cryocat Posted April 13, 2012 Share Posted April 13, 2012 Hey guys, I'm very new to paint, been completing a few of the tutorials (mainly text so far) and i've been searching for a way to do an icy/cold/frosty type of text look (and background maybe). Haven't had any luck with any of the searches so far (althoug there is a thousand different ways to do fire text haha). Anyone know of any tutorials? Quote Link to comment Share on other sites More sharing options...
Ego Eram Reputo Posted April 14, 2012 Share Posted April 14, 2012 This should get you started: Quote ebook: Mastering Paint.NET | resources: Plugin Index | Stereogram Tut | proud supporter of Codelab plugins: EER's Plugin Pack | Planetoid | StickMan | WhichSymbol+ | Dr Scott's Markup Renderer | CSV Filetype | dwarf horde plugins: Plugin Browser | ShapeMaker Link to comment Share on other sites More sharing options...
cryocat Posted April 14, 2012 Author Share Posted April 14, 2012 Hhhmmmm thanks for the reply. I created this from it but not really the look I was after. Will keep looking i guess Quote Link to comment Share on other sites More sharing options...
pdnnoob Posted April 14, 2012 Share Posted April 14, 2012 I wrote a tutorial a while back...hope it helps Quote what I do all summer Emote Cursor Pack 'noob gallery No, Paint.NET is not spyware...but, installing it is an IQ test. ~BoltBait Blend modes are like the filling in your sandwich. It's the filling that can change your experience of the sandwich. ~Ego Eram Reputo Link to comment Share on other sites More sharing options...
cryocat Posted April 15, 2012 Author Share Posted April 15, 2012 Hey pdnnoob, Thanks for the reply. That is more the look i'm after, will play around with it and see what i can come up with Quote Link to comment Share on other sites More sharing options...
jim100361 Posted April 15, 2012 Share Posted April 15, 2012 http://i114.photobucket.com/albums/n264/CantaLibra/WinterChill.png The above was something I was toying with awhile ago. I created the letters using the glass text with fill tutorial (less the fill) and then used the smudge plugin to create icicles on the lettering. The snow caps were made on another layer also utilizing the smudge plugin. The snow caps were simply white bars with light blue highlights. Smudge Plugin: http://forums.getpai...showtopic=10634 Glass/Fill Tutorial: http://forums.getpai...t-with-filling/ I hope this helps Quote Link to comment Share on other sites More sharing options...
