Borisyo Posted January 30, 2012 Share Posted January 30, 2012 How to accomplish "Aquire >>> Printers And Scanners" command with shortcut? How to accomplish "Color Picture", "Grayscale Picture", "Black and white picture or text " and "Custom Settings" rules with shortcuts? Quote Link to comment Share on other sites More sharing options...
BoltBait Posted January 30, 2012 Share Posted January 30, 2012 http://www.getpaint.net/doc/latest/KeyboardMouseCommands.html Quote Click to play: Download: BoltBait's Plugin Pack | CodeLab | and how about a Computer Dominos Game Link to comment Share on other sites More sharing options...
Borisyo Posted January 30, 2012 Author Share Posted January 30, 2012 http://www.getpaint....seCommands.html Where do you see there function/s that i've inquired about? Quote Link to comment Share on other sites More sharing options...
Ego Eram Reputo Posted January 30, 2012 Share Posted January 30, 2012 How to accomplish "Aquire >>> Printers And Scanners" command with shortcut? How to accomplish "Color Picture", "Grayscale Picture", "Black and white picture or text " and "Custom Settings" rules with shortcuts? Use the Menu Hotkeys. They are underlined when you hold down the Alt key e.g. Aquire: Hold down Alt then press F and Q. Quote ebook: Mastering Paint.NET | resources: Plugin Index | Stereogram Tut | proud supporter of Codelab plugins: EER's Plugin Pack | Planetoid | StickMan | WhichSymbol+ | Dr Scott's Markup Renderer | CSV Filetype | dwarf horde plugins: Plugin Browser | ShapeMaker Link to comment Share on other sites More sharing options...
BoltBait Posted January 30, 2012 Share Posted January 30, 2012 Just read the list. ..."Black and white picture or text " ... with shortcuts? Ctrl + Shift + G Not every function of Paint.NET has a keyboard shortcut. But, the ones that do are listed on that page. Quote Click to play: Download: BoltBait's Plugin Pack | CodeLab | and how about a Computer Dominos Game Link to comment Share on other sites More sharing options...
delpart Posted January 31, 2012 Share Posted January 31, 2012 And for the ones that dont have shortcuts, there are many options/applications for creating custom macros around that will fill in the blanks. Unless it's something as complicated and as well developed as MS Office, you're not often going to find a one to one shortcut array built into most applications. Quote *** Gallery at PDN-Fans Link to comment Share on other sites More sharing options...
Borisyo Posted January 31, 2012 Author Share Posted January 31, 2012 Just read the list. Ctrl + Shift + G Not every function of Paint.NET has a keyboard shortcut. But, the ones that do are listed on that page. It does something but not scanning. Quote Link to comment Share on other sites More sharing options...
Ego Eram Reputo Posted January 31, 2012 Share Posted January 31, 2012 Ctrl + Shift + G was a response to your "how to make an image Black and White" question. Aquire: Hold down Alt then press F and Q. Did you try this? Quote ebook: Mastering Paint.NET | resources: Plugin Index | Stereogram Tut | proud supporter of Codelab plugins: EER's Plugin Pack | Planetoid | StickMan | WhichSymbol+ | Dr Scott's Markup Renderer | CSV Filetype | dwarf horde plugins: Plugin Browser | ShapeMaker Link to comment Share on other sites More sharing options...
