relachs Posted February 12, 2012 Share Posted February 12, 2012 (edited) Hey guys, currently I'm working on a picture that consists of many other pictures and their layers. Now, if I want to cut edges of pictures with the same angle, it would be great to see the angle in the lasso mode. Sometimes this can also be handy when selecting rects. Can you implement this or is it already possible? edit: How can I move more than 1 layer at the same time? edit: When saving/reopeneing the project, the pictures in the layers loose their original pixels, so I cannot resize them to their original width/height wihtout losing quality. What can I do about that? I.e. I think a picture needs to be bigger I have to delete it and reimport it?? Edited February 12, 2012 by relachs Quote Link to comment Share on other sites More sharing options...
Rick Brewster Posted February 12, 2012 Share Posted February 12, 2012 How would you define the angle for an arbitrary polygon? I'm afraid what you're asking doesn't make sense ... Quote The Paint.NET Blog: https://blog.getpaint.net/ Donations are always appreciated! https://www.getpaint.net/donate.html Link to comment Share on other sites More sharing options...
relachs Posted February 12, 2012 Author Share Posted February 12, 2012 How would you define the angle for an arbitrary polygon? I'm afraid what you're asking doesn't make sense ... I mean the angle of the line of the lasso Quote Link to comment Share on other sites More sharing options...
Ego Eram Reputo Posted February 12, 2012 Share Posted February 12, 2012 To cut the edge off (at an angle) for multiple layers: 1. Create a new layer 2. Fill in the area that you wish to leave behind with an arbitrary color - leaving the cut off area transparent 3. Activate the Magic Wand tool 4. Click on the transparent area (to select it) and press Ctrl + C to copy it to the clipboard. 5. Click on each layer in turn and press Ctrl + V to paste the transparent selection to the layer. Repeat this for all layers. RE: Moving multiple layers simultaneously: You can't. What you can do is use the Pannelling Plugin to make the 'move' and then repeat the effect (Ctrl + F) after selecting another layer. Repeat for all layers you need to move. RE: Losing pixels. When importing an image you can only move it around until you commit it to the layer. Once the image is committed to the layer, its size is fixed (cropped to the layer). This is not something that is done when saving/reopening. Quote ebook: Mastering Paint.NET | resources: Plugin Index | Stereogram Tut | proud supporter of Codelab plugins: EER's Plugin Pack | Planetoid | StickMan | WhichSymbol+ | Dr Scott's Markup Renderer | CSV Filetype | dwarf horde plugins: Plugin Browser | ShapeMaker Link to comment Share on other sites More sharing options...
Rick Brewster Posted February 12, 2012 Share Posted February 12, 2012 If you need a tool to measure an angle, use the Line/Curve tool. It'll print the angle in the status bar. Quote The Paint.NET Blog: https://blog.getpaint.net/ Donations are always appreciated! https://www.getpaint.net/donate.html Link to comment Share on other sites More sharing options...
relachs Posted February 13, 2012 Author Share Posted February 13, 2012 To cut the edge off (at an angle) for multiple layers: 1. Create a new layer 2. Fill in the area that you wish to leave behind with an arbitrary color - leaving the cut off area transparent 3. Activate the Magic Wand tool 4. Click on the transparent area (to select it) and press Ctrl + C to copy it to the clipboard. 5. Click on each layer in turn and press Ctrl + V to paste the transparent selection to the layer. Repeat this for all layers. RE: Moving multiple layers simultaneously: You can't. What you can do is use the Pannelling Plugin to make the 'move' and then repeat the effect (Ctrl + F) after selecting another layer. Repeat for all layers you need to move. RE: Losing pixels. When importing an image you can only move it around until you commit it to the layer. Once the image is committed to the layer, its size is fixed (cropped to the layer). This is not something that is done when saving/reopening. Thank you, that helped me and clarified some things. Based on Losing pixels: If we have layers, why can't we save picture 'objects' in them? Wouldn't this be a huge plus? If you need a tool to measure an angle, use the Line/Curve tool. It'll print the angle in the status bar. Saw that, but it is not convenient to use. Would be nicer to have it on the lasso tool. Quote Link to comment Share on other sites More sharing options...
Rick Brewster Posted February 13, 2012 Share Posted February 13, 2012 Well what you really want is a direct measuring/ruler tool, right? You're just trying to measure stuff between two points? I've had some requests for that before. The lasso would be something of a hack, and not really the appropriate place to put this. Quote The Paint.NET Blog: https://blog.getpaint.net/ Donations are always appreciated! https://www.getpaint.net/donate.html Link to comment Share on other sites More sharing options...
pdnnoob Posted February 13, 2012 Share Posted February 13, 2012 Use the rectangle select tool to create a selection, then use the "move selection" tool () to rotate it (right click and drag). The angle should appear in the status bar at the bottom. Quote No, Paint.NET is not spyware...but, installing it is an IQ test. ~BoltBait Blend modes are like the filling in your sandwich. It's the filling that can change your experience of the sandwich. ~Ego Eram Reputo Link to comment Share on other sites More sharing options...
