ejdewan Posted May 6, 2012 Share Posted May 6, 2012 Is it possible to "reactivate" a line segment or curve after you have moved on and finalized the curve? For example, I go off to a corner and draw a small piece, and then shift it to its desired position in the main part of the drawing. However, I need to make a small adjustment by grabbing the end handle and shifting it a little. How do I get the handles to appear again, or is that information lost in the bitmap? (I am used to drawing programs where each object is preserved for all time, and can be reactivated simply by clicking on it.) Of course, I should probably draw the object in place, and do the tweaking before hitting Enter. Quote Link to comment Share on other sites More sharing options...
BoltBait Posted May 6, 2012 Share Posted May 6, 2012 Once a shape is finalized it becomes part of the bitmap. You may want to try a program called Inkscape. Quote Click to play: Download: BoltBait's Plugin Pack | CodeLab | and how about a Computer Dominos Game Link to comment Share on other sites More sharing options...
ejdewan Posted May 7, 2012 Author Share Posted May 7, 2012 I tried Inkscape, and it's a lovely package -- just what I had in mind. Thanks for the tip. Quote Link to comment Share on other sites More sharing options...
