Brewster Posted May 17, 2012 Share Posted May 17, 2012 It's not an adjustable grid. It's only meant to give a grid for pixel editing, which is why it's called View -> Pixel grid. Solution is what you've already found -- using a plugin or something to create an extra layer that has the grid you need. Quote The Paint.NET Blog: https://blog.getpaint.net/ Donations are always appreciated! https://www.getpaint.net/donate.html Link to comment Share on other sites More sharing options...
