SilverTrove Posted April 6, 2012 Posted April 6, 2012 I have been searching through previous threads and trying to fix my problems with Paint.NET to no avail. I just installed it a couple of days ago and it worked fine on the first file I opened but became unresponsive after that. I had to restart my computer to work on another image file. After reading another thread, I realized that I didn't save the install file. It's so hard to know which installers I need to save and which I can just run, but anyway, I tried downloading and using Windows Install Cleanup as instructed. After that, I could still open Paint.NET as if it was still on my computer, but when I went to Add/Remove Programs, it wasn't there. I tried searching for any Paint.NET files and removing all the empty folders manually and then reinstalling it but I get the fatal eror 1603 at the installer. What do I need to do? I would appreciate a very basic step-by-step explanation, if possible, because I am not a very technical-minded person. Once I get the software installed and working properly, I can usually figure out how to use it. Thanks in advance for any help you can give. Quote
Ego Eram Reputo Posted April 7, 2012 Posted April 7, 2012 Try here: http://forums.getpai...uble-read-this/ Post #10. There was a discussion recently on the same subject: Quote ebook: Mastering Paint.NET | resources: Plugin Index | Stereogram Tut | proud supporter of Codelab plugins: EER's Plugin Pack | Planetoid | StickMan | WhichSymbol+ | Dr Scott's Markup Renderer | CSV Filetype | dwarf horde plugins: Plugin Browser | ShapeMaker
